    More standard camera positions
    13 Posts 4 Posters 1.7k Views 4 Watching
      If I understand what you want to do, you don't need a plugin for it. You can do it with native tools.
      Draw a hexagon centered on the center of your subject and at the desired height of the camera. Use the Position Camera tool to locate the camera at a vertex on the hexagon. When you do that, click on the vertex and hold the mouse button while you move the tool to the center of the hexagon. The camera will move to the location of the first click and face the second end of the line you make with the tool. Make a scene and repeat for the next vertex. Continue around the hexagon until you've got all six positions 60° apart. Delete the hexagon when you're finished.
      If you use a polygon with more vertices, you'll get a smoother transition.
      Here's a quick sample.
      Camera Placement.skp
        tspco
        That might work Dave I made a few trial runs, and in a few cases I didn't move the camera position tool on the face of the hex, and things went weird, I will get it eventually. Thanks for the tip! Ryan
        SU make 2017, /Twilight Render Hobby
        Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
          tspco
          Here is what I wanted to accomplish I started by using Chris Fullmer's center on origin plug, then I used a camera spin plug I found, Animation 2 I believe. I started the spin plugin, then started recording with Cam Studio. Since Cam Studio dialogs show up at the beginning and end of recording, I edited those out with a free video editor (at least free for now)called VideoPad from NCH .
          http://www.youtube.com/watch?v=CFWivXCVmSQ
          Enjoy~!
            Good start. Why is half the trike underground?
            Like I wrote last night. You could do all that with native tools. It's nice to have the plugins though.
              tspco
              Well I think is is because of the center on origin plugin, When Chris says center on origin he means it. It would be an easy matter to move it up a few feet;)It also appears to spin in a downward if I do not center it on the origin, however I moved it up 2 feet and in one rev it still looks good and "flat" I will post that video after work to night.
                There's no limitation on where the camera view is centered using the Position Camera tool. I used the origin in my example but it doesn't have to be there. You also don't need to use the center of the polyon for centering the camera.
                • X Offline
                  xrok1
                  where is this position camera tool? i can't seem to find it!
                    It's in the Walkthrough toolbar - that little dude standing on a red cross
                    • X Offline
                      xrok1
                      thanks. i knew i used it before but couldn't remember. 😉 great compliment to the film and stage place camera tool!
                        tspco
                        Well after some playin' around here is my first version.
                        Her are the problems I had, it is difficult to move the camera position tool, from a vertex to the center of the hexagon if you can't see the center.
                        The avi I created looked good, when I converted it to an flv for uploading the quality suffered. I think with some (a lot) of practice and patience I may get it right.http://www.youtube.com/watch?v=HbJABSJ_AVM&feature=player_embedded
                          You could temporarily hide the model so you can see the center of the hexagon. Then unhide it and update the scenes.
                            tspco
                            There is a duh moment for me, I hide and show stuff all the time when I am working on a model, never thought about hiding the model so I could see the center. At any rate I did one video show and it worked out OK. I wish I could find the best possible, set up for you tube. The link I posted for this thread was upload #3.
                            I will practice and get better. Thanks for your help so far.
