    SketchUp 7 slow on the G5 Power PC
    4 Posts 2 Posters 756 Views 2 Watching
      joelreider
      I have a dual 2.3 GHz PowerPC G5 with 4 GB RAM. I just installed SketchUp 7 to work with some new files and it is impossibly slow. The files are large (30 - 40MB), but even in tiny files, the beachball just keeps spinning and spinning. How can I speed it up? Is it really only meant to run on the Intel Mac?
      Thanks.
      • jeff hammondJ
        i regularly run SU on a 1.33 G4 powerbook and it does pretty good.. certain scripts take a little longer to run and navigating will bog down earlier than on my more powerful computers but it's definitely not impossibly slow.
        more likely than not, it's the files you're using
        have you used the same files on a different computer and seen an improvement?
        edit.. oh wait- even on tiny files? what are you trying to do when the beach ball shows up?
          joelreider
          Jeff,
          I've purged unused but this doesn't help. Anything I do is very slow: selecting, moving objects, changing my perspective, copy/paste, etc. Even closing a file takes a while.
          • jeff hammondJ
            it's really hard to say what the problem is as i haven't experienced it even though i run SU on inferior ppc hardware..
            fwiw, SU was originally written on pre intel macs so no, it's not only meant to run on intel macs.
