    Disabling snap points... my dream.
    12 Posts 10 Posters 5.4k Views 10 Watching
    • honoluludesktopH
      honoluludesktop
      Would be nice as a option to select off when tracing an outline around a image.
        agamemnus
        Dave R... ok, that wasn't what I meant. It's kind of difficult to explain succinctly.
        Say you have one line. And then another line right after it in going in the same direction. Physically they can be replaced by a longer line equal to the length of the two shorter lines. Sometimes I make these line breaks in my program. I don't want Sketchup doing inference-snapping on the line segments some of the time.
        • C
          chrisjk
          You can of course remove the break. The weld plugin would do that. Also if two lines are themselves in a straight line, constructing and then erasing a small line at the break, will "heal" the break.
          • fredo6F
            @agamemnus said:
            Is there any way anyone can think of to disable those pesky snap points?
            You may want to trty the FreeHand tool of ToolsOnSurface.
            It includes a polyline draw tool without inference (working on surface or without surface). You may however punctually use inferences if you need to.
            • P
              Persil
              I am watching with interest. Have the same problem tracing stations of a hull. I had great hopes by downloading the splines, but those snap points are still present. Someone has posted the model of the Titanic I wonder how he has overcome this problem. Ship and boat lines are not french curves, there must be a solution, the freehand is not the solution.
              Fred
              • Chris FullmerC
                Agreed. I'm wondering if you have a mouse with a scroll wheel on it? If not, go get one. Its an absolute must have for working in SketchUp.
                  agamemnus
                  Thanks, good workarounds.
                  • ken28875K
                    ken28875
                    I agree with Chis, the scroll wheel is very useful to zoom in/out. However, to work faster and more efficiently, in combination with the scroll wheel, you should buy a Space Navigator/3D mouse by 3D Connexion. http://www.3dconnexion.com/
                    I use the 3D mouse everyday and would not imagine modeling in Sketchup without it. This is a really good investment if you use Sketchup all t he time and have deadlines.
                    Best,
                    _KN
                    Follow Your Dreams.
                    • P
                      Persil
                      Well. guess what some have a scroll mouse. I don't like to make smart comments however have you traced curved lines in 2 mm increments try for yourself even at a large scale the jumping of the lines are very annoying.If I have overlooked anything correct me. I think the comment about the scroll mouse was a valid comment but the person who has asked that question first sounded like he knows what he is doing.
                        alz
                        Has anyone found a way to have certain models not affected by inference-snapping?
                        I'm finding a couple situations where I wish the inference-snapping would ignore a model in the scene. For example, I have a large sub-divided plane and I'm trying to extrude a cube in the foreground, the motion keeps snapping at sub-division way off in the background.
                        With your input, this post could be even better šŸ’—
