    World of Houses design challenge by i.materialise
    extensions
    23 Posts 8 Posters 42.9k Views 8 Watching
      jaxcoffee
      @i.materialise said:
      @jaxcoffee said:
      When you say "House" does that exclude any commercial building, like say a library?
      yes
      So residential dwellings are the only buildings that qualify for this contest? Just wanting to be clear on this. Is it because there are limitations to the program? Feel free to explain better. Please!
      You wrote "exclude" and I read "include." Sorry about that. You are welcome to design and submit any type of building commercial or non commercial, airports, libraries, churches, really anything as long as your submission resembles a building.
      Got it! Crystal clear. Thank you so much for your response.
        KXI System
        May I ask a hint for the 3D "surprise"?
        Getting the perfect sig is hard...
        Google it!
          tim
          @tim said:
          Sadly, since there is no OS X version of the plugin, I can't enter. 😐
          Dear Tim,
          We are currently working on your problem. Since there's no plugin for OS X, and you would like to take part in this challenge, we will create a brief manual for OS X users, so you and other Mac users could take part in our challenge. We hope it will work for you.
          Jolly decent of you - I look forward to giving it a go.
          • I Offline
            idraft
            Could you please expand on your tips and tricks.
            EG: Should we..with our models do the following;
            a) explode all groups,
            b) remove section planes & delete hidden lines,
            c) unhide all and delete unwanted,
            d) remove all trees, people and models and import only those in the 3D warehouse ' iMaterials link'??
            Purhaps you could add or remove as necessary.
            • I Offline
              i.materialise
              @idraft said:
              idraft,
              a, b, c are all optional, it is up to you. We do not ask you guys to make any specific changes to your models, except using our plugin to get customization and dimensions right.
              regarding the "d," the models in our 3D warehouse are all 3D printer ready, meaning that if you are to use them, they will be 3D printed exactly as they appear in SketchUp. If you decide to use your own models, and should your entry win, we will be preparing the file to 3D printing and some alterations might be necessary to the parts of the model. For example in case the part is too thin. Regarding your question, feel free to use any model and don't limit yourself to our 3D warehouse.
              i.materialise team
              Join us on facebook
              • I Offline
                i.materialise
                If I were to tell you, it would spoil the surprise part 😄
                i.materialise team
                Join us on facebook
                • pugz1983P Offline
                  pugz1983
                  Hi Guys From I Materialise,
                  I have a question. I've been working on a model of a house and Its nearly finnished. I was thinking about sending this model as a contribution to the challenge. Iwas just wondering if there are any limitations. The design consists of a boxed shape design, but the walls are covered with woodstrips( 5cm/5cm ) with a spacing of about 4/5 cm between them. The strips are all connected so there are no floating geometry. But I think the woodstrips may be to small for 3d printing.
                  Greetz,
                  Twan
                  • I Offline
                    i.materialise
                    Greetz,
                    Twan
                    Hello Twan,
                    It might be the case that some of the parts of your design might be too small for 3D printing. Objects smaller then 1mmx1mm are normally too small. You can use our plugin to scale your model and then check the sizes of smaller elements of your model.
                    Good luck on the challenge. If you have any additional questions, feel free to leave a reply, we'll be happy to help.
                    i.materialise team
                    i.materialise team
                    Join us on facebook
                    • I Offline
                      i.materialise
                      Guys, a small announcement:
                      We decided to extend the deadline for the model submission stage of our challenge until May 24th. The manual for Mac users is also on the way and will be available in the beginning of the next week.
                      i.materialise team
                      i.materialise team
                      Join us on facebook
                        arjunmax09
                        thanks sir/madam!!!
                        was it because of my exams if i'm not wrong??
                        when you fail at something....you haven't really failed...you've found one way the thing will not work out
                        • I Offline
                          i.materialise
                          For Mac users the manual is available here.
                          i.materialise team
                          Join us on facebook
                            tim
                            Small problem - that document refers me to a manual which seems to be included only in the Windows based wizard….
                            • I Offline
                              i.materialise
                              Dear Tim,
                              The document is in PDF format, you will probably need to install Adobe Reader to be able to view the file.
                              Let us know if you need additional support.
                              Alex
                              i.materialise team
                              Join us on facebook
                                tim
                                Dear Tim,
                                Alex
                                No problems at all reading a PDF (this is a Mac, after all), but on page 2, section 5 it refers us back to your website (http://i.materialise.com/Tool/CreateYourArchitecturalModel) which in the section 'Design Tips' says "Please check our manual (enclosed in the wizard) for design tips". Of course, there is the cunningly hidden part 2 of the "How does this work" section where I should have noticed a download for the actual manual. 😳
                                • I Offline
                                  i.materialise
                                  The winners are in. Take a look at the 3D printed models on our blog or facebook album.
                                  i.materialise team
                                  Join us on facebook
