    Setting camera eye
    8 Posts 4 Posters 409 Views 4 Watching
      Brett McAllister
      Hi there
      I want to set my camera eye at the equivalent of zoom extents, would anyone know what array values to use?
      By the way superb forum, have learnt so much through the people who post here.
      Regards
      Brett
        You can directly invoke zoom_extents with a send_action see http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#send_action ( Sketchup.send_action("viewZoomExtents:")). You could then reverse engineer the Sketchup.active_model.active_view.camera.eye from that if you still want it ?
          View.zoom_extents
          http://code.google.com/apis/sketchup/docs/ourdoc/view.html#zoom_extents
          The zoom_extents method is used to zoom to the extents about the entire model, as if the user has selected the zoom extents command from the menu.
          From the docs it seem to be identical to View.zoom... Either the methods are aliases or the docs is wrong about one of these methods...
            model.active_view.zoom_extents zooms to the model's extents
            model.active_view.zoom(2.0) zooms in x2
            model.active_view.zoom(0.5) zooms out x2
            model.active_view.zoom(model.selection.to_a) zooms to the extents of the selection
            model.active_view.zoom([group1,group2]) zooms to the extents of the two groups specified in the array
            model.active_view.zoom(group) zooms to the extents of the group or one entity
            πŸ€“
              So the arguments that the docs claim for .zoom_extent is incorrect?
                The linked doc has NO arguments for view.zoom_extents in the text - it only gives them for view.zoom() - where it's either a float for the amount to zoom in/out >1.0/<1.0, OR an entity or an array of entities to zoom to the extents of...
                The wrong examples are given for zoom_extents - they have been copied down from view.zoom in error !!!
                πŸ˜•
                  I was looking at the example - didn't notice the example under View.zoom_extents said View.zoom.
                  • snicoloS Offline
                    snicolo
                    Should be fixed soon, I have submitted the change and it needs to be picked up by the servers.
                    thanks for the report.
                    Simone.
                    Simone Nicolo
                    QA Manager
                    http://www.sketchup.com
