    Need help to creat this chair for 3d model! [TUTORIAL]
    26 Posts 12 Posters 5.9k Views 12 Watching
    • soloS Offline
      3 views even better.
      looks easy enough.
      • Alan FraserA Offline
        Alan Fraser
        It seems to be this one. No dims, so I guess 18" for the seat height wouldn't be far wrong. It's the Loop Chair by Infinit.
        3D Figures
        • soloS Offline
          probably not accurate but anyway, I used a basic proxy (half model symmetry modeling), subdivided with 2 iriterations, then adjusted form using FFD, used JPP for thickness subdivided with another 2 iriterations and duplicated flipped and joined.
            @solo said:
            used TOS for thickness
            can you explain a little more on this step what you used in TOS? Can't figure it out? But nice tutorial, SDS used correctly give outstanding results, wish I understood how best to build proxies. Practice, practice, practice I suppose.
            Rich
            • N Offline
              nguhait
              Yes it is the loop 3d chair from Infiniti..heres another pictures of the front.
              • N Offline
                nguhait
                Heres more picture of the chair!
                Solo: is that in sketchup or can you upload that to sketchup so i can download it?
                http://www.infinitidesign.it/ita/loop3dvinterio.php
                • soloS Offline
                  Good spot Rich, I used JPP, thanks for correcting me.
                  Hai, yes it's Sketchup, but now after seeing the front I realise mine is not correct, when I get some time later I'll give it another go and post once I finish.
                  • N Offline
                    nguhait
                    ok sounds good...
                    • soloS Offline
                      Okay, here is the seat part only, the legs should be easy for you I believe.
                      First a low-ish poly version:
                      chairlower poly.skp
                      • soloS Offline
                        And if you want it higher poly (I think it's better) then here is it:
                        http://dl.dropbox.com/u/1129899/cube%20neon.skp
                        • N Offline
                          nguhait
                          Yeahhh! Thanks alot Solo i can do the rest from here..
                          • olisheaO Offline
                            olishea
                            Solo that's pretty sweet man, well done πŸ‘
                            "king proxy"
                            oli
                            • dermotcollD Offline
                              dermotcoll
                              Sweet little model - you make it look so easy - Git! πŸ˜‰
                              When you burn your arse - you gotta sit on the blisters!!
                                markbowen
                                Unfortunately that's the wrong link 😞
                                That said, thanks for sharing the chair anyway that's really really kind. Would love to see how you create this sort of thing in SU though. For that matter would just love to know how someone / anyone can take any ordinary everyday object and just know which tools to use to re-create it. Some of the organic shaped things just do my head in as I've just no idea of where to start with them. Any tutorials anyone could point me to would be greatly appreciated.
                                Best wishes,
                                Mark
                                  Strangely that link works for me?????????
                                  As for understanding how members achieve end results for certain models it's best to post where you're having difficulty with a particular model. Most members around here will offer suggestion on how best to approach a particular form/plugin/technique. It's the most efficient way to overcome issues and you'll be surprised at how quickly you'll become proficient at approaching certain issues.
                                  Post your exact problem with modelling the object and the solution will follow....... πŸ‘
                                    markbowen
                                    Hmm it works for me too but I thought it was supposed to be of a higher poly chair and not the neon cube? πŸ˜‰
                                    Well with me that would be the very beginning phase πŸ˜‰
                                    Well as mentioned above I wouldn't even know where to start on something like this. Even sometimes when I take a look at what looks like a simple object in my house I just look at it for hours and hours and wonder how something like that would be created.
                                    I'll have to get something and post to see how to make it. I really wish I could just look at an object and see in my mind which tools to use. The main problem is probably that I don't really know what all the plugins do at the moment and so never know the best one to use.
                                    Best wishes,
                                    Mark
                                    • soloS Offline
                                      http://dl.dropbox.com/u/1129899/chair%20high%20poly.skp
                                      I messed up, here is the link, you are right that's the cube model.
                                      I'm getting too old for this internet thing, It's just a fad. πŸ’š
                                        markbowen
                                        Hiya,
                                        @solo said:
                                        Dropbox - 404
                                        (dl.dropbox.com)
                                        That's really kind of you to share that model, thank you. I had a bit of a problem with painting it in SU though. Not too sure why but when I paint it with a colour then the model still stays grey. I reckon maybe I have some style setting affecting that though maybe?
                                        I would absolutely love to see a vide on how you create these kinds of things. Organic objects just do my head in at the moment. I'd love to be able to take some household object and just know instinctively which tool / plugin to use to model it with.
                                        Best wishes,
                                        Mark
                                        • RichardR Offline
                                          Richard
                                          Pete I've heard you say that a few times lately, what's going on mate? Sensing a big 0's birthday coming up or a bum hip or something. Mind you I know myself how little some little things can make one feel a bit older!
                                          Hey bit of mastery on the chair shell mate!
                                          [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                          • F Offline
                                            ferrosoa
                                            Hi, can i ask you, where i find feature to up poly in sketchup. Its plugin? ... Something like meshsmooth or turbosmooth in 3ds
