    [Plugin] SU2POV 3.3
    16 Posts 7 Posters 19.3k Views 7 Watching
    • Didier BurD Offline
      Didier Bur
      Hi Jim,
      (1985-ish?)
      Here is the first sentence of the introduction of Pov-Ray's history:
      "Back in 1986 or so, I had an Amiga..." 🀣
      DB
        Khai
        first problem.
        it demanded a path to the Pov installer. erm... it's already installed thanks?
        so it reinstalls POV.
        I get a render..then second problem. after the first render I did... I get nothing when I push render. just 'exporting faces'.....
        running on Win7 64bit, UAC off, SU free not installed in Program Files (see UAC issues).. where Pov is installed I now have no idea.... (it was on D under d:\8888 - Render Engines \ POVRAY 64... ) oh great. now Pov is installed to C:\Users\Khai\AppData\Roaming\POV-Ray\v3.6\bin.....
          Didier Bur
          Impossible, or old version of su2pov not uninstalled.
          Impossible, the script cannot install POV.
          Regards,
          DB
          • honoluludesktopH Offline
            honoluludesktop
            Help!
            Probably not a bug per say. Could the program check, and substitute for UTF8 characters.
              Khai
              @didier bur said:
              Regards,
              no, not impossible.
              I ran it, it asked for the installer. sorry, I know what I saw and what I had to point it to. I also know that I had POV installed already. please don't tell me it's 'impossible' - I actually found that offensive. I am not an idiot or making this up.
                Didier Bur
                Hi Khai,
                You are certainly NOT an idiot, but I repeat, it is impossible that the script asks for the POV installer, nor re-install it. I presume it is the system that asked that, when the openURL method tried to launch Pov-Ray after exporting the file.
                DB
                • Z Offline
                  Zacchia
                  Thanks for the Exporter. PovRay i could never use because of the interface. With the SUExporter it works. But i am wondering about PovRay: Is it not an old renderer and other newer engines are much better or is this wrong?
                  • IdahoJI Offline
                    IdahoJ
                    As a die-hard POVray user, I can tell you it's been around for over 20 years and that it was one or the very first rendering engines produced. Right now, it's undergoing new development to take advantage of newer PC technologies, like multi-core CPUs and increased RAM capabilities amongst other things. It's also getting a new radiosity model and several other improvements for rendering outputs.
                    As for one rendering engine being "better" over others, it's relative. The real power in POVray lies in its text-based SDL (Scene Description Language). The SDL allows you access every facet of POVray and to create user-defined macros and #define procedures to extend its capabilities. Not only that, but POVray also includes built in procedures for radiosity, sophisticated illumination models and a lot more. There are things you can do in POVray that are difficult, if not nigh impossible to do in other rendering engines. Animating textures and surface finishes comes to mind...
                    I encourage anyone thinking about POVray to go the main site: http://www.povray.org/ and check out the Hall of Fame. There are renderings in there that rival any other that I've seen from other rendering engines. Personally, I consider a render to be only as good as the effort that goes into making the scene and it's elements. POVray allow me to tweak a scene down to the most minute aspect to make it precisely the way I want it to look.
                    I have used a number of other rendering engines over the years, but I consistently return to POVray for the amount of customizing and control it affords in my rendering work.
                    A great place to find current information on the new version 3.8x is here: http://news.povray.org/groups/
                    Cheers.
                    "For a moment, nothing happened. Then, after a second or so, nothing continued to happen."
                    • Z Offline
                      Zacchia
                      Thanks for answer. This sounds interesting and if you can handle it (using without real interface, just using the keyboard) then it can be good and i know that good is in hand from the user πŸ˜‰ So for me i belive this is anyway to heavy for me and i stay where i am.
                      • IdahoJI Offline
                        IdahoJ
                        Yeah, I started programming from the command line a long time ago. Folks since those days have gotten used to "point n click" interfaces ... πŸ˜„
                        BTW, POVray for Windows does have a nice IDE with integrated help, etc. It's even possible to add custom libraries and code for insertion into your .pov files... It's a bit advanced but a great time saver.
                        Cheers.
