    How observers work ?
    18 Posts 5 Posters 2.6k Views 5 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @jim said:
      This works for me:
      class SO
      >     def onShadowInfoChanged(info, type)
      >         puts "changed;#{info.inspect};#{type.inspect}"
      >     end
      > end
      > Sketchup.active_model.shadow_info.add_observer(SO.new)
      I assume you mean when the user changes control settings in the Shadow Settings inspector dialog...
      Does it also work (ie, the callback gets called,) when a Ruby call directly modifies ShadowInfo['ShadowTime'] ??
      @jim said:
      Your code looks good to me, so I am not sure why it didn't work.
      I see two (2) issues:
      (1) Jim did not subclass from Sketchup::ShadowInfoObserver
      (2) Neither version creates a 'code controlled' reference (variable,) to the observer instance object. How can you be sure Ruby will not garbage collect the instance, if there is no reference pointing to it? (Meaning that you are relying on Ruby to maintain an anonymous reference to the object.)
      Would this be more stable?
      class SO < Sketchup;;ShadowInfoObserver
      ShadowInfoWatcher = SO.new
      Sketchup.active_model.shadow_info.add_observer(ShadowInfoWatcher)
      The other major issue is that ShadowInfo['ShadowTime'] returns an incorrect time (I posted a bug report on this.) It displays correctly in the dialog (on the time slider, but ShadowInfo['ShadowTime'] seems to return a time which is the "SliderTime" minus the user's OS system (time zone,) difference to GMT (taking Daylight Savings Time into account,) regardless of where the model's geolocation is. The same error occurs whether the model is located in Boulder, Colorado or Melbourne, Florida (My local location.) Since my computer is located at GMT-5 hours (or GMT-4 hours during daylight savings time,) the time returned by ShadowInfo['ShadowTime'] is currently (on DST,) always 4 hours less than the "SliderTime" in the Shadow Settings inspector dialog.
      I'm not here much anymore.
        Dan Rathbun
        @thomthom said:
        No need. Su doesn't care. Just implement the methods required.
        I knew that Sketchup does't (currently,) check the observer's superclass.
        But isn't it a matter of good Ruby programming practice?
        And, what if (in the future,) Google implements some built-in methods, constants, etc. in the superclass that will need to be inherited by your custom observer's subclass(es)? You'd have to go and edit and re-release all your plugins that use observer's.
          Probably is. But combining several observers into one class sure is handy at times. πŸ˜‰
            pvbuero
            This works for me:
            This works for me too. Perfect. Thanks a lot.
            I thought I was doing something basically wrong because the code above was't "my code". It was from the API documentation... strange πŸ˜’
              pvbuero
              I'm still having trouble with this observer.
              Now the event is fired whenever I change the shadowinfo settings and I see a messagebox (see below). That's fine so far.
              But I'm not able to overwrite this messagebox-method with my own method.
              I wrote the following:
                      UI.messagebox("test the observer")
              ...but still the same message as shown above appears..
              What have I done wrong ?
              Thanks for your help...
              MD
                Dan Rathbun
                Jim's version is still being loaded, probably AFTER your version, so your's gets redefined by his version.
                Also it's best to restart Sketchup for testing. (Otherwise you have to detatch the old observer instance, redefine the variable to point to a new instance of your new observer class, and attach the new observer instance.)
                  pvbuero
                  Hello Dan,
                  I have restarted sketchup and I've no idea where Jim's version should come from ? I deleted it and replaced it by my code...
                  Thanks MD
                    Have you tried giving it a unique name?
                    Or even better wrap your code into a unique module to avoid namespace collision.
                      Dan Rathbun
                      It has to come froma script file in the Plugins folder.
                      if you write a script that opens the Console first thing (name it !!!first.rb or something with exclamtion points so it gets loaded first,) and then in that set
                      $VERBOSE=true
                      you will see warnings issued to the Console whenever a method is overwritten.
                      The problems you have are because you have too many things in the Plugins folder.
                      This is why ThomThom suggested MOST scripts should be in subfolders (and loaded with a loader script.)
                      The easiest way to test is to rename the Plugins folder to something else "_Plugins"
                      and make a new Plugins folder.
                      Put the script under test in the new folder and load Sketchup. Test it.
                      If it works then there is a problem script in the "real" Plugins folder.
                        pvbuero
                        Thanks a lot. You're answers are a great help for me as an absolute beginner... πŸ’­
                        ... I'll try your suggestions this evening and give you a feedback.
                          pvbuero
                          Hello,
                          thanks to Dans suggestion πŸ‘ I solved the problem. There was a second testing script which obviously overwrote the script I was working on. I deleted it and everything worked as I intended.
                          Thanks to all of you for your help.
                          MD
                            Kind of seem to be by design: http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&start=150#p171636
