    Face plugin question
    5 Posts 4 Posters 569 Views 4 Watching
    • E Offline
      EDMON242004
      Hi everyone just want to ask about a plugin that can automatically orient faces of a model inward or outward? I just downloaded a 3ds model and the faces are facing in different directions. thanks for the help πŸ˜„
        Here is an "automatic face reverser" by Didier:
        http://forums.sketchucation.com/viewtopic.php?t=5333
        and a "brush like" tool by Tomasz:
        http://forums.sketchucation.com/viewtopic.php?t=13380
          Alternatively I'd simply shortcut the Reverse and Orient tools [select a face first to see these as available commands in Window > Preferences > Shortcuts]. I'd use say Q+shift and Q+shift+alt.
          The you can quickly edit a form. Select a face, Q+shift flips it over, it stays selected, Q+shift+alt to orient all connected faces the same way as it s now; or select several faces and Q+shift to flip them all at once etc etc...
          The problem with any automated fix is deciding which is 'the inside' and which is 'the outside'; also edges with more that two faces will always make one connected face wrongly oriented compared to another - you must then fix it manually anyway... πŸ€“
          • DavidBoulderD Offline
            DavidBoulder
            I've thought about a plugin that would try and identify which faces are reversed. If you had a convex volume as a group you could make sure all face normals point towards the center of the group. Another approach would be for a face to look at all adjacent faces and look at their face orientation and would match them if they were all the same. Some things would sneak through the crack with this (e.g. multiple bad faces side by side), but this would work on non-convex volumes.
            David Goldwasser
            OpenStudio Developer
            National Renewable Energy Laboratory
              It's easy to make a shape with 'all' concave faces that you want to face 'outside' so it'd fall over at the first hurdleCapture.PNG
