    Section cuts in scenes
    3 Posts 2 Posters 159 Views 2 Watching
      steve2802
      I've recently created a fly through of a cottage using section cuts to remove the roof and show cross sections where required. All was working well until I changed the style of the first scene. Now when I play the annimation the section cuts dont show. I've made sure they are active in the scene and updated the scenes but every time I hit play it just runs through with no section cuts.
      Any ideas?
      Cheers,
      Steve.
        Hi Steve,
        Go to your preferences window (Window menu on PC) > General tab and make sure that the style change warning is on. Now set your preferred style with the section cuts and update the scene (right click the scene tab > update). A popup will ask you if you want to update your style, save it as a new style or do nothing. I guess you need to update your style (but that also depends on your whole model).
        Repeat this with the preferred style/cut settings for each scene tab.
          steve2802
          That's great - Thanks a lot for your help.
