    Something new.
    40 Posts 14 Posters 8.1k Views 14 Watching
    • Mike LuceyM
      Mike Lucey
      This sounds great!
      • W
        Wacov
        I'm gonna have fun with this one!!
        So, will all the newtonServer external commands be available for scripting, even if they're not implemented? I'm just wondering how we can get access to the materials πŸ’š
        • H
          hobbnob
          Kinda confused to be honest, mostly about the behaviour thing and ruby. Is sketchyphysics still usable for people who don't know ruby? A lot of the features mentioned need ruby to make them work, which is kinda worrying. . .
          My WIP Thread:Here
          • C
            camokid11
            To be honest, i dont like the idea, i hate scripting and the easier its made the better. Im still catching up on the current Sketchyphysics scripting (thanks to LazyScript). However the idea is good as its something difference but personaly, i think i will struggle with it.
            Having said that, it wouldbe better to use a different Physics engine for sketchup.i guess idea really have to try it first to really give my proper opinion.
            If you can read this, thank a teacher.
            If you can read this in english, thank a soldier.
            • C
              CPhillips
              Yes. Thats the way it works.
              • C
                CPhillips
                No, if anything you will need to know less. It will come with all the basic SP features and only new features will require ruby code.
                Regarding the question of changing the physics engine. When I started this I took another look at all the physics engines out there and decided they were unsuitable for one reason or another. I even went so far as to get Physx running only to discover that it does not support cone or cylinder shapes. And convex hulls can only have 256 faces. Ug.
                • W
                  Wacov
                  Is it switched to Newton 2.0... or is that not stable enough?
                  • C
                    CPhillips
                    BTW. I had never heard of LazyScript 😲 . I must of missed it somehow. I am looking at it now. But from a glance it looks like an attempt to fix the same problem SketchyBehaviors is. Allowing others to write code that can be easily used by others.
                    Excellent work guys!
                    • C
                      CPhillips
                      Yeah, its the latest beta of 2.0.
                      • C
                        camokid11
                        so will the scripts be like the ones show in the picture, or will they be similar to whats being used in sketchy physics at the moment ❓ ❓ ❓
                        • C
                          CPhillips
                          The behavior scripts are an evolution of what was in sp3x. ontick{}, ontouch{} etc.
                          • C
                            camokid11
                            so hopefuly not too hard then, ill have to try it when it comes out because ive got mixed feelings about it. One last thing, will it be compatable with sketchyphysics, eg: youcan run old sketchyphysics models on it, or have a bit of both worlds?
                            • H
                              hobbnob
                              I don't think it will be tay, as it uses a whole new physics engine.
                              My WIP Thread:Here
                              • C
                                CPhillips
                                Sorry. Maybe simple models could be converted. But anything that used a controller field or scripted elements wouldnt work.
                                • W
                                  Wacov
                                  Out of interest, how is the joint data gonna be stored... in other words, is the JCT making a comeback?
                                  • C
                                    CPhillips
                                    Joints will just be another behavior(s). I imagine most joints will not need a joint connection tool because they will connect themselves automatically via touching or something like "wheel" auto connects to "body".
                                    When you do need to manually connect a body to a joint you will do it in the joints properties. Probably a button like "Attach all selected bodies to this joint". Only not as wordy.
                                    • C
                                      CPhillips
                                      Update. I put up a video of the current version. Its now working pretty well and there are a few interesting behaviors in place.
                                      First the video shows a cone being created and then a behavior being created for it. Toggle color. This simple behavior allows an group/component to be two different colors. Another behavior can tell it to toggle. It starts out the first color. Once behaviors are started using the button at the top the cone changes to its first color. When behaviors are stopped it returns to its original color.
                                      Thats kinda worthless by itself. But the second behavior added in the video allows the color to be toggled by clicking on the object. Note the Event and Signal field both contain "ToggleColor" That means when the click happens the toggle color behavior changes color.
                                      Next is Interpolate. It allows a object to smoothly move from one "pose" (position+rotation) to another by moving a slider. Note that the slider works even if the behaviors are not running. πŸ˜„
                                      Next is Follow Path. The behavior moves the object, Sang in this case, smoothly on the curve selected. The speed is adjustable even when the behavior is running and he can be set to ping pong or loop.
                                      Last are a few objects with the physics rigid body behavior.
                                      Video best viewed in 480p or higher. Otherwise you cant make out much. Not sure why the frame rate is so low in the video its smooth in real time.
                                      [flash=620,500:1zvyzk27]http://www.youtube.com/v/U1bar8gKVsI&hl=en_US&fs=1?rel=0&hd=1"[/flash:1zvyzk27]
                                      • W
                                        Wacov
                                        The rigid bodies seem to collide with a plane at ground level - will this be optional? Looking fantastic though, this will have many uses πŸ˜„
                                        • Mike LuceyM
                                          Mike Lucey
                                          πŸ‘
                                          • C
                                            camokid11
                                            πŸ’š πŸ’š πŸ’š Not looking too bad, still have mixed feelings with it though, ill have to try it out when the first release is available, but some of them could be useful...
