    Better Resolution on Export
    layout
    7 Posts 3 Posters 2.1k Views 3 Watching
      Jim57
      Maybe this is a stretch, but I'm trying to export presentation documents from SketchUp or LayOut. My curves have a case of the jaggies, even when I use LO to make a "fine" quality PDF. JPG is no better.
      I seem to remember a choice somewhere between vector & bitmap, perhaps— does this relate to exporting, and if so, where is it? If not, what controls export resolution/rendering?
      Do most folks use another render engine for this?
      TIA,
      Jim
      • jeff hammondJ Offline
        you can choose vector output via the print dialog then save as pdf..
        not sure if you can do this on pc
          i should add that you're still not going to entirely get rid of the jaggies by doing that..
          a better method would be to export at a giant size then reduce in photoshop.
            Jim57
            That works nicely from SketchUp. It looks like the image quailty has already been set by the time it's in Layout? Is there a way to up the image quality so I can compose images like in LayOut? Or should I export individual images from SketchUp and compost them in separate graphics software?
              Jim57
              Whoops, I didn't see your answer, Jeff. I'll try that using Canvas (I don't have Photoshop). Looks like I would do that under File/ Export/ Options, then set image size. I presume a larger image size gives better resolution, e.g., the resolution is fixed and a bigger image gets more fine detail?
              Thanks,
              Jim
                jhauswirth
                You can select vector or hybrid rendering of SU models in LO
                by selecting the model and changing the rendering type in the
                SketchUp Dialog.
                  Jim57
                  Cool. I get it now, thanks.
                  It takes forever to render if there's a lot of edges, but it makes for a really nice output when I set the Model Window output choice to either Vector or Hybrid (depending on the amount of surfaces) and set the Export/ Options quality to High.
                  Jim
