    Help Me Draw A Dome [TUTORIAL]
    322 Posts 10 Posters 47.7k Views 10 Watching
    • chrisglasierC Offline
      chrisglasier
      D0me, you may find this Sunday idea the basis for a good solution.
      See also sketch .skp
      D0me - simple form.skp
        D0me
        Hi Chris
        With regards to the spinner, I'm still curious to know what sort of contraption can be made to fit on my wood and the pipe (2" Diameter)?
        This contraption should be able to stay in a stationary point on the pipe and spin.
        I've thought up a few ideas but had to disgard them because if I have a contraption that will be tightened in place and at the specific height on the pipe, it won't spin if you know what I mean. And if I leave it loose it won't stay at the height on the pipe I wish for it to stay.
        Any ideas?
        Regards
        D0me
          chrisglasier
          Basically you need two pipes one fitting inside the other like a telescopic leg. One has the wood clamped to it and rotates; the other needs to be solidly fixed to keep vertical. The size will depend on what you can find that will work.
            chrisglasier
            Trying to improve my analytical Sketchupping:
              chrisglasier
              One plus one ...
                D0me
                Hi Chris
                Nice sketching
                Can you upload the skp of those images? Would love to get a better view of things.
                Guys, I'm also starting to redo the model but I am going to use the advice Gaieus gave and start with the pipe first.
                Any tips on how I should go about doing so, like e.g the domes first then pipe or the other way around???
                Regards
                D0me
                  chrisglasier
                  Here you are
                    chrisglasier
                    Hey D0me I just came across this:
                    Fornobravo
                    Have you seen it before?
                    See the bung, the simple floor, the position of the smoke vent ...
                      D0me
                      Hi Chris
                      Nice find. Thanks for the link.
                      Thanks exactly what I am looking to do. One difference is I will pour in my cement to fill the bunghole rather than how they have done it by having the keystone already made.
                        D0me
                        Hi Gaieus
                        I'm starting to redo my model and was wondering if you have any tips on how to implement my pipe into the model.
                          chrisglasier
                          Did you notice the rebated joints?
                          You don't want to cast each segment on its back (sketch 1) and then stand it up to demould (sketch 2)?
                            @d0me said:
                            Hi Gaieus
                            Which pipe in this case? The one in the middle you will build the dome around?
                              D0me
                              Hi Gaieus
                              Yes, the middle pipe around which the dome will be built.
                                chrisglasier
                                I think I should try and clear up any confusion here.
                                I suggested spinning a screeder around a pipe to realise the job of the follow me tool when you have a point for the apex of the d0me and a circle on the brick base. The curved rule replaces the profile that is extruded. This works fine when there is no obstruction.
                                When you compartmentalise a segment the form sides get in the way, but the sides do provide the opportunity to draw reference curves not very far apart. You can still use a curved rule and get sufficently accurate substrate layers. Most important the last layer will be most accurate using the other curved rule in the opposite direction.
                                Revised skp showing the inner rule attached.
                                D0me - simple form 2.skp
                                  D0me
                                  Chris, should there be any concern or precautions taken should I still choose to leave a bunghole and fill it later. I will require a pipe in my center to help create the bunghole?
                                  Gaieus, I completely forgot about looking through the attachment you posted when i requested how to print my model to scale. Thanks for showing me the steps. That is exactly the way i pictured it my head. Now, just for me to add my pipe and then redo the model, print it to scale and get this "Baby" started.
                                  Look forward to hearing from you guys
                                  Regards
                                  D0me
                                    chrisglasier
                                    Just cut a piece out of a plastic pipe if you want a round bunghole or plywood if square; wedge either into top of form. Remember to set on the splay to create a bevel; or form a rebate. But it is really not necessary now you have only four pieces.
                                    Good luck!
                                      @d0me said:
                                      Hi Gaieus
                                      So how thick this pipe would be?
                                        D0me
                                        Hi Gaieus
                                        The pipe is 2" diameter and about 5mm Thick.
                                          OK, although 2" is not exactly 5 cm (I guess you meant centimetres, not millimetres?) here is the way with our existing domes - although best would be to do this either before we make some of the pieces unique (for the entrance) or to do the whole thing with the hole applied as shown in method 2 later below.
                                          So method 1 is very similar in theory to how we made the entrance. You need to pull that pipe up, intersect the pieces as well as the pipe itself, delete unnecessary geometry and insert bits copied from the pipe back to "heal" the hollows.
                                          It is obviously a tedious process. If you did it before making some of the dome pieces unique (for the entrance), you could halve the pieces needed be intersected and to insert back as when you do that with one component, all the other instances change, too.
                                          If you restarted your project, you could already include the pipe hole into the domes as per this second method:
                                          Of course, here it is demonstrated with one dome only - do the same with each.
                                            D0me
                                            Hi Gaieus
                                            Thanks for the step by step on how to add the pipe to my model.
                                            I redid my model from scratch and incorporated the pipe from the beginning as you advised. All went well. I’ve attached my model. May I ask that you take a quick look at it too see if anything seems amiss.
                                            Now I am ready to print my model to scale.
                                            @gaieus said:
                                            Now I also added a section plane to the model so that you can print the section cut to scale. Certainly the cut looks quite ugly this way but with some plugins we can easily fix that later
                                            How do I go about adding section plane to my model?
                                            The cuts on the model you posted in the above post did look quite ugly. Can you show me how to use a plugin to fix this?
                                            Regards
                                            D0me
                                            Dome V2 Final.skp
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
