    Req:free form shapes
    4 Posts 3 Posters 283 Views 3 Watching
    • Y Offline
      yahia mito
      first of all i'd like to thank all of u for this magnificent forum
      i was modeling an exterior which has some organic curvy voids on it ๐Ÿ˜
      i've tried tools on surface plugin
      or even extruding curvy faces ... but i didn't get the result i hope ๐Ÿ˜ฎ
      my problem is kinda like this :
      @entersketchup said:
      http://forums.sketchucation.com/viewtopic.php?f=79&t=27856
      Question: How to model a random perforated surface...
      my question is :
      if i draw the shape i want on 2D software ( Cad or Sketchup )
      and i want to apply it on this curvy surfece to creat a void that has the same shape but on a curvy 3D surface
      http://img97.imageshack.us/img97/5148/capturebj.jpg
      i'm asking for ur help " my project's discussion will be after tomorrow " ๐Ÿ˜’
      p.s
      sorry for my bad english ๐Ÿ˜Ž
        I think the easiest and quickest solution would be to use an image that has transparent areas in it. Certainly this only works if the object you want to perforate has no thickness.
        • Y Offline
          yahia mito
          thanks Gaieus
          but there is a simple solution i could think of
          i don't know if it was right or wrong so u could tell me ๐Ÿ’š
          what if i've used any tool to unfold this surface ( like unwrap in 3d max ) and then applied the 2D surface that has my draw of organic lines on it and extrude it with the value equals the thikniss of sorface
          but the problem is
          what plugin i could use ?
          how to refold this surface as it was before using ( unfold ) ?
          • soloS Offline
            Unfold.
            Plugin: Unfold Tool
            This SketchUp script assists the user in flattening, or unfolding, 3d objects onto a 2d plane. Installation Download unfoldtool.zip . M...
            (sketchuptips.blogspot.com)
