    [Plugin Update] Ruby Console Pro with SketchTalk in Motion++
    28 Posts 7 Posters 173.8k Views 7 Watching
      MartinRinehart
      Zero bugs? No Mac issues?
        driven
        hi Martin,
        great work, again, the test animation runs, no flames, yet, I'll have a proper look when I get some time
        on the console [and the previous] I had to add padding to the body of the html to see the buttons, also not sure if Function keys work at all, but I may have them turned off for something else...
        %(#0040BF)[style type='text/css'
        body {
        background: #f0ecd8;
        height: 100%;
        overflow: hidden;]
        padding:10px
        I did all three, or else you get a crop line on the mac...
        I also changed the WD's to show_modal as I prefer that to hunting behind the drawing...
          MartinRinehart
          Damn the differences. On PC, they are on top by default. For me the Ruby Console, now the RCP, was always a vital modeling tool. Putting a banister on a stairway is a b* without it. I'd suggest an arrangement of a not-quite-maximized SketchUp beside peeking-out-from-behind RCP. (Big monitors are a Good Thing now that they're not prohibitively expensive.)
          Got to check into your other stuff. Thanks much for the feedback.
            MartinRinehart
            11:50 AM, Saturday morning.
            There's a new file attached to the original post. You definitely want it. It adds rotation and scale.
            Put this in your RCP and Exec it with the new version:
            n
            box o, [20,20,0], 10
            box1 = g 'box1'
            m box1, [20,20,30], 2, 20
            s box1, [0,0,0], 2, 2, 2, 5, 20
            q box1, [0,0,0], 'gb', 360, 5, 20
            m box1, [-20,-20,-30], 20, 30
            s box1, [0,0,0], 0.5, 0.5, 0.5, 20, 32
            none
            box o, [-20,-20,0], 10
            box2 = g 'box2'
            m box2, [-20,-20,30], 4, 20
            q box2, [0,0,0], 'rb', 360, 5, 18
            m box2, [40,40,-20], 25, 30
            none
            box o, [-20,20,0], 10
            box3 = g 'box3'
            m box3, [-20,20,30], 8, 20
            m box3, [40,-20,-10], 23, 27
            q box3, [0,0,0], 'rb', 360, 20, 23
            none
            box o, [20,-20,0], 10
            box4 = g 'box4'
            m box4, [20,-20,30], 12, 20
            m box4, [-20,40,0], 20, 23
            q box4, [0,0,0], 'gb', 360, 20, 25
            all
            go
              MartinRinehart
              OK, John. Got my rotate/scale done. Now back to multi-platform coding.
              body {
              height: 100%;
              overflow: hidden;]
              padding:10px
              On a PC, that gives you this:
              It's supposed to look like this:
              I can write a little JavaScript that goes something like this:
              // not real code!
              if ( platform === 'Mac' ) {
                  body.style.padding = '10px'
              What about the output and setup windows? Do they need help, too?
                driven
                Martin,
                I basically get the exact opposite to your images without the padding, so I add it to all three html's...
                and the new script,
                SU is hardly working at all when running this (8% of cpu) and it doesn't even slow down if I turn on transparency, shadows and fog...
                It's run time comes in at 31.4sec on the mac, how does that compare?
                  MartinRinehart
                  There's a Conductor singleton at the center of the animation.
                  Every second the conductor looks at his watch. He speeds up or slows down based on what he sees. That means fast and slow machines will all run at the same speed. This animation is scripted for 30 sec. so 31.4 means the conductor is doing a pretty good job.
                  That 8% number is happy-making! (Edit: I got 0 to 6%.) Boxes are low-poly. 8% means you have room for animating much bigger things. An old-fashioned steam engine, anyone?
                    MartinRinehart
                    New SketchTalk for controlling and animating the camera!
                    There are six new methods, each with two forms but they are very regular. (Before you can use this you have to go buy a folding chair with the word "Director" stenciled in very large letters on the back.)
                    Now, the things you need to know about the new functions. First, they all start with "c" for camera.
                    Second, they continue with "e" for camera eye, "f" for camera field of view or "t" for camera target. Now you know four things: start with "c" and then specify "e" for eye, "f" for field of view or "t" for target.
                    The fifth thing you need to know is that they each have an optional third letter "m" for movement. The cem() and ctm() functions move eye and target by a vector from their current location. The cfm() function adds the specified number of degrees to the current field of view. (Higher degrees==zoom out.)
                    You set the eye with ce(), just once. From then on use cem(). Similarly, you set the field of view once with cf(). From then on you change it with cfm().
                    The sixth, and last, thing you need to know is that they are like the move, scale and rotate methods. You provide a single value if you just want the thing to happen immediately. You append start and stop second specifications if you want it to be animated. (My personal most common mistake: forget to put 'go' in the script and wonder why nothing happens.)
                    The first value for ce() is a Geom::Point3d object. That is too much trouble to type, however. Just use a [r,g,b] array. Ditto for ct(). Ditto for the Geom::Vector3d you want for cem() and ctm().
                    Here's a sample. Yes, its way over the top, but it's still a sample.
                    n
                    ct [0,0,0]
                    cf   35
                    cfm  35,  2, 14
                    cfm -35, 14, 30
                    ce  [  100,  100,  0]
                    cem [    0,    0, 50],  0,  2 #  100,  100
                    cem [    0, -100, 0 ],  2,  5 #  100,    0
                    cem [    0, -100, 0 ],  5,  8 #  100, -100
                    cem [ -100,    0, 0 ],  8, 11 #    0, -100
                    cem [ -100,    0, 0 ], 11, 14 # -100, -100
                    cem [    0,  100, 0 ], 14, 17 # -100,    0
                    cem [    0,  100, 0 ], 17, 20 # -100,  100
                    cem [  100,    0, 0 ], 20, 23 #    0,  100
                    cem [  100,    0, 0 ], 23, 30 #  100,  100
                    box1 = g 'box1'
                    none
                    box2 = g 'box2'
                    none
                    box3 = g 'box3'
                    none
                    box4 = g 'box4'
                    all
                    go
                    We start with a 35 degree (default if you haven't changed it) field of view. We zoom out to 70, then back in to 35.
                    The eye takes a clockwise tour around the origin in a big square, from 100,100 to -100,-100. If you think this is easy, try it without copying my code.
                    Good luck!
                      driven
                      EDIT: this is what happens when you DON"T swap out the NEW version at top of page, it's all working now
                      %(#FF0080)[n # nil
                      ct [0,0,0] # #<NoMethodError: undefined method `ct' for Ruby_Console_Pro:Module>
                      cf 35 # #<NoMethodError: undefined method cf' for Ruby_Console_Pro:Module> cfm 35, 2, 14 # #<NoMethodError: undefined method cfm' for Ruby_Console_Pro:Module>
                      cfm -35, 14, 30 # #<NoMethodError: undefined method `cfm' for Ruby_Console_Pro:Module>
                      ce [ 100, 100, 0] # #<NoMethodError: undefined method ce' for Ruby_Console_Pro:Module> cem [ 0, 0, 50], 0, 2 # 100, 100 # #<NoMethodError: undefined method cem' for Ruby_Console_Pro:Module>
                      cem [ 0, -100, 0 ], 2, 5 # 100, 0 # #<NoMethodError: undefined method cem' for Ruby_Console_Pro:Module> cem [ 0, -100, 0 ], 5, 8 # 100, -100 # #<NoMethodError: undefined method cem' for Ruby_Console_Pro:Module>
                      cem [ -100, 0, 0 ], 8, 11 # 0, -100 # #<NoMethodError: undefined method cem' for Ruby_Console_Pro:Module> cem [ -100, 0, 0 ], 11, 14 # -100, -100 # #<NoMethodError: undefined method cem' for Ruby_Console_Pro:Module>
                      cem [ 0, 100, 0 ], 14, 17 # -100, 0 # #<NoMethodError: undefined method cem' for Ruby_Console_Pro:Module> cem [ 0, 100, 0 ], 17, 20 # -100, 100 # #<NoMethodError: undefined method cem' for Ruby_Console_Pro:Module>
                      cem [ 100, 0, 0 ], 20, 23 # 0, 100 # #<NoMethodError: undefined method cem' for Ruby_Console_Pro:Module> cem [ 100, 0, 0 ], 23, 30 # 100, 100 # #<NoMethodError: undefined method cem' for Ruby_Console_Pro:Module>]
                      I'll look closer later, but for now... yesterday's bit ran, but no new camera moves, do I need to require SketchTalk?
                        driven
                        Hi Martin,
                        I did a quick[ish] hi-poly test 1.5 million edges and it slowed down to 01:27.8 min and was pulling 92-96% on single core of CPU, but ran quite smoothly after the component switch settled down. It certainly looks cool animating grassy blocks...
                        a furred replacement hot-swapped at start-up
                        I know should do it in code, but it's just quick trick to test hi-poly performance
                          mptak
                          I so love what you are doing!!!!! How do we get this into the hands of kids so they concurrently learn both their math and animation...Perhaps so they can control undersea vehicles and tophats under the ocean!
                            MartinRinehart
                            Take it easy! Your conductor's probably becoming neurotic because he can't get the job done.
                            Seriously, its good to find the limits. We could actually model the lawn, showing it grow. Would have to do something more clever than modeling each blade separately.
                            @mptak said:
                            I so love what you are doing!!!!! How do we get this into the hands of kids ...
                            Hmmm. Good thought. First, though, a little controller thingie and we've got a really nice walk-through capability for the architects.
                              MartinRinehart
                              Video Player now included in very early stage. It pauses and resumes play.
                              It seems to argue with the timing software. I'll look into that tomorrow. I think what's needed now is a tutorial for creating walkthroughs.
                                driven
                                pause and resume work, no < << ; >> > [but you didn't say there was..]
                                the padding 'trick' doesn't work, had to redo as simply padding: 10px
                                great work, keep it coming
                                  MartinRinehart
                                  Start/End should be cake. Back, For'd? Hmmm. Timing tho is more worrisome. Did three tests, none of them using pause/resume: 22, 32 and 40 sec. (All should have been 32.)
                                  Does Video Player look OK on Mac? Had to play tricks to get it to look right in MSIE.
                                    driven
                                    the current, 'select all' file is running at 13.5 sec from pressing play until end without using pause, what are you timing?
                                    EDIT: Sometimes, I get 35>37 sec if I re-run 'without' (me) deleting the existing 4 boxes (from a previous run) other times the same thing still runs fast... It is the camera move file, but the non cam version runs at 13.5ish as well
                                    Where is the WD container generated/sized? I was going to see if I could restrict it to the button block size or add some Mac only features as an experiment, but I can't find where you hid it...
                                    bit plain, but adequate
                                      MartinRinehart
                                      Timing: 3 tests ranging from 31+ to just under 33 for a 32 second model. (Stupid me: was setting start time at go. Now setting it, correctly, when you click to start.)
                                      In the Conductor initialize() method, sketch_talk_motion_classes.rb, line 217. Then position fiddled in video_player.html in the <body> tag. This is what I want:
                                        driven
                                        although this probably isn't what you want, I've been using it to try making a MSIE/Safari controller just using text (no images)
                                        I think it looks quite good, but when trying to load from RCPro in PC SU, I kept getting bugsplats, which I put down to me and windows or the ruby,,,
                                        however, when I returned to OSX SU and tried to load from RCPro it also crashed...
                                        after a restart I loaded it with Ruby Console Editor (which I partly wrote it in) and it works fine.
                                        I then went back to PC SU and ran it from Ruby Console...
                                        There are other PC issues with the file , but it does load from Ruby Console and not RCPro...
                                        might be good for bug testing... if you want to have a look, I'll PM the file...
                                        three states in one image, click green to go, red to pausehow do you, add shadows, get rid of scrollbars, contorl the box size, and , and, and.....
                                        EDIT: Similar but different, not as nice in IE, now to try PC/SU again....ahhhhh
                                        got it similar in IE using same script for both browsers
                                          MartinRinehart
                                          Cool!
                                          <body scroll=no> MSIE only and should never be used (unless you are locked into MSIE, as we are).
                                          {overflow: hidden;} This is another one you almost never want to use, but, in the case at hand ...
                                            driven
                                            dlg.show_modal
                                            Cool!
                                            Hi Martin, I finally got it to work, still not functioning, just the WD bit using shadowed/glow fonts, which you can change colours around in code (not done yet), i.e on action, on hover, etc... I'll PM the file...
                                            dlg.show()
