    Splitting strings around 2 parameters
    18 Posts 4 Posters 1.6k Views 4 Watching
    • Chris FullmerC
      Thats awesome, thanks Dan! I'm going to play with this tonight. String parsing is not my favorite thing currently, but you guys are making it bareable.
      • Dan RathbunD
        Dan Rathbun
        Here's another example using substrings specified by range offsets:
        (I dup'd the string just in case because I'm slicing off the first unsued part.)
        def grabAPI( htstr )
          temp = htstr.dup
          temp.slice!(0..temp.index('<span class="myclass">')+21)
          return temp[0..(temp.index('</span>')-1)]
        end #
        I'm not here much anymore.
        • Chris FullmerC
          ok, this is remarkably painful, but still somehow keeping me amused. I stay up late everynight trying to figure out how to parse this text. Thanks to everyone who is chiming in.
          New question. What is this error?
          (eval):62: warning: string pattern instead of regexp; metacharacters no longer effective
          I am getting it for 2 different lines of code:
          temp_info_str_array.sub(" ", "") if temp_info_str_array[0] == 32
          and
          temp_str = str.split("***")
          In the first one I just wanted to remove the first character of the string if it is a space. And the second one seems pretty simple, just split a string at the *** delimeter. But each of these lines seems to to be throwing that error, and I'm not exactly sure what it means. But I'm guessing I'm just doing something wrong. Any ideas what it is?
            Not an error, just warning that your match pattern is not a regex.
              temp_info_str_array.gsub!(/^ /,'') should remove just the first white-space, or try
              temp_info_str_array.strip! to remove all leadings and trailing white-spaces
              str.lstrip! to remove all leading white-spaces
              str.rstrip! to remove all trailing white-spaces
              str.slice!() to remove the specified portion(s) of the string,
              e.g. str.slice1(0) removes the first character, also
              str.chomp! typically to remove the \n etc
              str.chop! to remove the last character
              etc etc there are very many 'string' methods
              • Dan RathbunD
                Dan Rathbun
                The if condition has an error, should be:
                ... if temp_info_str_array[0] == **32.chr**
                but as TIG said, temp_info_str_array.lstrip! is much easier.
                  Nope - not under Ruby 1.8.
                  "string"[0] 115 "string"[0,1] s
                  This was changed in 1.9 though.
                  • Dan RathbunD
                    Dan Rathbun
                    I stand corrected. (Confused with Pascal, a min there.)
                    I always think of Strings as Arrays of Char; and a subscript should return the character at that index.
                    So for Ruby I'd need probably do: " string"[0..0]==32.chr
                    It's just kinda weird.
                    What did they change it to?
                    EDIT: n/m I see they changed it to the way I expected it to work.
                    And added the String.ord method to return the ASCII ordinal. That's the way it should work! like:
                    " string"[0].ord==32 >> true # in ver1.9.x
                      I got caught on this the first time I tried to extract characters at indexes as well, being used to PHP. And it really is counter-intuitive the way Ruby 1.8 works.
                      • Dan RathbunD
                        Dan Rathbun
                        Agree! .. but at least they revising Ruby to correct things the way they should be.
