    [REQ] PushPull Rotation
    11 Posts 7 Posters 1.7k Views 7 Watching
      Does this exist ?
        Isn't that EEbyLathe ??? πŸ˜• πŸ˜• πŸ˜•
          Since you won't know the angle you can't enter it in EEbyLathe... 😲
          OK OK - it is in EEbyLathe2...
          I've already been asked to add an option for you to pick two points for the lathe's rotation angle - it's currently at the ~3/4 way up the to_do_list...
          You'll enter 0 for the rotation and then after you've picked the axis points it'll prompt you for the start and end points to get the rotation angle from....
          Wait a week or two...
          πŸ˜‰
            I don't want draw the path before or measure for know the angle! πŸ˜‰
            Just pick the surface and click 2 points : Center of rotation, snaping point
              You are the king! β˜€
              • U Offline
                utiler
                Yes, Yes, YES!!!!!
                I like how these guys incorporate the protractor tool into their functions...
                http://www.3skeng.com/en/index.htm
                I'm going to dig, Lathe2, TIG!!!
                Just Curious...
                • E Offline
                  erikB
                  this would be very handy indeed.
                  erikB
                    ken28875
                    TIG is the man! Can't wait for EEbyLathe2 to come out. πŸ‘
                    Follow Your Dreams.
                      Cool stuff, and as always TIG has the tools.
                      Just wondering however why not use follow me to create this?
                        FollowMe won't make 'square' ends - it starts off at a right angle to the first segment of the path NOT the rotation of the 'face' being followme'd - it's a known limitation of FollowMe around circular paths, and one of the reasons I made 'Lathe'...
                        I'm currently redoing EEbyLathe so you can either enter the angle in the initial dialog or if you you make it zero [0] you get prompted to pick two points to define the angle around the center of rotation with a protractor like tool, VCB angel readout etc - I'm looking also at allowing you to type in the angle as you go...
                          DIEGO-RODRIGUEZ
                          tig.
                          in this new version of lathe, it could include generating estruciΓ³n edges, and besides extrusion of faces?
