Very Odd Bug
Edit: Problem solved. Thank you for stopping by to lend a hand.
Stupid Programmer Trick # 38,298,987,234
The first component to start moving was shorted by one second. Had nothing to do with the quadrant.
In this script:
load( Sketchup.find_support_file('sketch_talk.rb', 'Plugins/ruby_console_pro/') ) n box o, [20,20,0], 10 box1 = g 'box1' m box1, [20,20,30], 0, 20 none box o, [-20,-20,0], 10 box2 = g 'box2' m box2, [-20,-20,30], 4, 20 none box o, [-20,20,0], 10 box3 = g 'box3' m box3, [-20,20,30], 8, 20 none box o, [20,-20,0], 10 box4 = g 'box4' m box4, [20,-20,30], 12, 20 none gofour boxes are created in the four rg quadrants. Translating SketchTalk to English, that's:
n # select all, delete (quickie File/New) box o, [20,20,0], 10 # Rectangle, origin to [20,20,0], PushPull up 10 box1 = g 'box1' # Create ComponentInstance named 'box1' m box1, [20,20,30], 0, 20 # schedule a future move during seconds 1 through 19 none # unselect everything ... go # begin the scheduled movesEach box schedules a move, 20 units out into its quadrant and 30 units up the blue axis. They move, which is great.
But the box in the positive r, positive g quadrant doesn't quite do a full move. The move code is quite simple-minded. It divides the move vector into distance per frame. It has nothing to do with quadrants.
def create_amcis() # convert registrants into actionable, movable CIs for reg in @@registrants duration = reg.stop - reg.start frames = duration * $sketch_talk_fps r = reg.vector[0].to_f() / frames g = reg.vector[1].to_f() / frames b = reg.vector[2].to_f() / frames reg.actionable = Con_Amci.new( reg, r, g, b ) end # registrant loop end # of create_amcis()The move vector is [20,20,30]. Actual move is speed-dependent:
5 sec. [16,16,24]
10 sec. [18,18,27]
20 sec. [19,19,28.5]
40 sec. [19.5,19.5,29.25]The other three boxes animate happily to a full [20,20,30]. Shuffling the box order doesn't change the behavior. The box in the positive red, positive green quadrant doesn't do a full move.
Glad we helped
