    Something new.
    40 Posts 14 Posters 8.1k Views 14 Watching
    • C
      CPhillips
      @camokid11 said:
      so will the scripts be like the ones show in the picture, or will they be similar to whats being used in sketchy physics at the moment โ“ โ“ โ“
      The behavior scripts are an evolution of what was in sp3x. ontick{}, ontouch{} etc.
      • C
        camokid11
        so hopefuly not too hard then, ill have to try it when it comes out because ive got mixed feelings about it. One last thing, will it be compatable with sketchyphysics, eg: youcan run old sketchyphysics models on it, or have a bit of both worlds?
        If you can read this, thank a teacher.
        If you can read this in english, thank a soldier.
        • H
          hobbnob
          I don't think it will be tay, as it uses a whole new physics engine.
          My WIP Thread:Here
          • C
            CPhillips
            Sorry. Maybe simple models could be converted. But anything that used a controller field or scripted elements wouldnt work.
            • W
              Wacov
              Out of interest, how is the joint data gonna be stored... in other words, is the JCT making a comeback?
              • C
                CPhillips
                Joints will just be another behavior(s). I imagine most joints will not need a joint connection tool because they will connect themselves automatically via touching or something like "wheel" auto connects to "body".
                When you do need to manually connect a body to a joint you will do it in the joints properties. Probably a button like "Attach all selected bodies to this joint". Only not as wordy.
                • C
                  CPhillips
                  Update. I put up a video of the current version. Its now working pretty well and there are a few interesting behaviors in place.
                  First the video shows a cone being created and then a behavior being created for it. Toggle color. This simple behavior allows an group/component to be two different colors. Another behavior can tell it to toggle. It starts out the first color. Once behaviors are started using the button at the top the cone changes to its first color. When behaviors are stopped it returns to its original color.
                  Thats kinda worthless by itself. But the second behavior added in the video allows the color to be toggled by clicking on the object. Note the Event and Signal field both contain "ToggleColor" That means when the click happens the toggle color behavior changes color.
                  Next is Interpolate. It allows a object to smoothly move from one "pose" (position+rotation) to another by moving a slider. Note that the slider works even if the behaviors are not running. ๐Ÿ˜„
                  Next is Follow Path. The behavior moves the object, Sang in this case, smoothly on the curve selected. The speed is adjustable even when the behavior is running and he can be set to ping pong or loop.
                  Last are a few objects with the physics rigid body behavior.
                  Video best viewed in 480p or higher. Otherwise you cant make out much. Not sure why the frame rate is so low in the video its smooth in real time.
                  [flash=620,500:1zvyzk27]http://www.youtube.com/v/U1bar8gKVsI&hl=en_US&fs=1?rel=0&hd=1"[/flash:1zvyzk27]
                  • W
                    Wacov
                    The rigid bodies seem to collide with a plane at ground level - will this be optional? Looking fantastic though, this will have many uses ๐Ÿ˜„
                    • Mike LuceyM
                      Mike Lucey
                      ๐Ÿ‘
                      • C
                        camokid11
                        ๐Ÿ’š ๐Ÿ’š ๐Ÿ’š Not looking too bad, still have mixed feelings with it though, ill have to try it out when the first release is available, but some of them could be useful...
                        • C
                          CPhillips
                          Collide with the invisible ground plane is just testing right now. But I think it might make sense for a default. If I was a totally new user I not expect the objects I just made on the "ground" to start falling as soon as I pressed start. But its open to debate.
                            Davidfi1
                            Very nice work!
                            I am a big fan of your work in SketchyPhysics
                            Let me know if I could help.
                            David.
                            • H
                              hobbnob
                              yay thank you for making the infinite plane, I thought you would forget. I'm not that worried about this release, since as I understand the joints will all be the same, and all the aspects of sketchyphysics will still be there, but with multicore support.
                              My WIP Thread:Here
                                4dHans
                                Nice! ๐Ÿ˜› Your plugins are great!
                                • P
                                  Physicsguy1
                                  This sounds great. It is becoming more FPS-friendly, which I like. ๐Ÿ˜„ I am excited, but my absence dummed me up and I don't know half about scripting than I used to know. It definitely will be troublesome learning it all over again... ๐Ÿ˜ž
                                  • C
                                    camokid11
                                    ๐Ÿ˜ฎ physicsguy, its been forever since we last got any contact from you. where have you been.
                                    and dont worry, im no good at scripting/codes so im proberbly in the same boat (i just hope theres no ice berg ahead thouhg ๐Ÿ˜ )
                                    • P
                                      Physicsguy1
                                      What happened? Something common with me. I got bored. But then I got interested with it again. It usually happens. But I'm happy to say that I will be back for a long time.
                                      Anyway, let's keep this less personal and more sketchyphysics(Although I am scared about what I've missed ๐Ÿ˜„ )
                                      What I have been itching to see would be a "space-mode", where objects are relieved of the universal gravitational force, resistance, etc, kinda like space. I have also always wanted an accurate gravity system(not just fall down to the infinite plane, objects actually attracted to a others), such that you can simulate orbits, and stuff like that(I like astrophysics). It would be nice, and I would like to help build something like that(I know my astrophysics).
                                      I also would like to see points in lieu of meshes'n'objects so you can simulate light and other high-component-density-particle simulations.
                                      • H
                                        hobbnob
                                        I didn't understand a word of all that particle stuff, but it seems gone are the days when physicsguy made planes. . .
                                        Anyways, any updates on sketchybehaviours yet chris?
                                        My WIP Thread:Here
                                        • C
                                          CPhillips
                                          That was possible in SP3x. One of the demos is a planet system.
                                          You could use a very small triangle. But the problem with a full particle system would be that it is slow to move lots objects in SU, no matter how many faces they have.
                                          • C
                                            CPhillips
                                            I am working on integrating the physics engine. Its a bigger job than I expected because I have to recreate a lot of what was already done in SP. Like the ability to pick up objects with the mouse.
                                            But I am also doing some remodeling in the house and that is taking up a lot of my time.
                                            • 2 / 2
