    Twilight project
    42 Posts 12 Posters 8.2k Views 12 Watching
    • Bryan KB
      I have to agree that the second one looks better.
      Is this an interior furnishings store? Looks nice.
      • X
        xrok1
        almost looks like an emitter material on the posts. πŸ˜•
        • jo-keJ
          jo-ke
          Yes, that is how my interior design shop should look like after the reconstruction in july.
          http://www.zz7.de
          • jo-keJ
            jo-ke
            A detail of that project:
            http://www.zz7.de
            • FrederikF
              Frederik
              @jo-ke said:
              The modell is to big to upload (39MB) but I took the walls and the ceiling with the lights in a seperarte file. I hope that helps.
              Thanks...
              I see some issues with your model...
              1.) Please remember to model with faces showing front...
              (A lot of the geometry in your model is facing back-face)
              2.) Point light components are very big and interfear with mesh in the light component.
              I suggest you take a look at the Lights - render times thread at the TWR forum, which should give you a lot of help creating light components...
              Please also see the Light Components for Twilight
              Hope this can help you improve...
              Cheers
              Kim Frederik
              • Bryan KB
                Excellent!
                • FrederikF
                  Frederik
                  Jo-ke, did my advice help you or do you need more guidance...?
                  Cheers
                  Kim Frederik
                  • jo-keJ
                    jo-ke
                    Hmm. Yes and no. First of all thank you for yout support. It helped because now I know where the problem is but i don't have a solution right now. The light theme is very complex, I will need some weeks to understand that but at first I have to turn around the faces. How can I see if a face is on the right site or not?
                    http://www.zz7.de
                    • pyrolunaP
                      pyroluna
                      turn on the 'monochrome' face style. the white ones are good, the light-blue ones are bad...
                      When this kind of stuff is important in a model, I like to make the back-color a bright red... this can be changed in the styles/edit/faces dialog.
                      • FrederikF
                        Frederik
                        My pleasure... πŸ˜„
                        Not that this is a real fix, but an easy way you can try is the following...
                        Actually you only have three point-light components, so it's quick to make adjustments...
                        1.) Click the "Open Twilight Light Editor" icon...
                        2.) In the top bar click the "From Scene" and select the first PointLight[21] component...
                        3.) Use the -tool and move the components down and away from the ceiling by 50mm...
                        4.) While the pointlight is still selected, you can adjust the "Light Strength" from the current 5 to i.e. 1...
                        5.) Repeat step 2-4 on the remaining two point-light components...
                        Under normal circumstances, I would have replaced the point lights with spot lights and in the light can placed some square emitter planes...
                        But please try the above quick adjustment, and I'm sure you'll soon adapt the light system in a render application... πŸ˜‰
                        Cheers
                        Kim Frederik
                        • jo-keJ
                          jo-ke
                          This was very usefull. Here's the result:
                          http://www.zz7.de
                          • FrederikF
                            Frederik
                            Now all you need to do is to select all back-faces, right click and select "reverse face" et voilΓ‘ they should all face front...
                            Please remember that you'll need to re-apply some materials and textures...
                            I also saw that some of your faces don't have any material and/or texture applied at all...
                            I suggest that you always apply a texture or a material to a face before rendering...
                            For white surfaces, I recommend that you adjust the RGB values to i.e. 240, 240, 240...
                            Real white (255, 255, 255) doesn't actually exist in real life and these can become too bright when you render them...
                            Cheers
                            Kim Frederik
                            • jo-keJ
                              jo-ke
                              OK, Faces are reversed.
                              Now I tried to adjust the light settings but I'm not really satisfied. I enclosed the scene for you to look for the settings.
                              umbau-tw2.skp
                              http://www.zz7.de
                              • FrederikF
                                Frederik
                                OK... Took a quick look and made a few adjustments...
                                1.) Removed some parts from the light components
                                2.) Added a square mesh and applied an Emitter material using the TWR material editor
                                3.) Adjusted the TWR spot-lights
                                (Decreased the light strength from 5.000 to 2.000... Adjusted the Falloff to 120 degree and the HotSpot to 90 degree)
                                I've attached the model below and hope you can learn from it... πŸ˜‰
                                P.S. I also moved the floor up... You can see in your render that it's below the pillars and the walls...
                                Please also be careful when placing the light components...
                                I moved them up (app. 7,2mm) in order to prevent light leaks...
                                P.P.S. Sorry about the TWR watermarks... I'm currently at the office and had to use a demo version of TWR... 😳 πŸ˜†
                                umbau-tw2-1.skp
                                Cheers
                                Kim Frederik
                                • jo-keJ
                                  jo-ke
                                  thank you so much. that helped a lot. I'm going to update the scene as soon as posible. I played a bit with the light. 2000 was to dark. I setted the light to 3000 and it looked great. Many things are clear to me now.
                                  http://www.zz7.de
                                  • N
                                    notareal
                                    Back faces are real killer for most renderers - you might get excessive reflection (like in Twilight or Kerkythea) or faces won't render all or they render black (it's all up to the engine). I don't know many render engines that can handle back faces, even in Thea they do matter, if one uses displacement or instancing brush. Making back faces to a strikingly different color, do help a lot. There is also a neat style for troubleshooting the scene.
                                    Second common problem I seen is that light sources do intersect with the geometry. Third common issue is the scene scale - when you use a physically based renderer, you must model in the correct scale.
                                    • FrederikF
                                      Frederik
                                      My pleasure... πŸ˜„
                                      πŸ˜• Eeehhh... You got me confused there for a second... πŸ˜†
                                      It's not 2000 (two thousand) but 2 point 000...
                                      A question... Can I ask you if you play games on the computer you're also using to render models with...??
                                      Reason for asking is simple... Since most of your renders seem over exposed, I tend to believe that your monitor is calibrated very dark...
                                      I've seen it before that users who are using the computer to both play games on and also render models always seem to be over exposed...
                                      Cheers
                                      Kim Frederik
                                      • jo-keJ
                                        jo-ke
                                        No I'm not gaming πŸ˜‰ but the lights in that room are really very strong. I will show a picture after the reconstruction is finshed.
                                        http://www.zz7.de
                                        • jo-keJ
                                          jo-ke
                                          here's the brand new render with perfect TWL- lights.
                                          http://www.zz7.de
                                          • jo-keJ
                                            jo-ke
                                            I just played around with the spotlights, edited the emitter and turned the direction. Now it comes pretty close to reality.
                                            reality
                                            http://www.zz7.de
                                            • 1 / 3
