    Castle Howard
    72 Posts 56 Posters 30.2k Views 56 Watching
      linea
      Martin
      This is phenomenal work. I live about an hour from Castle Howard so have visited a few times. Wish I'd thought about doing an SU model!
      jon
        studio1
        I am truely amazed - I'd like to say this is a stunning piece of work but it simply wouldn't do justice to the care and the sheer dedication gone into this.
        Unbeleivable....
          d12dozr
          Phenomenal modeling! Thanks for posting here for us all to enjoy ๐Ÿ˜„
          http://goo.gl/f7ooYh
            MartinPh
            ...iRender turned out another one overnight.
            http://imgur.com/5O0FG.jpg
            • EarthMoverE Offline
              EarthMover
              Phenomenal work! I'm picturing this with some dirt maps applied, better glass and an ambient occlusion overlay. It wouldn't be too hard to take this to photo quality that would fool most anyone. Great job on the mode ๐Ÿ‘ ling!!!!
              Content Creator at Skapeup
                CADAddict
                Simply Brilliant,
                great Job!
                http://www.cad-addict.com/
                • simon le bonS Offline
                  simon le bon
                  Bookmarked in my Sketchup remarkable pages ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜„
                    Now you can make a 3D printing ๐Ÿ˜‰
                    But piece by piece โ˜€
                    like this one 'Tuileries : Louvres' behind the guy
                    in fact all is not 3D printing because will be to expensive but one piece then copy in traditional (silicon muld)
                    [flash=480,385:3dhk1xjz]http://www.youtube.com/v/IMAUc9kQ8a4&hl[/flash:3dhk1xjz]
                      MartinPh
                      Tempting thought Pilou... only, where will I put it...?
                      Adam, I need to get into the iRender material editor more; I barely scratched the surface. But bitmap textures are basically useless, except for detail views; on the large scale patterning will occur. As for the glass, suggestions are welcme! I'm not satisfied with the metal ornaments either.
                      As far as I've been able to see iRender unfortunately doesn't do AO. I'm still hoping ASGVIS will finally come up with a decent patch for their new, incredibly buggy Vray, which has been sitting on my PC unused for over a month now because it crashes every time I try to render this model. I would be very curious to see what VRAY makes of this!
                        tomislavm
                        My God,it looks fantastic, unbeleivable. For me You are the master, how long did You make it?
                          ScottPara
                          This is a perfect example of a highly detailed model and taking the time to get things right and not rushing things through only to post your work. The attention to detail is fantastic to say the least.
                          Scott
                          Love the fact that some HATE my avatar.....
                          • AnssiA Offline
                            Anssi
                            Martin,
                            I run out of superlatives.
                            Now you can make an animated version of Brideshead Revisited...
                            Anssi
                            • FletchF Offline
                              Fletch
                              Stunning model! I hope you leveraged the use of components in this one! Seems like if it was done right, it would be a big file, but no 80Mb...
                              but who am I to judge?! I've never built a castle like that! ๐Ÿ˜†
                              I'm sure if you showed what you've done to people that care about the castle you would find it of great importance to them. ๐Ÿ˜‰ If they're in the mood to think, or listen.
                              guessing SU2KT could export this to Kerkythea, and you can use layered/procedural textures with it, and instancing brush for vegetation... and it's free.
                              Fletch
                                MartinPh
                                Hm, no, unfortunately. Attempts to export this to Kerkythea only make SU crash. That's why I opt for renderers that work inside SU.
                                You are undoubtedly right though that a little more work on thorough use of components would reduce the file size... I tend to be a bit lax in that way, bad, bad habit... Not that I would expect such a 'cleanup' to solve the export problem, I'm afraid my system simply isn't up to the task.
                                • Al HartA Offline
                                  Al Hart
                                  Ambient occlusion is a technique used to "fake" indirect lighting in renderers which do not offer this feature. Typically, engines like Maxwell, Kerkythea, or IRender nXt do not use this because they offer "true" indirect lighting. Some engines offer the choice of indirect lighting or ambient occlusion ( ambient occlusion is faster, but much less correct).
                                  For IRender nXt, you should use the "Gather/Exterior" indirect lighting setting to get a similar result, using actual indirect lighting.
                                  Al Hart
                                  IRender nXt from Render Plus
                                    MartinPh
                                    For those of you who are intererested, here are a few examples of the reference material I used. Vitruvius Britannicus is an excellent source, offering complete plans and elevations as well as, in this case, a famous and spectacular birds eye view. Still, modeling the thing soon made it clear that the drawings are not consistent among each other, so at times I had to improvise. There are no lateral views or views of inside courtyards in VB, so for those I relied on a visit, on photographs and even on scenes from the Brideshead Revisited TV-series (excellent!) and movie (awful!).
                                    Jon, I envy you! I have traveled quite extensively but still consider Howard and its environs to be the most beautiful place I've ever been...
                                    • ken28875K Offline
                                      ken28875
                                      Wow, awesome model! ๐Ÿ‘ ๐Ÿ‘
                                      I would suggest you play with the camera/field of view to get some more interesting/dramatic views.
                                      Have a nice one!
                                      _KN
                                      Follow Your Dreams.
                                      • FletchF Offline
                                        Fletch
                                        hmm... too bad about the component leveraging... as it also makes for much faster model processing and rendering and better RAM usage... maybe keep it in mind for your next monster project. ๐Ÿ˜„
                                        well, it's a pain, I'm sure, but you can export different sectors of the model, north wing, south wing, etc, then merge them all together in one big model in KT... but it should (KT) handle the polys just fine.
                                        People do this all the time, usually its a matter of separating furniture from architecture... but in your case could be castle "wings". ๐Ÿ˜‰
                                        Fletch
                                          Glenn at home
                                          This model needs to be the response that people get when they say that SU is not a professional tool! Excellent job. ๐Ÿ‘
                                            Sir
                                            amazing
                                            • 2 / 4
