    [Plugin] Wudworx Mortise & Tenon Plugin (woodworking)
    6 Posts 3 Posters 8.3k Views 3 Watching
      PurpLev
      Another intuitive and simple to use woodworking plugin for Mortise and Tenon joinery. works on 2 components that are positioned in a way to allow M&T joinery between them. the plugin will automatically select which component will get the Tenon, and which will get the Mortise, and will generate the geometry accordingly. (parameters to set the tenons and mortises can either be entered in explicit measurements aka 1/2" or 20mm or in relation to the tenoned/mortised parts aka *1/2 of the mortised part thickness, or *1/3 of the tenoned part thickness:
      [flash=640,385:3o07u6ps]http://www.youtube.com/v/c-7YwVMSglg[/flash:3o07u6ps]
      Plugin website: http://sites.google.com/site/wudworx/
      • Didier BurD Offline
        Didier Bur
        Interesting, but where can we download it ?
        DB
        • Rich O BrienR Online
          Hi Didier,
          Dave R mentioned it here
          But if you're unable to view the Woodworking forum, you'll get it here
            Didier Bur
            I was not aware of the Woodworking Forum... Never read the bottom of the page 🀣
            What must I do to access it ?
            DB
              You can enable from the 'User Groups' tab in your 'User Control Panel' along with alot other Language forums.
              I often forget to go there myself as it doesn't appear if you click 'Active Topics' πŸ˜•
                PurpLev
                Thanks.
                My bad for forgetting to include the plugins website πŸ˜•
                I have now edited it in the OP.
                FWIW, It's http://sites.google.com/site/wudworx/
