    [Plugin] Blend ver 1.12.
    80 Posts 35 Posters 65.1k Views 35 Watching
    • N Offline
      nankyo
      IT is amazing one indeed..
      Though, I wonder if u think it possible to make a 'reverse engineering' version of that one.. I mean,many times I need to take a "solid" shape and make it with 2D shapes.. what I do is creating many planes and intersecting it all.. THis plugin is so amazing (really I feel I work with Rhino..), and I guess adding the revearse option would make it perfect.
      Thank you for that, kirill. ๐Ÿ˜Ž ๐Ÿ˜Ž ๐Ÿ˜ ๐Ÿ˜
      mmmm.... mow I found the SliceModeler v1.0 that do more or less what i need ๐Ÿ˜„ but yet not exactly....
        kirill2008
        @haru said:
        In order to make the blended face right to designerโ€™s intention, each start-point of two figures(โ‘ ,โ‘ข) shall be set-up as well as the direction of drawing, that is clockwise(โ‘ก,โ‘ฃ) or counterclockwise.(โ‘ก,โ‘ฃ-a)
        For all, itโ€™s just an idea
        Thank's for great idea. I'll try to implement it as soon as possible.
        I think it is posible. I'll try to make it too.
        You may try also 'pnts2mesh.rb'. It can slice a group that contains a set of faces with a number of horizontal planes placed with specified offset (horizontal means relatively to selected group transformation).
        [flash=425,344:uuqblkor]http://www.youtube.com/v/qetoQvcEoic&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:uuqblkor]
          Disrespective
          Just thought i'd say thank you from the southern hemisphere.
            pr0bka
            Kiril, i have a question. I really like both your plugins - blend and path to face. I noticed on a thread that you have the ability to blend segments instead of simply geometry for the blend plugin. Is it possible to do the same with the path blend tool - i.e. blend 2 paths along another path?
            just for reference, here's an example ๐Ÿ˜„
              Seems there is a little bug when you Blend 2 closed curves ๐Ÿ˜ฎ
              (here 2 circles)
                Momac
                Hi Krill
                Is the plugin Windows only
                In Mac version the dialog / Input box does not get active
                  ricklaney
                  Where can we download the latest version of sublend.rb
                  Does it work with SketchUp Pro 7?
                  I am trying to make Pipe fittings like 3/4" 90 degree Street Elbow. Do you know where to download pipe, hose and tube fittings?
                  Thank you for a reply,
                  Rick
                    ricklaney
                    Where can we download Blend ver 1.9 and 'pathface.rb'
                      dedmin
                      Purged Account
                      Purged Account
                      (lss2008.livejournal.com)
                        kirill2008
                        Hi, Rick.
                        pathface.rb: http://dl.dropbox.com/u/4885828/pathface.rb
                        sublend.rb: http://dl.dropbox.com/u/4885828/sublend.rb
                        I also sent a reply to your private message, so check your inbox for more information.
                        • EarthMoverE Offline
                          EarthMover
                          Kirill, just downloaded the new toolbar set from your site. Great idea and it works great. One suggestions would be to add the name of each tool when you hover over the toolbar icon. Thanks again...it makes life easier!
                          Content Creator at Skapeup
                            kirill2008
                            Ok, I'll add tooltips.
                            Note that there is a bug in prerelease version of lss_toolbar.rb: zoom-in/zoom-out clears selection. I already fixed it, but did not published the release version, because I want to make some other enhancements and bug fixes before release. I'll try to finalize lss_toolbar.rb in the coming days.
                              EarthMover
                              Rick
                              Rick, have you checked out Skeng 3D? - http://www.3skeng.com/en/index.htm
                                Keith Benson
                                (here 2 circles)
                                [attachment=0:2ghmer31]<!-- ia0 -->sublend.jpg<!-- ia0 -->[/attachment:2ghmer31]
                                I recently downloaded the latest version of Bland, but only occasionally can I get it to blend two shapes without "twisting" them. Am I missing something? I am just trying to blend a rectangle (12"x5") and a circle (12" diameter) over a 6 inch distance.
                                I have used every combination of choices from the drop down box that pops up and I must be setting it up wrong or something.
                                Any help would be appreciated, thanks!
                                Keith
                                  EarthMover
                                  Keith, it's because each shape has a defined start and end point to SU. The plugin is set to read those points and align the new mesh to the existing segments in successive order. With the Blend plugin, Kirill added post operative capabilities so you can rotate either shape until you align the start/end points and the mesh straightens out. So after the plugin is finished, it is still waiting to receive user input to correct the errant shape, as long as you don't explode the created group.
                                    Keith Benson
                                    Ahhh - thank you. That helps me understand why some were more twisted than others.
                                    Keith
                                    • H Offline
                                      hgdn
                                      Krill,
                                      All your tutorial videos seem have been deleted on youtube strange??? Could you tell us an alternative source to find as a lot of people try to look for it as well. Thanks...
                                        sbergstedt
                                        Krill,
                                        I somehow cannot access the videos that you posted? could you repost them and let me know? I would really like to know the proper way to utilize these utilities you've created. They're awesome!
                                          atek
                                          Great plugin what i was thinking i got it. Its not working with group and component. Is there any option i want to use with group or components. Plz reply
                                            Did you read the author's first post in this thread? He says this plugin is obsolete.
                                            • 3 / 4
