    [Plugin] ThomThom's Menu
    12 Posts 7 Posters 19.1k Views 7 Watching
      Hurry! πŸ‘
      Yes all plugs must be listed by Plugins/Author! β˜€
      That is mnemonic trick and save many place on the menu plugins!
        I personally don't like the Group by Author system - so I opted for a user choice system. In theory other systems can be made.
        From now on my plugins will look for a variable $tt_menu which it will attach to if present. If not present it will use the default Tools, Plugins or whatever top menu I choose.
          chrisjk
          Thanks for this Thom. I do like the Group by Author system - when it's got a TT stamp (or a TIG, Chris Fulmer, Fredo etc. stamp on it, there is some guarantee of quality!)
          Ideally, a menu that could be sorted on the fly in the manner of a booklist - by author, purpose, date etc would be useful especially if it could load/unload plugins as needed..
            alz
            This is kinda like an idea I had a couple months ago (but not savvy enough with Ruby yet to try out) --> create an generic_menu.rb which passes in menu variables. Add this (require generic_menu.rb) to any existing plugin (yours or other peoples), then comment out the original plugin's menu. Now call the other script and send over the plugins menu commands and how you'd like to group it (submenu or even a separator).
            For example, 5 different plugins from all places on the web. Re-route them where ever you like:
            plugins
            ... Frequent
            ...... FredoScale
            ...... Mover2
            ... Utility
            ...... Weld
            ...... Cleanup
            ... SketchyPhysics2
            You'd have to tweak existing plugins, but it'd only use one external script to do the routing. It could be expanded to also influence context menu options or even toolbar or cursor options.
              Why your ThomThom's Plugins is down page ?
              I must scroll down my big list for find it!
              It's not possible to put it on the top page? πŸ˜‰
              All script's heros are there ! β˜€
                What page?
                (p.s. I moved the posts in regard to the TT_Lib to that thread: http://forums.sketchucation.com/viewtopic.php?f=323&t=23307 )
                • Dan RathbunD Offline
                  Dan Rathbun
                  @thomthom said:
                  What page?
                  He's speaking of the menu page. His menu is so large that it's scrollable, and your submenu appears near the bottom.
                  You (ThomThom or user) need to rename the script that creates the TT submenu to have a '!' as the first character:
                  tt_menu.rb rename to !tt_menu.rb
                  and then it will load as one of the first files from the plugins folder.
                  I'm not here much anymore.
                    Thx! I have now 2 possibilities a number and the "!" πŸ‘
                    (I believe that Thomthom has linked the posts)
                    See my answer πŸ˜‰
                    • EdsonE Offline
                      Edson
                      thom,
                      I installed this plugin but all I get in its menu is "website" and "sketchucation". no plugins. and I have tt lib installed. why do you think this is happening?
                      regards,
                      http://www.mahfuz.arq.br
                        Edson,
                        Only a few of my plugin supports this at the moment.
                        The one that does will add themselves to this menu under the Website and SketchUcation links.
                        If you don't have any of my plugins that support this then it'll be empty.
                        • KrisidiousK Offline
                          Krisidious
                          This helps me because I sometimes can't remember the name of a tool but I know who made it...
                          By: Kristoff Rand
