    All my ruby scripts suddenly died
    7 Posts 3 Posters 1.8k Views 3 Watching
    • I Offline
      ibr_remote
      Getting error when there was none before today:
      %(#4080FF)[Error Loading File clf_greeble_2.rb
      cannot convert nil into StringError Loading File clf_shape_bender_loader.rb
      cannot convert nil into StringError Loading File drop.rb
      cannot convert nil into StringError Loading File examples.rb
      cannot convert nil into StringError Loading File flattery.rb
      cannot convert nil into StringError Loading File fur_en.rb
      cannot convert nil into StringError Loading File fur_en_v1_2.rb
      cannot convert nil into StringError Loading File i.materialise.rb
      cannot convert nil into StringError Loading File IDXRenditioner.rb
      cannot convert nil into StringError Loading File jf_obj_import.rb
      cannot convert nil into StringError Loading File load_samples.rb
      cannot convert nil into StringError Loading File ObjExporter.rb
      cannot convert nil into StringError Loading File obj_importer.rb
      cannot convert nil into StringError Loading File ocean_extension.rb
      cannot convert nil into StringError Loading File offset.rb
      cannot convert nil into StringError Loading File podium_load.rb
      cannot convert nil into StringError Loading File progressbar.rb
      cannot convert nil into StringError Loading File protrude.rb
      cannot convert nil into StringError Loading File sketchlife_nc.rb
      cannot convert nil into StringError Loading File spheretool.rb
      cannot convert nil into StringError Loading File su2kt.rb
      cannot convert nil into StringError Loading File su2pov3.rb
      cannot convert nil into StringError Loading File utilities.rb
      cannot convert nil into StringError Loading File dynamiccomponents.rb
      cannot convert nil into StringError Loading File extensions.rb
      cannot convert nil into StringError Loading File langhandler.rb
      cannot convert nil into StringError Loading File make_pano_pm.rb
      cannot convert nil into StringError Loading File sandboxtools.rb
      cannot convert nil into StringError Loading File sketchup.rb
      cannot convert nil into StringError Loading File webtextures.rb
      Using Google 7.1 on a winxp sp3 machine (32-bit).
      I think I am being silly about this, but I just can't figure out what happened.
      Anyone, please help with some suggestions for troubleshooting ?
      • Chris FullmerC Offline
        Have you recently added or deleted scripts? How about the tools folder, did you move or rename anything there?
        • I Offline
          ibr_remote
          I decided to remove all the files ending in .rb from my plugins folder to a temporary folder.
          I am adding them back one by one, launching Sketchup 7 each time I add.
          I have already identified some which don't work correctly.
          Still checking as I update here.
          Will report back if anything noteworthy comes up.
          Thanks !
          • I Offline
            ibr_remote
            Identified city_gen.rb as the script which is giving my SU7.1 launch problems.
            All other ruby scripts inside my Plugins folder now working again.
              Is that one error message? (From SU startup?) Or several you compiled into a list?
              • I Offline
                ibr_remote
                My Opening Post shows the list which I got all at once, and so suddenly as well, after adding all the scripts I wanted to use, which I downloaded from the internet. That is why I couldn't identify which one threw my SU7.1 launch. Also why I had to remove all scripts from the Plugins folder, then add back one by one and launch SU each time.
                So now I am pretty sure that only city_gen.rb is causing the error message if I include it.
                I wonder, perhaps it could be a clash with some other script I have added, but I can't tell which or why.
                • I Offline
                  ibr_remote
                  Further discussion of this item will continue in the city_gen thread, thanks.
                  http://forums.sketchucation.com/viewtopic.php?f=314&t=19410&p=249727#p249727
