π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
How do I turn off hidden geometry?
This is my first crack at Layout and I haven't been able to find an answer to this anywhere. Please help! When I set up my viewports in layout, the hidden geometry from my contours is showing. It's not showing in my model in sketchup when I click on the same scene. Anyone know how I can get this to turn off in Layout? Thanks!
Make sure you're displaying the same scene with the same style in LayOut - you can use the ones in SketchUp or apply new ones in LayOut. Window->SketchUp Model and verify the scene that's chosen in the pulldown on the View tab.
b
That worked. I had modified the views somehow, but when I set them back they displayed correctly. Thanks for your help!
