Model size
I have a large model size (25MB) and I am wondering if there is a way to be able to see the size of the various components and items within the model?
I've exported as a .dae file to see the texture file sizes but It's the actual size of the parts of the model I'm interested in.
Any suggestions much appreciated.
Thanks.
Hi Lee,
Have a look at this topic for ideas:
http://forums.sketchucation.com/viewtopic.php?f=15&t=26893 -
Sort of.
Assuming you have a train, delete everything but the locomotive. File/Save As ... locomotive.skp. Load again. Delete everything but the caboose. File/Save As ... caboose.skp. And so on.
File/New. File/Import locomotive.skp. File/Import ... through caboose.skp. After each import, click the origin. Each piece will be a separate component in the completed model. Clicking the origin will reassemble perfectly.
And each piece will be much friendlier to work with than the 25MB full model.
Trick: open locomotive.skp. Create a layer named locomotive. Select all. Use Entity Info to move everything into the locomotive layer. Save. When you import, your completed model has a layer named "locomotive" with a single component, also named "locomotive".
