    [Request] Helix following curves
    8 Posts 4 Posters 1.9k Views 4 Watching
    • ken28875K Offline
      ken28875
      Hi guys,
      I don't think there is a plugin like this yet. It seems like a tough one to write.
      I would appreciate if someone could come up with a plugin that create an helix that follows a curve or even another helix.
      The best example is a phone cord.
      Thank you very much for you help,
      _KN
      http://i593.photobucket.com/albums/tt12/ken28875/misc images/phone_cords.jpg
      http://i593.photobucket.com/albums/tt12/ken28875/misc images/coiled_cords.jpg
      http://i593.photobucket.com/albums/tt12/ken28875/misc images/coilcord.jpg
      Follow Your Dreams.
        There are several Helix tools available.
        Make a helix... then use something like my EEbyFace, draw a small circle/oval for the cross section and use that to make the extruded form...
        πŸ’­
        • ken28875K Offline
          ken28875
          πŸ’­
          Hi TIG,
          Well, it's actually more complicated than that. As you see in the phone cords samples or the ones below, the helix should follow a curves.
          I used a helix plugin, your EEbyFace and Chris Fullmer's component stringer. The one I did is not perfect as the ends of the helix are not connected.
          I'd like to see a plugin that will make the helix follow the curve in a cleaner smoother way.
          _KN
          http://i593.photobucket.com/albums/tt12/ken28875/misc images/helix_following_curve_01.jpg
          http://i593.photobucket.com/albums/tt12/ken28875/misc images/helix_following_curve_02.jpg
          http://i593.photobucket.com/albums/tt12/ken28875/misc images/helix_following_curve_03.jpg
          Follow Your Dreams.
            Pipe along path by Tig πŸ˜‰
            Followme&Rotate by Wikii
            Followme and keep by Wikii
            1001bit
            • Chris FullmerC Offline
              I've done it like this with good success:
              Make a long helix.
              Then use shapebender to bend the helix to the desired curvy/bendyness.
              Then apply a face to the end of the helix and do a simple follow me along the helix. Then you will get the curved helix AND a perfect round cord shape.
              I think I had posted some pics as an example of this somewhere before. If I find it, I'll post it again here.
                Make the complex-curves path.
                Make a simple helix curve component and use Component Stringer with it to make a copy of it along the curve joined end-to-end ?
                Explode all of these 'line' components into a single grouped set, explode these curves and welded everything into anew curve.
                Use TubeLongPath to make a FollowMe extrusion that will rotate smoothly along this new curve...
                πŸ’­
                  This tutorial researched by Chris πŸ˜‰
                  • ken28875K Offline
                    ken28875
                    Hi guys,
                    Thanks for all the tips. Very useful. But I still cannot manage to get the correct result.
                    Shape bender does work only for flat/2 dimensional curve. What I have is a complex 3 dimensional curve.
                    TIG's method or the similar method that I used in my first images using Component Stringer works well only is the segments of the curve are equal. In that case I can probably join the helixs end-to-end, explode and weld them as TIG described. However, most of the curve that I use will mostly be composed of irregular segments. Therefore, all the methods that have been give won't work.
                    Indeed, I just did another test with a curve with different sizes for the segment using Component Stringer. As you can see, it is not possible to join them end-to-end as the size of each helix is different from one another due to the different sizes of the segments.
                    http://i593.photobucket.com/albums/tt12/ken28875/misc images/helix_following_curve_04.jpg
                    What I hope is to have a plugin that will make the helix follow the complex 3 dimensional by connecting end-to-end and keeping it size consistent/uniform not matter the sizes of each of the segments that make the curve.
                    I think it will be a great challenge to come up with that plugin, but if anyone has time and would like to think about it, I'll be much appreciated. πŸ‘
                    Thank you,
                    _KN
                    p.s. I may even give a monetary donation as a token of my appreciation. πŸ˜‰
                    Follow Your Dreams.
