    [Plugin] 2D Tools
    791 Posts 178 Posters 635.2k Views 177 Watching
      tulacong
      thank
        amjhds
        Hello, I can't get these plugins to work.
        I already put the 2Dtools_4.6 into the Plugins folder.
        Please help.
        Thanks,
          Alberto
          Have you extracted all of the files and folders from the zip file, keeping the files in their folders [do not drag and drop files].
          These files and folders go into the Plugins folder in the same arrangements as they are in the zip file.
          If you have put files in the wrong place remove them and start again.
          To activate the toolbar select it from the View > Toolbars Menu.
          Are you getting any error messages ?
            rickgraham
            TIG,
            I just downloaded your 2D Tools v4.6 and am looking at the help file. Does this plugin work on Macs? I don't get any icons and some of the commands don't seem to work form the Draw pulldown. I'll keep on searching, but I wanted to ask.
            Rick
            Edit: Nevermind - I'm an idiot!
              rickgraham
              Okay, now I DO have a legitimate question for TIG on this.
              Is there any way I can take the 2D Tools Line that I grouped and have it drape onto a surface while keeping its thickness and linetype?
              I have a weird request that the client wants their property line shown on the model. Right now I have it hovering just above the surface, but since the surface has a good amount of slope, at one end the line is hugging just above the surface, while at the other end it is perhaps 50 off the surface. It looks dumb like that anyways.
              So, I tried to use the sandbox tools drape and it didn't do anything. πŸ˜•
              Thanks TIG for yet another steller plugin. And I happened upon this AFTER I bought the dashed lines from smustard 😐 Oh well, I'll find a use for that one too. πŸ˜„
              Rick
                Answering two questions at one here...
                It works on Macs - ensure all of the required files and files-in-folders are in the right place - Mac Plugins location can be tricky - make sure you do it right - there are other threads about this.........
                If you 'draw' Lines over a 3D surface then 2D Line-Style WILL work - it is not limited to 2D - BUT you might want to use a tool like Tools-on-Surface by Fredo to make the 'draped' lines - or use the Sandbox Tools ???
                πŸ€“
                  dedmin
                  The same rectangle filleted with 2D Fillet and with the arc tool changed the size - arcs with the same number of segments and the same radius?
                  fillet.skp
                    dedmin
                    Set you 0.0000 as high as it'll go and see what the error is - measure the distances with the tapemeasure rather than dimensions - I can't see what the issue might be ?
                    Try doing it on a rectangular face draw on the center of a larger face and see if it's the same ...
                    I've no idea what it might be.... πŸ˜•
                      dedmin
                      Tried again and now the height changed and the number of segments is 17 even if I typed 18s. Opened the SketchUp's file in SpaceClaim :
                        dedmin
                        Now I did it at the top view and everything is fine - the first example was at the front view! In both cases - parallel projection. πŸ˜’
                          theark
                          Many thanks.
                          • W Offline
                            watkins
                            Dear dedmin,
                            Are you able to import SU files into SpaceClaim easily? What process steps do you use?
                            I have been thinking of switching to SpaceClaim from Inventor.
                            Regards,
                            Bob
                              dedmin
                              SpaceClaim opens SketchUP's files directly and also exports in .skp format. Amazing program - SketchUP on steroids! Inventor is more powerful, but to bloated, heavy,slow and $$$$! There is a demo You can download and try and a lot of video tutorials - http://www2.spaceclaim.com/forum/files/9/default.aspx. Watch them first to see how different is this software! See this video for SketchUP integration:
                              http://www2.spaceclaim.com/learnmorenow/product_videos.aspx?v=2009_plus_sketchup.flv
                              • W Offline
                                watkins
                                Dear dedmin,
                                Thanks for the quick reply. I work at a university in the UK, and so I am entitled to an academic copy, which should make the transition cost effective. Are you UK based?
                                Kind regards,
                                Bob
                                  dedmin
                                  No - Bulgaria. You can join here - http://www.spaceclaiming.com/forum
                                    dedmin
                                    @watkins said:
                                    Dear dedmin,
                                    Kind regards,
                                    Bob
                                    Yes - very cost effective - http://www.novedge.com/products/3148 β˜€
                                    Be warned that this piece is like SketchUP - You always come back to it! πŸ˜†
                                      Michaelv
                                      @tig said:
                                      @oxer said:
                                      Hello!!
                                      The first Thanks! for your marvelous plugin. I'm Spanish user of SUp, i have seen that the last version include Spanish translation, my problem is that if i push on the help icon into SUp, no it appears the help, i don't know why, i work in Mac, in the 2Dtools folder there is a file with this name "~$toolsHelp.htm" its contents is: "TIGTIG The Grants$(^±€ï˜|ì*,%"
                                      Can be the problem this? is a problem in the characters codification in Mac?
                                      Waiting your answer, advanced Thanks!!
                                      Somehow a 'rogue' htm temporary file has got left in the zip file [unnoticed] - however, it's not needed at all and its existence shouldn't cause a problem. There should also be a file called 2DToolsHelpES.htm and a matching folder of images etc, this is the Spanish help file that should load for you on clicking the help-button or picking the equivalent menu item. I've reattached it all of them in a zip file, to see if it helps.
                                      Put everything [htm and folder] into the ../Plugins/2DTools/ folder
                                      Can you open the Spanish htm file 'manually' - double-click on it - when outside of SketchUp ?
                                      If you cannot then there is something that is not working properly in the 'help' file lookup.
                                      Can you also copy/paste this line of text into the Ruby Console and report back what the result is...
                                      Sketchup.get_locale.upcase
                                      It will be fixable...
                                      [attachment=0:1g18rgvi]<!-- ia0 -->PutInto2DToolsFolder.zip<!-- ia0 -->[/attachment:1g18rgvi]
                                      Hello TIG Thanks very much for all your stuff it's awesome. I've been using the 2D for a while no major issues.
                                      SIncidently though I have the same problem with the help file on Mac, Did the extraction many times, tools work mostly (except toggles, more below) but help doesn't.
                                      File (2Dtoolshelp.htm)can be opened separately (the one in the plugins, I use the EN one)
                                      Pluging your command into the ruby console gives me EN-US
                                      More troubleshooting info: clicking the help button doesn't do anything, no info in the help console. The button highlights but doesn't turn grey and any other button (tool) remains active.
                                      Now another very minor issue I have is that the CTRL toggle doesn't work (it's a MAC that's why). For example for the arc tool: I can't get anything to change but select 1st pt, 2nd pt and then circle circumference. Command and option (alt equivalent) do nothing as expected, and control doesn't toggle.
                                      Control does this: If you start with an arc (no other object) and keep it pressed it prevents you from clicking point until you release it, then it does nothing. As toggle it doesn't work either.
                                      If you have already an object (a line for example) and clicking on it, it brings up a contextual menu (the entity info menu, same as right click)
                                      Alt toggle works fine on other tools.
                                      The undo button does weird things too on entities. It erases the first one or few and then either it adds points or it just stop erasing.
                                      Also incidentally, no menu access, only the tool bar. ( I don't know if there is supposed to be a menu access, just in case I mention it)
                                      All these are minor issues, as I"m really happy with everything as it is, so it's just for feedback.
                                        I know why the MAC Help doesn't open.
                                        If you put this attached file into the ../Plugins/2Dtools/ folder in place of the earlier one it should open Help on a Mac... 2D#loader.rb I've also temporarily added this updated file to the first item in this thread...
                                        2D Tools sub-menu is to be found under the Draw menu...
                                          Michaelv
                                          If you put this attached file into the ../Plugins/2Dtools/ folder in place of the earlier one it should open Help on a Mac... [attachment=0:36uy3x3m]<!-- ia0 -->2D#loader.rb<!-- ia0 -->[/attachment:36uy3x3m] I've also temporarily added this updated file to the first item in this thread...
                                          It works like a charm, thank you Sir! Sorry for the submenu, I can't believe I didn't find it before, I always used he toolbar so never looked for it, it's only until you mentionned whether help could be accessed from the submenu that I tried to find it.
                                            Michaelv
                                            OK I've solved the problem of the control key on Macs. Into the ruby programs that correspond to tools that have a ctrl modifier, I changed all tests for VK_CONTROL into VK_COMMAND, I changed the display to cmd too.
                                            I don't have stuff to zip but I'll gladly send you the modified files through email or whatever you'd like.
                                            Thanks TIG
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 39
                                            • 40
                                            • 12 / 40
