    Get/Set Image and Group glue_to ?
    3 Posts 3 Posters 516 Views 3 Watching
      ComponentInstance has .glue_to - but Image and Group does not despite that they can be glued.
      And Face has .get_glued_instances which does list Images and Groups attached.
      Is there a workaround to glue or unglue Image or Group entities using the API?
        class Sketchup;;Group
          def real_parent
            if self.entities.parent.instances.include?(self)
              return self.entities.parent
            else
              Sketchup.active_model.definitions.each{|definition|
                return definition if definition.instances.include?(self)
            end#end
            return nil # Should not happen.
        class Sketchup;;Image
          def real_parent
            else
            end#end
        Now use these to find the 'component-instance' of a group/image - e.g. of say the group you want to 'unglue'...
        group.real_parent.instances.each{|ins|
          if ins == group
            ins.glued_to = nil
            break
          end#if
        I haven't tried this but something like it should work... πŸ€“
        EDIT: tried it it fails ! πŸ˜• πŸ˜’
        • Dan RathbunD
          Dan Rathbun
          see new beta post, SKX forum:
          [code] beta Group/Image parent, glued_to? etc.
          I'm not here much anymore.
