    Bonzai3D - double take
    extensions
    119 Posts 21 Posters 22.6k Views 21 Watching
    • X Offline
      xrok1
      could just be the way its presented, the jury is still out for me. i'm sure the b3d support team will clear it up (if they're still talking to me). in the end it doesn't really matter along as the program does what you need. πŸ˜‰ to me the little things are more important, like snaps and aligning...
        bonzai3d support
        Rocky,
        Thanks for your extensive suggestions. We take all user feedback very seriously, so they will certainly be considered. A few comments / clarifications:
        The (missing) options to Align and Snap to Ghosted was an oversight, and will be added with the next update (in April).
        While moving an object, if you enter an angle and tab to the distance filed, then the angle will be locked. (Likewise, entering a distance and tabbing to the angle field will also lock the distance and allow you to select the desired angle graphically -- or you can enter both numerically and just hit Enter to numerically modify your objects.)
        The Shift key while moving objects toggles the Snap to Self on and off (and does not lock the object) but the idea of a modifier to lock the direction of an object sounds reasonable. (We will see what we can do. πŸ˜„)
        Arail,
        Sorry to hear that you did not have sufficient time to evaluate bonzai3d with your Trial version. Please send an email to support@bonzai3d.com to request an extension, and we will see what we can do. πŸ˜„
        Rocky et al,
        Bonzai3d is perhaps properly called a "hybrid" modeler. It is a solid modeler that works with both Smooth and Facetted data -- AND it also works well with Surfaces AND NURBS.
        We are looking into additional file formats, but for now, NURBS objects can be imported and exported using the OBJ format.
        Bonzai3d's NURBS are quite sophisticated, and we have more improvements coming. To see what you can do currently, check out these videos:
        301 Moved Permanently
        (www.formz.com)
        (www.formz.com)
        You can also check out a few of our sample files here if you like:
        (www.formz.com)
        So when you first create a Sphere in bonzai3d, it is a true sphere, with a center and radius and corresponding controls. If you want it to be a NURBS object, click on it with the NURBS Convert tool:
        If you want to add or remove control points, use the NURBS Reconstruct tool:
        Hope this helps!
        Please let us know if you have any further questions.
        Explore * Design * Deliver
        http://www.bonzai3d.com
        Version 2.5 Now Available!
          remus
          Bit of a wishy washy question to bonzai support: what do you consider the advantages and disadvantages of a hybrid system?
          p.s. xrok, i'll delete/split this if its wavering too far form the subject of the topic.
            bonzai3d support
            Remus,
            There are lots of advantages to a hybrid system. For example, if you draw a smooth Sphere, you have spherical controls and you can control it as a sphere (with radius, closure options, partial sphere options, etc). If you decide that you want to edit it differently, you can simply Convert it to NURBS, and manipulate it that way. And if you decide that you now want to start manipulating individual facets of the object, you can Convert it to Facetted as well. It is really the best of all worlds.
            Really the only disadvantage is that there are more options and more ways to manipulate data -- so there is more to learn. But of course, you don't have to start out knowing everything to be effective. Learn and use the basics -- and just know that when you need more, there is more available.
            (By the way, if anyone is interested, a bonzai3d Webinar just started and there are still a couple of spaces available. See this link to sign up if you want: http://www.formz.com/landings/webinar.html)
            • X Offline
              xrok1
              very very good news!
              good to know, doesn't solve the negative movement workflow though.
              i hate to argue with you about how your own software operates but... although tapping does toggle self snap, holding shift does lock direction it just doesn't do it consistently. (see attached video)
              shift lockedit.avi.zip to view delete the .zip part at the end of the name, this was added so i could upload it. if someone wants to bother (or knows how) to display it... πŸ˜‰
              thanks for clearing that up. πŸ˜„
              • arail1A Offline
                arail1
                A thank you to both xrok1 and Bonzai support for a very useful exchange. For someone who's not sure of the way forward this type of thread is incredibly helpful.
                  bonzai3d support
                  Rocky,
                  Regarding the Shift Lock -- what I meant was it does not lock it at an arbitrary angle. Currently, it locks it to either Parallel to X, Y, or Z IF your cursor is on one of those axes when you press and hold the SHIFT key. (This allows for easy orthogonal movement while aligning with another object...) πŸ˜„
                  • X Offline
                    xrok1
                    i'm glad we agree. πŸ˜„
                    now, i've been able to reproduce the inconsistency i told you about and i'll demonstrate here:
                    if i move along an edge then hold shift it won't lock in the direction of that edge even though you see that i'm moving parallel to the red axis:b3d1.jpg
                    if i move past the end of the edge and hold shift it works as expected. this is a problem when you can't get past the end because other objects may be in the way (i know you can simply zoom way out then back in but its not good work flow). also it seems to me that you should be able to lock on edges anyway, whether they are along an axis or not but especially if they follow an axis.
                    • X Offline
                      xrok1
                      another example:
                        bonzai3d support
                        Rocky,
                        Thanks for clarifying, we are now reproducing this. If you disable the object snaps before you hold down the shift, then this will work as we expect. You can then re-enable the object snaps (while still moving the object and holding down shift) to complete the move -- snapping to something else.
                        Thanks for your report, we will get this corrected.
                          jpalm32
                          @xrok1 said:
                          this is actually not a tutorial but a journal of my experience with a new (your) software from a designers point of view. πŸ˜‰ i will send you the file so you can check it out and advise on what's going on. i will try one more time from scratch since i'm not too far in anyways.
                          πŸ‘Š biting my tongue over your last statement. πŸ‘Š
                          I bit my tongue at the same time. WTHF what's up with that staement.
                          This thread is GREAT!!!
                            MrWip
                            Great subject xrok1, you're really asking good questions, and I see that SU user have struggle on the same point while beginning with B3D.
                            It's good to see that I'm not the only one to envounter many crashes, even with an updated version of B3D and graphic drivers... I really hope this will evolve, because you have to trust the program you're using everyday...not knowing when it will shut down is a real pain...
                            Since B3D people are around here responding to questions, there is something they may explain... Actually, it's just a small parameter, but it stops me going further in B3D workflow : when you're making an extrusion, or something like that, you first pick the object, then begin the movement, clearly visually presented by a nice arrow, then you enter the dimension you want (actually it's sound like sketchup...) BUT (and that's where its really annoying...) there is a "minus" to enter if you want to go in one way... actually, giving the direction + a dimension should be enough, but here, you have to take care of the direction (quite arbitrary... maybe normal related...), and enter for example "50" or "-50 " regarding to the direction.
                            I didn't find a way to disable that (maybe it's an hidden option, and my post make no sense...) and it really reduce my interest in the subject... I
                            t may sound like a rather small problem, but it's killing the workflow when you're constantly pushpulling things around in a model... so I hope it's just an option , somewhere...
                            http://www.wip-archi.com
                            • X Offline
                              xrok1
                              mrWip if you look closely through my extensive critiques 😳 i've mentioned this too. stating that Bonzai should take the direction of you initial movement into account as the direction you want your action to go in. funny thing is it does work properly with the move tool πŸ˜• you don't need +- then it goes in the direction you start in.
                              anyway the Bonzai team reported a while back that there will be an update in april so i have paused my project until then so i can also include comments about the update and see if it helped streamline the work-flow any. πŸ˜„ lets hope so...
                              • X Offline
                                xrok1
                                @bonzai3d support said:
                                Rocky,
                                here we are in may πŸŽ‰
                                  rickgraham
                                  Hi Xrok et al,
                                  I am really liking this thread, but I DO need to ask..
                                  So far, what I have seen done with this software with pictures and descriptions looks like other rubies can duplicate unless I'm missing something major here. πŸ˜’
                                  But keep up the work. It is good to see ones processes.
                                  Rick
                                    You can create the same in SU for most of it, true. But Bonzai is a NURBS modeller, a different animal. It can deal with solids and geometry is more parametric than SU.
                                      rickgraham
                                      Thanks Thomthom,
                                      So in other words for my application as 99.999% commercial architecture/landscape architecture, SU is still it. I will admit, I really like their demo of contours and terrains tho..
                                      πŸ˜‰
                                      Rick
                                        SU is fine.
                                        But Bonzai is fine as well for that. Let you cut into solid walls. And the walls have parametric width and height.
                                        I did try out the terrain tool, very nice in that it let you choose between smooth and stepped, but it requires all contours to be connected. Any small caps, as there often is in the data one get, will prevent it from generating terrain. While SU's sandbox tool accepts any amount of garbage.
                                        The cleaner the contours the better the terrain of course, but at least SU let you get at a starting point, while Bonzai just flat out refuses to play game. To me that was disappointing because I can't can't go through all the contours to ensure they are connected to generate a terrain. The data is just too big for that, and one have no idea where the smallest gap might hide.
                                        • X Offline
                                          xrok1
                                          thom did you try the object doctor? i'd be curious to know if that would work.
                                          bonzai should have better dialogs and trouble shooting when it fails at certain operations or the object doctor should run automatically. 😒
                                          still waiting for the update πŸŽ‰
                                            No - I have not tried the Doctor.
                                            • 4 / 6
