    Tool <> WebDialog <> Observers relationship
    23 Posts 4 Posters 2.0k Views 4 Watching
    • T
      tomasz
      @dan rathbun said:
      Tools are meant to be re-used.
      I have downloaded Google's 'rectangle.rb' tool example and I find following on the start-up:
      if( not $rectangle_menu_loaded )
          add_separator_to_menu("Draw")
          UI.menu("Draw").add_item("Rotated Rectangle") {
              Sketchup.active_model.select_tool RectangleTool.new }
          $rectangle_menu_loaded = true
      The tool is created each time the plugin is started.
      Maybe if I have a Tool as a global variable inside a MyWebDialog class it multiplies now tools, every-time I open the dialog..
      What you propose has definitely a lot of merit. I will check if it improves my tool stability.
        Yea - I used to create tools every time it was activated as well - due to the examples in the manual always do so. Can't remember if it was Fredo or Whaat that mentioned it was not necessary.
        • AdamBA
          AdamB
          Well Dan is sensible guy who says smart stuff. But I'm not quite sure why you want to keep a reference to the Tool around rather than release it back to the system. The specific reason I generally keep dialogs as class variables is to avoid the weird GC behaviour I wrote about earlier. But the rule of thumb in OO systems, is you create stuff, use it and explicit/implicit release stuff.
          The exception is sometimes performance when you pre-create Pools of objects to use/share. But this isn't one of those cases.
          Adam
            That is what I am doing. I was going a bit OT. I wasn't referring to a tool that created webdialogs.
            • Dan RathbunD
              Dan Rathbun
              I have downloaded Google's 'rectangle.rb' tool example ...
              Warning! Most of the Google Ruby examples, have very poor Ruby programming practices. (One of the things on my to-do list is to edit these examples, so newbies see the proper Ruby way of scripting. Just need to find the time is all.)
              And that makes my point. The example is a poor example.
              Globals are not kept inside a class, even if they are defined inside a class.
              I'm not here much anymore.
                Yes - I have some to realise this. Bit of a shame as one easily use the documentation as guideline when learning a language.
                • Dan RathbunD
                  Dan Rathbun
                  Depends... if it's a base drawing or editing tool, that will be used often.. keep it around. If it's say a import, export or report tool, that will be used only on occasion, then yes create it when it's used, and release the reference to it when it's no longer needed. (Hoping GC will dispose on it.)
                  So is there a difference when the WebDialog instance, is created inside Object (at the console,) as opposed to within a custom namespace (Class or Module.) ?? It's always dangerous to create objects in the ObjectSpace, because all other objects may inherit them in some way (especially true of methods.) Local variables, Class variables and Instance variables defined in Object (at the console,) act strangly like Global variables when they're inherited by all the other objects.
                  Well I have no idea what kind of tool he's talking about. If it's an occasional tool, then you are correct AB. If it will be used often, he will want to, keep the instance alive.
                  • Dan RathbunD
                    Dan Rathbun
                    Agreed.. however, it would nice to have direct control over "my" objects. When I want to get rid of an object, I'd like to call a dispose method. Perhaps also a release method that would release ALL references (vars) to the object. And finally, I'd like the undef function/keyword to act upon references (of all kinds,) so when I'm done with a reference, it can be removed from the module/class reference hash-table. (There is cheat to this. Use vars that begin with a capital letter so Ruby sees them as Constants, then you can use the remove_const to remove the definition.)
                    Anyhow... these wishes need to be voiced over at
                    http://redmine.ruby-lang.org/projects/ruby/issues
                    • T
                      tomasz
                      @dan rathbun said:
                      The next time the user clicks a toolbar button (or menu item,) for your tool, Sketchup will call the Tool's activate method. This means that the Tool class object is still defined and should remain defined.
                      I have noticed that 'activate' method of my tool is never called. I create a object=MyTool.new, it launches initialize().
                      Could we create a simple structure of a properly programmed tool?
                      I have written something for a start. I think it is bugged because set_on_close is fired up twice.
                      require "sketchup.rb"
                      module ProperTool
                      	#Observer
                      	class ProperTool;;ViewObserver < Sketchup;;ViewObserver
                      		def onViewChanged(view)
                      			puts "View changed; #{view}"
                      	#Create observer
                      	version="ProperTool_001"
                      	unless file_loaded?(version)
                      		ProperTool;;VERSION=version
                      		@@view_observer=ProperTool;;ViewObserver.new
                      	#Define reader method for the observer
                      	def ProperTool;;get_view_observer
                      		return @@view_observer
                      	#Tool
                      	class ProperTool;;TestTool
                      		def initialize(web_dialog)
                      			@ip = Sketchup;;InputPoint.new
                      			@web_dialog=web_dialog
                      		def onCancel(reason,view)
                      			@web_dialog.close
                      		def deactivate(view)
                      			@web_dialog.close
                      	#Web Dialog controls the rest
                      	class ProperTool;;MainDialog
                      		def initialize
                      			@dlg=UI;;WebDialog.new("ProperTool")
                      			@dlg.set_html("<html><body>
                      				<form>
                      				<input type=\"button\" value=\"Close Me\" onclick=\"window.location.href='skp;close_me'\" />
                      				</form></body><html>"
                      			@dlg.set_on_close {
                      				puts "Set on close fired."
                      				Sketchup.active_model.active_view.remove_observer ProperTool;;get_view_observer
                      				Sketchup.active_model.select_tool(nil)
                      			@dlg.add_action_callback('close_me'){ |dialog, params| self.close() }
                      			@tool = Sketchup.active_model.select_tool ProperTool;;TestTool.new(@dlg)
                      			Sketchup.active_model.active_view.add_observer ProperTool;;get_view_observer
                      			@dlg.show
                      		def close
                      			@dlg.close
                      end # Module
                      unless file_loaded?(ProperTool;;VERSION)
                      		main_menu = UI.menu("Plugins")
                      		main_menu.add_item("ProperTool") {ProperTool;;MainDialog.new}
                      file_loaded(ProperTool;;VERSION)
                      Version 001
                        activate and initialize both works - for completely different purposes.
                        initialize triggers when you create an instance of your Tools class - as any other class. activate triggers when the tool is being activated - either by Sketchup.active_model.select_tool or Sketchup.active_model.tools.push_tools.
                        Are you not seeing that behaviour?
                        • T
                          tomasz
                          When I have added the activate method to the posted sample, it does trigger, but the initialize() doesn't.
                          For some odd reason activate doesn't fire up in my own tool. I start both tools exactly in the same way:
                          @tool = Sketchup.active_model.select_tool ToolName.new
                          Version 002 - activate tool method added
                            ` > class MyTool; def initialize; puts 'init'; end; def activate; puts 'activate'; end; end;
                            nil
                            t = MyTool.new
                            init
                            #MyTool:0x11752260
                            Sketchup.active_model.select_tool(t)
                            activate
                            #Sketchup::Model:0x11269cf8
                            Sketchup.active_model.select_tool( MyTool.new )
                            init
                            activate
                            #Sketchup::Model:0x11269cf8`
                              In your code:
                                "Tool created."
                              You're missing a puts.
                                  @web_dialog.close
                                Do you need to close the webdialog here? It does not stop the Tool.
                                If the tool is a line tool for instance, and the user starts to draw a line:
                                Clicks once to set start point - then the tool enters a state where it expects the user to pick another. but if the user hit Escape this event is triggered with reason == 0 - and the tool should then reset itself. But the tool itself is not killed.
                                  @dlg.set_on_close { puts "Set on close fired." Sketchup.active_model.active_view.remove_observer ProperTool::get_view_observer Sketchup.active_model.select_tool(nil) }
                                  Regarding Sketchup.active_model.select_tool(nil) - that will activate SU's Select tool. I'd recommend that you instead use Sketchup.active_model.tools's push_tool and pop_tool so that when you deactivate your own tool it return to the previously selected tool (which might very likely not be the Select tool)
                                  • T
                                    tomasz
                                    >   @web_dialog.close
                                    > end
                                    It is just a single stage tool. If an user presses escape I want to close the webdialog and deactivate.the_tool. Invoking @dlg.set_on_close {Sketchup.active_model.active_view.remove_observer ProperTool::get_view_observer; **Sketchup.active_model.select_tool(nil)**} will close the tool... and will trigger @web_dialog.close again. That is why it fires up twice.
