    Same Colors not equal?
    11 Posts 5 Posters 768 Views 5 Watching
      There seems to be no [working] method for '==' for comparing Colors: but c1.to_s==c2.to_s does return true if they have the same rgb values...
      • Chris FullmerC
        A color is a Sketchup::Color object. So what you've done there is just compare the two objects, which are different, regardless of what their actual color is. It would be nice if Google fixed that. πŸ‘
          As well as comparing the Color turned into strings c1.to_s==c2.to_s to get true/false, you could also compare the rgb values
          c1.red==c2.red c1.green==c2.green c1.blue==c2.blue
          will all return true if the three color values are all equal...
          As Chris says the Colors are two different objects so they aren't equal so == returns false unless c1 and c2 refer to the same Color object !
          • C
            cjthompson
            c1.to_a == c2.to_a works too.
              So there are lots of ways of checking if two Colors are equal, BUT NOT the obvious c1==c2 !
              • Chris FullmerC
                Does converting to an array work faster than to string I wonder? As an array, are the RGB values still left as integers? That seems like it would be a faster comparison.
                  Also c1.to_i==c2.to_i works, as the color is converted to a single integer format - that might be even quicker ?
                  πŸ˜•
                    Jim
                    Ah, of course.
                    The "Ruby way" would be to define the <=> operator for the Color class, and then mix in Comparable.
                      Jim
                      Then again, what does it mean for a Color to be greater than another? Nevermind...
                      Equality is all that's needed. I think the .to_i comparison makes the most sense for clarity.
                        Yea, always avoid comparing strings.
                        Such a shame that they've not added a proper comparison method for all objects.
