    Use PickHelper to find nested Instances?
    16 Posts 3 Posters 1.5k Views 3 Watching
      Jim
      Here's the scenario.
      There is a "Joint" component made of only edges. Using a Tool, I need to be able to get the "global" position of its origin.
      I know how to handle the nested trasnformations, but I thought the PickHelper would give me a list of the nested instances in order, which I can then use for the calculation.
      cubetest.skp
        Jim
        This is where I think .all_picked is bugged out - it returns an array of the same Instance; where I think it ought to return an array of the nested instances.
        I think .all_picked is returning the correct number of things - it appears to send a ray through the point and picks up the entities both heading into the nest and also picks them up in reverse order as it's exiting the nest.
        • TIGT Online
          array = pickhelper.path_at(pickhelper.count)
            .all_picked return an array of entities containing the top level entity. You must use .leaf_at to get the deepest item.
            When you use .all_picked after picking a point it'll return all top level entities within the given aperture. If you click on an edge attached to two faces it'll return an array containing the face and edges.
            If the faces and edges are contained within a group/component - then you get an array of the top level entity, which would be the group/component. You then need to use the count of the picked number of entities and traverse the tree of entities picked.
            ph = view.pick_helper
            ph.init(x, y, 5) # (!) Allow user to customize pick aperture
            puts "Pick;"
            ph.do_pick x,y
            p ph.all_picked
            puts "> Paths;"
            for i in 1..ph.count
              p ph.path_at(i)
            Console output from this code after clicking a corner of a cube inside a group:
            ` Pick:
            [#Sketchup::ComponentInstance:0x118a8a18, #Sketchup::ComponentInstance:0x118a8a18, #Sketchup::ComponentInstance:0x118a8a18, #Sketchup::ComponentInstance:0x118a8a18, #Sketchup::ComponentInstance:0x118a8a18, #Sketchup::ComponentInstance:0x118a8a18]
            Paths:
            [#Sketchup::ComponentInstance:0x118a8a18, #Sketchup::Edge:0x117a98b0]
            [#Sketchup::ComponentInstance:0x118a8a18, #Sketchup::Face:0x117a9838]
            [#Sketchup::ComponentInstance:0x118a8a18, #Sketchup::Edge:0x117a97c0]
            [#Sketchup::ComponentInstance:0x118a8a18, #Sketchup::Face:0x117a9748]
            [#Sketchup::ComponentInstance:0x118a8a18, #Sketchup::Face:0x117a96d0]`
              Jim
              Ok, so I need to go through each path until I find the Instance I am looking for?
              If I do that in x-ray mode, it works. But it fails when I turn x-ray off.
                I believe so. Unless there is a shortcut here that I've missed.
                something like
                for i in 0...(ph.count)
                  if ph.path_at(i).include?(instance)
                    path = ph.path_at(i)
                    break
                The output is different?
                The sample output I posted in previous post was with X-Ray off... Not tried with it on.
                (Update with correct indexed.)
                  The docs are outright wrong about the index for the *_at methods. The index does not start at 1 - it start at 0.
                    The only difference I see with x-ray mode is that it picks more elements.
                      My test code
                      tt_picktest.rb
                        Jim
                        Yes, I consider it a failure that I (so far) have not been able to pick an Instance that is nested in another Instance unless X-ray is enabled.
                        It must be possible?
                          So, you have a reference to a ComponentInstance_ And you want to sniff it out using the pickhelper?
                          Maybe just some typo bug in your code?
