🤑 30% Off | Artisan 2 on sale until April 30th Buy Now
Twilight project
42 Posts 12 Posters 4.8k Views
    jo-ke
    I used twilight render preset 10 interior+ 19h rendering ray tracing 122/10000 but I'm not happy with the result. The low preset is even better. What have I done wrong?
    http://www.zz7.de
    • O Offline
      olishea
      light strength is far too intense. remember twilight is physically accurate.
      oli
        D-space
        ...or try to tone map. Lower the exposure at the camera tab. 😉
        http://blibestmentalt.no/54981
          jo-ke
          this is the twilight render in preset 2 "low" and I like the quality more then the previous one.
          http://www.zz7.de
            dermotcoll
            Jo-ke
            I get the same problems when i render with twilight - its me not the render engine! I just need to keep practicing, looking in the forums and practicing some more to get it right. Lighting is so critical in rendering and material choices affect lighting so much that you have to marry the two together very carefully to get the perfect image. I tend to start off at very low levels of lighting and slowly increase the strength to a level where I am happy to show a client. Keep going you will get there in the end.
            When you burn your arse - you gotta sit on the blisters!!
            • F Offline
              Frederik
              Something strange going on in your scene...
              To me it looks as if you've applied an emitter material to parts of the wall and ceiling...
              Can you post the scene enabling me to take a look and revert with suggestions to improvements...??
              Cheers
              Kim Frederik
              • O Offline
                olishea
                the quality of low preset should not be the best....its pretty much the worst! interior progressive is most realistic IMO.
                why not post your model in twilight forum? would be a good challenge to improve it and you will learn a lot from feedback.
                oli
                  jo-ke
                  Thank you for your help.
                  The modell is to big to upload (39MB) but I took the walls and the ceiling with the lights in a seperarte file. I hope that helps.
                  umbau-tw1.skp
                  http://www.zz7.de
                    I have to agree that the second one looks better.
                    Is this an interior furnishings store? Looks nice.
                    • X Offline
                      xrok1
                      almost looks like an emitter material on the posts. 😕
                        jo-ke
                        Yes, that is how my interior design shop should look like after the reconstruction in july.
                        http://www.zz7.de
                          jo-ke
                          A detail of that project:
                          http://www.zz7.de
                          • F Offline
                            Frederik
                            Thanks...
                            I see some issues with your model...
                            1.) Please remember to model with faces showing front...
                            (A lot of the geometry in your model is facing back-face)
                            2.) Point light components are very big and interfear with mesh in the light component.
                            I suggest you take a look at the Lights - render times thread at the TWR forum, which should give you a lot of help creating light components...
                            Please also see the Light Components for Twilight
                            Hope this can help you improve...
                            Cheers
                            Kim Frederik
                              Excellent!
                              • F Offline
                                Frederik
                                Jo-ke, did my advice help you or do you need more guidance...?
                                Cheers
                                Kim Frederik
                                  jo-ke
                                  Hmm. Yes and no. First of all thank you for yout support. It helped because now I know where the problem is but i don't have a solution right now. The light theme is very complex, I will need some weeks to understand that but at first I have to turn around the faces. How can I see if a face is on the right site or not?
                                  http://www.zz7.de
                                    pyroluna
                                    turn on the 'monochrome' face style. the white ones are good, the light-blue ones are bad...
                                    When this kind of stuff is important in a model, I like to make the back-color a bright red... this can be changed in the styles/edit/faces dialog.
                                    • F Offline
                                      Frederik
                                      My pleasure... 😄
                                      Not that this is a real fix, but an easy way you can try is the following...
                                      Actually you only have three point-light components, so it's quick to make adjustments...
                                      1.) Click the "Open Twilight Light Editor" icon...
                                      2.) In the top bar click the "From Scene" and select the first PointLight[21] component...
                                      3.) Use the -tool and move the components down and away from the ceiling by 50mm...
                                      4.) While the pointlight is still selected, you can adjust the "Light Strength" from the current 5 to i.e. 1...
                                      5.) Repeat step 2-4 on the remaining two point-light components...
                                      Under normal circumstances, I would have replaced the point lights with spot lights and in the light can placed some square emitter planes...
                                      But please try the above quick adjustment, and I'm sure you'll soon adapt the light system in a render application... 😉
                                      Cheers
                                      Kim Frederik
                                        jo-ke
                                        This was very usefull. Here's the result:
                                        http://www.zz7.de
                                        • F Offline
                                          Frederik
                                          Now all you need to do is to select all back-faces, right click and select "reverse face" et voilá they should all face front...
                                          Please remember that you'll need to re-apply some materials and textures...
                                          I also saw that some of your faces don't have any material and/or texture applied at all...
                                          I suggest that you always apply a texture or a material to a face before rendering...
                                          For white surfaces, I recommend that you adjust the RGB values to i.e. 240, 240, 240...
                                          Real white (255, 255, 255) doesn't actually exist in real life and these can become too bright when you render them...
                                          Cheers
                                          Kim Frederik
                                          • 1 / 3
                                          1 / 3
