    Something new.
    40 Posts 14 Posters 6.9k Views 14 Watching
    • W Offline
      Wacov
      @cphillips said:
      When I started this I took another look at all the physics engines out there and decided they were unsuitable for one reason or another.
      Is it switched to Newton 2.0... or is that not stable enough?
        CPhillips
        BTW. I had never heard of LazyScript ๐Ÿ˜ฒ . I must of missed it somehow. I am looking at it now. But from a glance it looks like an attempt to fix the same problem SketchyBehaviors is. Allowing others to write code that can be easily used by others.
        Excellent work guys!
          CPhillips
          Yeah, its the latest beta of 2.0.
            camokid11
            so will the scripts be like the ones show in the picture, or will they be similar to whats being used in sketchy physics at the moment โ“ โ“ โ“
            If you can read this, thank a teacher.
            If you can read this in english, thank a soldier.
              CPhillips
              The behavior scripts are an evolution of what was in sp3x. ontick{}, ontouch{} etc.
                camokid11
                so hopefuly not too hard then, ill have to try it when it comes out because ive got mixed feelings about it. One last thing, will it be compatable with sketchyphysics, eg: youcan run old sketchyphysics models on it, or have a bit of both worlds?
                • H Offline
                  hobbnob
                  I don't think it will be tay, as it uses a whole new physics engine.
                  My WIP Thread:Here
                    CPhillips
                    Sorry. Maybe simple models could be converted. But anything that used a controller field or scripted elements wouldnt work.
                    • W Offline
                      Wacov
                      Out of interest, how is the joint data gonna be stored... in other words, is the JCT making a comeback?
                        CPhillips
                        Joints will just be another behavior(s). I imagine most joints will not need a joint connection tool because they will connect themselves automatically via touching or something like "wheel" auto connects to "body".
                        When you do need to manually connect a body to a joint you will do it in the joints properties. Probably a button like "Attach all selected bodies to this joint". Only not as wordy.
                          CPhillips
                          Update. I put up a video of the current version. Its now working pretty well and there are a few interesting behaviors in place.
                          First the video shows a cone being created and then a behavior being created for it. Toggle color. This simple behavior allows an group/component to be two different colors. Another behavior can tell it to toggle. It starts out the first color. Once behaviors are started using the button at the top the cone changes to its first color. When behaviors are stopped it returns to its original color.
                          Thats kinda worthless by itself. But the second behavior added in the video allows the color to be toggled by clicking on the object. Note the Event and Signal field both contain "ToggleColor" That means when the click happens the toggle color behavior changes color.
                          Next is Interpolate. It allows a object to smoothly move from one "pose" (position+rotation) to another by moving a slider. Note that the slider works even if the behaviors are not running. ๐Ÿ˜„
                          Next is Follow Path. The behavior moves the object, Sang in this case, smoothly on the curve selected. The speed is adjustable even when the behavior is running and he can be set to ping pong or loop.
                          Last are a few objects with the physics rigid body behavior.
                          Video best viewed in 480p or higher. Otherwise you cant make out much. Not sure why the frame rate is so low in the video its smooth in real time.
                          [flash=620,500:1zvyzk27]http://www.youtube.com/v/U1bar8gKVsI&hl=en_US&fs=1?rel=0&hd=1"[/flash:1zvyzk27]
                          • W Offline
                            Wacov
                            The rigid bodies seem to collide with a plane at ground level - will this be optional? Looking fantastic though, this will have many uses ๐Ÿ˜„
                            • Mike LuceyM Offline
                              Mike Lucey
                              ๐Ÿ‘
                                camokid11
                                ๐Ÿ’š ๐Ÿ’š ๐Ÿ’š Not looking too bad, still have mixed feelings with it though, ill have to try it out when the first release is available, but some of them could be useful...
                                  CPhillips
                                  Collide with the invisible ground plane is just testing right now. But I think it might make sense for a default. If I was a totally new user I not expect the objects I just made on the "ground" to start falling as soon as I pressed start. But its open to debate.
                                    Davidfi1
                                    Very nice work!
                                    I am a big fan of your work in SketchyPhysics
                                    Let me know if I could help.
                                    David.
                                    • H Offline
                                      hobbnob
                                      yay thank you for making the infinite plane, I thought you would forget. I'm not that worried about this release, since as I understand the joints will all be the same, and all the aspects of sketchyphysics will still be there, but with multicore support.
                                      My WIP Thread:Here
                                      • 4 Offline
                                        4dHans
                                        Nice! ๐Ÿ˜› Your plugins are great!
                                          Physicsguy1
                                          This sounds great. It is becoming more FPS-friendly, which I like. ๐Ÿ˜„ I am excited, but my absence dummed me up and I don't know half about scripting than I used to know. It definitely will be troublesome learning it all over again... ๐Ÿ˜ž
                                            camokid11
                                            ๐Ÿ˜ฎ physicsguy, its been forever since we last got any contact from you. where have you been.
                                            and dont worry, im no good at scripting/codes so im proberbly in the same boat (i just hope theres no ice berg ahead thouhg ๐Ÿ˜ )
