    Ships Hulls
    20 Posts 7 Posters 2.8k Views 7 Watching
    • charly2008C Offline
      charly2008
      Hi Ken,
      thanks for your advices. I will try it that way. It's like Sketchup, you have to practice.
      Karlheinz
        charly2008
        @gaieus said:
        Yes, there were all these demos but what I really would have liked to make there were some historic ships and for the life I could not get it to make a Santa Maria for me.
        A new experiment with Delftship. Gaieus inspired me with his note for the Santa Maria. It was not so easy and the model is not as perfect as it could be. The Jpeg Plan has not a good resolution. At present I'm not shure yet whether I'll continue working on it.
        Karlheinz
        Santa Maria1.skp
          This is way too cool even if you say it's not "perfect" 😄
          I should reconsider to use this little gem later for sure.
          • IdahoJI Offline
            IdahoJ
            DelftShip is a wonderful tool. I've been using it for the last few years to recreate hull data for turn of the century sailing canoes. These small craft were very popular in from about 1870 to 1900 but much of the original construction information has faded into history. Being able to import both lofting data and line drawings, (when I can either find them) makes Delftship very flexible.
            I've also used Delftship to create a prototype design for a streamlined single wheel trailer to be pulled behind my '94 BMW R1100 RS sport bike...
            Cheers!
            BTW, as far as "perfect", I say don't sweat it. No one is going to get out a ruler and protractor to check your work! Close enough is good enough IMO.
            Cheers!
            "For a moment, nothing happened. Then, after a second or so, nothing continued to happen."
              charly2008
              Hi Jeff,
              would you be so kind to show us some examples you made with Delftship. That would interest me very much.
              At present i try to develop a Viking Ship. The problems i'm thinking about is how to make the planks of the hull as a texture and how can I give a wall thickness to the hull. Any idea?
              Karlheinz
                Wall thickness could be made with Joint PushPull by Fredo I guess. Maybe using Whaat's UVTools could then help with the planking. It should have some nice clinker planking.
                  charly2008
                  Hi Gaieus,
                  thanks for your tip. But the best result i got with "Push-Pull Multiple Faces Along Their Normals. The faces had to be done by "Make Faces 1.4.
                  Trace is a bit of manual work but better than having to redraw every vector.
                  Maybe helpfull for others.
                    charly2008
                    i have a question to the professionals in the Forum.
                    A Problem of texturing the planks is that all planks are running horizontely (projected Texture) and this not correct. They should run along that red path shown below.
                    Is there any possibility to do so?
                    • jo-keJ Offline
                      jo-ke
                      I'm also waiting for an answer. This is a problem for me too. I hope for a solution.
                      http://www.zz7.de
                        UV Tool?
                        • Alan FraserA Offline
                          Alan Fraser
                          There's another free Hull designer here near the bottom of the page. It sometimes produces results that are double-skinned (mucho z-fighting) but that's easy enough to clear up with a few well-chosen SU commands. Basically temporarily hide the edges, delete the faces then use Create Face to create clean new ones.
                          3D Figures
                            Or use ThomThom's Cleanup Plugin.
                              charly2008
                              Hi jo-ke,
                              Have a look at: http://forums.sketchucation.com/viewtopic.php?f=323&t=39442&start=105
                              Charly
                              • jo-keJ Offline
                                jo-ke
                                Thank you charlie. very good pluginn...
                                http://www.zz7.de
