    Req:SU to Zbrush Exporter
    4 Posts 4 Posters 839 Views 4 Watching
      sus4
      SU moderings wall
      http://imgur.com/IKIYR.jpg
      .obj Export
      http://imgur.com/2VdrD.jpg
      ZBrush import
      http://imgur.com/Y9Npp.jpg
      OMG
      Need zbrush Exporter... πŸŽ‰
        Have you the original skp file?
        You have some parameters to input inside Zbrush before the obj importation, and after the importation
        You must also maybe use the last obj plug exportation by TIG
        • jason_marantoJ Offline
          jason_maranto
          The real problems will be when you try to subdivide that in Zbrush...
          Reverse faces -- what you are seeing is the back faces. Also maybe need to weld...
          Best,
          Jason.
            View your skp with hidden geometry 'on' and in mono-chrome mode in a style where back faces have a distinct color compared to the front.
            Then you can see if there are any reversed faces - reverse them to match the rest [I recommend that you make a shortcut key to 'reverse faces' for speed].
            Now view it in texture-mode, you might find some faces aren't colored - fix those...
            You might also have some unneeded hidden.smoothed edges - erase those if the faces stay OK...
            Only now export etc...
            πŸ˜•
