    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 76.5k Views 44 Watching
      A very "rough" grass & ivy combo (Twilight Render until I came home from my "Corner Bar"...)
      Model by "Kephalos", ivy by Majid, background (#4) by Olishea (thanks all).
      • F Offline
        fymoro
        Really nice mood in your render Gaieus, congrats... 😉
        http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
          Well, I only added the grass, ivy and background...
            @olishea said:
            ...rendered with twilights "render all hidden layers"...
            How do you do that, Oli?
            I tried this way:
            Hid the grass layer (was choking SU very much) and in Twilight I made sure that the grass layer was checked to render. But it did NOT render that layer.
            Then I made another scene where the grass layer was turned ON in SU but navigated in another scene where it was not. I made sure to set the scene containing the grass layer on, when in Twilight and also selected the grass layer to render but it does not render again.
            • daleD Offline
              dale
              A few too many plants showing up, so I thought I'd introduce something to keep them in check. (ants by museum maker)
              Amazingly stable considering the amount of poly's.
              • F Offline
                fymoro
                Hey Dale very scary !!! 😄
                  A dusky (or if you want, "Twilight") scene... Still vegetation, but the ants are also cool!
                  Still Kephalos' model, Majid's ivy and Oli's background.
                    Rico91
                    very nice Plugin! 😛
                    http://lh6.ggpht.com/_rMc47FEl0fA/S-hEjsJPg5I/AAAAAAAAB-c/pKLzFOjdoTY/R8_P.47.jpg
                    [img:y90a5vdg]http://lh5.ggpht.com/_rMc47FEl0fA/Sro-DozMGPI/AAAAAAAABwU/zZsLbdpwWAs/forum_onderschrift_r3d_30pxh.jpg[/img:y90a5vdg] [url:y90a5vdg]http://www.R3Design.nl[/url:y90a5vdg]
                      Rico91
                      number 2 😄
                      http://lh4.ggpht.com/_rMc47FEl0fA/S-hiucGiGNI/AAAAAAAAB-k/lBDp_IVwmrQ/R8_P.49.jpg
                        Totally missed the possibility to "Make a Component instance"
                        (a component must be first in the model for appear on the fur's list) 😳
                        you can also replace selected by a component 😒
                        http://forums.sketchucation.com/download/file.php?id=47832
                          KarinaGM
                          rico, very nice fury car.
                          How did you achieve that soft look?
                          My attempts look sharp
                          **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                          -Benjamín Franklin.**
                          • olisheaO Offline
                            olishea
                            gaieus: if you have a hidden layer within a component just right click on the component (thats why i left a line in the component; so you can still click on it), go to twilight>render all hidden layers in all components. look at fletch's 2000 teapots example in twilight resources. or i will just post the skippy later if you are still having trouble? i never went through the twilight layers dialogue....i only right clicked to access the twilight context menu.
                            i really can not simplify more than that!
                            these fur images are amazing!! keep em up!
                            the audi looks fantastic! and nektares: nice bed head!
                            links for twilight "leveraging components":
                            http://twilightrender.com/phpBB3/viewtopic.php?f=26&t=531
                            http://twilightrender.com/phpBB3/viewtopic.php?f=25&t=1611
                            oli
                              Rico91
                              thnx for reply!
                              i rendered with hypershot, but i don't changed the material.
                              it's only the quality of hypershot..
                                @olishea said:
                                gaieus: if you have a hidden layer within a component just right click on the component (thats why i left a line in the component; so you can still click on it), go to twilight>render all hidden layers in all components...
                                Thanks Oli, I did not do it that way but hid all the components. I will try this way, too (although it "seemed" to be intuitive as I tried but then it seems I was mistaken about what those settings mean - see screenshot).
                                IMO if it worked this way as well, it would be even easier to handle things in SU (as maybe hundreds of thousands of single lines representing grass can already slow SU down).
                                But of course, this should belong to the Twilight Forums so will go on posting there as I do not want to push this topic off too much (sorry).
                                • olisheaO Offline
                                  olishea
                                  lol tell me about it! it only works when you have a few! best to just make all the grass hidden with no lines! 😆
                                  oli
                                  • olisheaO Offline
                                    olishea
                                    had some time to play!
                                    sketchup view
                                    http://i654.photobucket.com/albums/uu269/olishea/Picture30.png
                                    all the grass hidden replaced with line 'proxies'....not very feasible on a large model is it gaieus?!! haha 😛
                                    http://i654.photobucket.com/albums/uu269/olishea/Picture32.png
                                    twilight render
                                    http://i654.photobucket.com/albums/uu269/olishea/2-6.jpg
                                    oli
                                    • olisheaO Offline
                                      olishea
                                      seriously it gets better and better
                                      podium render
                                      http://i654.photobucket.com/albums/uu269/olishea/20100511155459_5m12s.jpg
                                      2 minute sketchup scene. i love this plugin. combined with free hand tool its fantastic...no more ivy generator!
                                      http://i654.photobucket.com/albums/uu269/olishea/Picture33.png
                                      oli
                                      • soloS Offline
                                        Hairy hare.
                                        • soloS Offline
                                          Fun plugin.
                                          • F Offline
                                            fymoro
                                            🤣 You two guys have smoked the carpet or what ?... 😆
                                            This plugin is one of the best for me... 😉
                                            • 3 / 9
