    Shape Bender not creating a final entity
    2 Posts 2 Posters 343 Views 2 Watching
      jdh3777
      Hi. I'm having an issue with Shape bender completing its process. Here's what I'm doing followed by the problem:
      1. Select a group
      2. Activate Shape Bender
      3. Select a straight line on the red axis which brings up "start" and "end" tags
      4. Select the curve -- the grids appears and the process bar begins ticking off the time until completed at the bottom of page
      5. The bent object appears properly around the curved line as a green outline preview bend
      6. Problem: the green outline doesn't become an actual 3D shape. If I click on the screen, the green outline disappears.
      I am I doing something wrong?
      Thanks you!!
      • Chris FullmerC
        Hi Jeff, once you get the previes shape looking how you want, just press enter to finalize the process. That will then make a final shape. Hope that helps,
