    Ivy
    13 Posts 6 Posters 1.1k Views 6 Watching
    • leedeeteeL
      leedeetee
      Hi guys,
      Just wondering what you guys use to get ivy covering walls/buildings.
      Thanks. 😄
      • GaieusG
        The fur plugin?
        http://forums.sketchucation.com/viewtopic.php?p=244210#p244210
        http://forums.sketchucation.com/viewtopic.php?p=244339#p244339
        http://forums.sketchucation.com/viewtopic.php?p=244358#p244358
        http://forums.sketchucation.com/viewtopic.php?p=244461#p244461
        http://forums.sketchucation.com/viewtopic.php?p=247940#p247940
        http://forums.sketchucation.com/viewtopic.php?p=247984#p247984
        • soloS
          Fur plugin will work, try not cover whole area however, use tools on surface to define an area and populate within that for added realism.
          SU:
          rendered:
          • C
            Click Draw
            That looks awesome! Nice job as usual Pete!
            Have I mentioned how much of a laugh I get out of some of the Signatures on here!
            • numbthumbN
              numbthumb
              The fur plugin is obviously the right tool for the job.
              But somewhere in those threads posted by Gaieus, the Ivy Generator has been mentioned - which is not a convenient option, because the files are huge, and you really don´t want to use them in SU. However, they can be used in external apps, so if you are interested http://graphics.uni-konstanz.de/~luft/ivy_generator/
              Comfortably numb...
              • C
                Click Draw
                Can anyone provide any testimonial for this Ivy Generator? I have downloaded so many programs that don't live up to the expectations of the software provider. No disrespect intended. Does this work well with Sketchup or is it kind of hit and miss?
                Thanks,
                Jeff
                • numbthumbN
                  numbthumb
                  It does not work well, because the exported .obj files are way too large.
                  http://forums.sketchucation.com/viewtopic.php?f=15&t=8141&start=0&st=0&sk=t&sd=a
                  Comfortably numb...
                  • leedeeteeL
                    leedeetee
                    Wow, posted that question and then went to the pub, really pleased to see so many answers, many thanks guys, and many thanks for your comprehensive answer Solo.
                    I love this forum so much. I would like to buy you all a pint of real ale. This is my favourite at the moment ....
                    http://www.eandsbrewery.co.uk/images/nettlethrasher.jpg
                    • numbthumbN
                      numbthumb
                      Ah, fine! But I really should get my eyes checked - for a second I thought it said NESTLE 😄
                      Comfortably numb...
                      • leedeeteeL
                        leedeetee
                        Many thanks for your help again, chaps. Works a treat. 😄
                        ivy
                        • leedeeteeL
                          leedeetee
                          Just as a little aside to this, can anyone recommend a material for the top of the coping stones on the wall?
                          I've just used enlarged brick texture, but this looks naff. I couldn't find anything in CG textures but then i'm maybe just lacking in imagination.
                          • GaieusG
                            I have some other, rather irregular shape things I generally use for floor tiling (added as tegula) if you find it better but maybe even some roof tiles would do.
                            tegula.skm
                            • N
                              notareal
                              Thanks,
                              Jeff
                              Ivy Generator is good, but not for SU. Too high poly. Naturally if you import the generated ivy directly to your rendering app, it should be fine too. But then you most likely will need a external renderer, I am not sure if any renderer running in context of SU, can handle links to external files...
