    Drawing a Shaft with Rectangular Key-Ways
    5 Posts 2 Posters 1.2k Views 2 Watching
      ahandrew
      I know this is probably relatively simple to do, but I seem to be too stupid to figure it out.
      I want to put rectangular key-ways through a round shaft. I have no problem putting round key-ways through the shaft. How do I put rectangular key-ways into and through a round shaft?
      Al
      • bmikeB Offline
        bmike
        Something like this?
          ahandrew
          bmike:
          That is exactly what I need. How do I do that?
          • bmikeB Offline
            bmike
            Draw cylinder. Make it a component.
            Draw keys, make them longer than you need. Make component.
            Copy these where you need them.
            Explode keys.
            Edit cylinder component. Select all by triple clicking.
            Right click>Intersect with model
            Close component.
            Triple click your key(s).
            Right click>Intersect with model.
            Delete the 'extra' bit of the key(s).
            Explode your cylinder component.
            Delete out the curved rectangle where the key entered the cylinder.
            You should now have the remnant of the key inside the cylinder.
            Remake into component.
              ahandrew
              bmike:
              Perfect, thanks again.
              Al
