    Help Me Draw A Dome [TUTORIAL]
    322 Posts 10 Posters 75.0k Views 10 Watching
      D0me
      Hi Gaieus
      The pole is used for 2 reasons.
      1. A Screeder (Wood Attached to a spinner) will be attached to the pole and used as my guideline when building the Domes.
      2. It will be used to create a Bevel at the top of the Dome and I guess this is the reason why my Dome lost a bit of height.
      Yesterday, I began redoing the Model as an exercise to see how long it takes me and surprisingly I did up to this point in about an hour which is an accomplishment in itself for me.
      Regards
      D0me
        Now when it is used only for construction (No.1) afterwards the "missing" material will not be replaced?
        As for No.2 - what is the reason for that? Why do you need your dome "bevelled"?
        • chrisglasierC Offline
          chrisglasier
          @d0me said:
          Hi Gaieus
          The reason why you think your dome is lower is because you are comparing two different points on the arc:
          You do not show the bevel on the bunghole yet. You can attach a knife to the spinner to cut the bevel to support the bung (as it will be cast separately.)
          You can also use the pole to wire cut the segments if you want.
            D0me
            Hi Guys
            Gaieus, the reason for the bevel in my dome is as per advice from Chrisglasier and after pondering over his advice a few posts back, i realized that this will strengthen my dome even more.
            Regarding point 1, you are right. After construction, the missing material will no longer be there. Should I modify my model in such a way that it accommodates for any material that will be missing (e.g Pole, Screeder, etc).
            Chris, I'm a little confused with regards to your last post. You mentioned that I was comparing 2 different points on the arch. Is it possible to show me where I should mark the correct points to compare on My Model attached on previous posts both before and after adding the bunghole?
            Any tips on how I should add the bevel to the Bunghole?
            Lastly, how should I attach a knife to the spinner? May I ask if it's OK for you to maybe illustrate it on a picture or better yet on my model so I get a better understanding?
            Regards
            D0me
              Well, a very quick and dirty "fix" would be to scale your model up accordingly. Certainly a uniform scale would be best but of course in that case, everything will be a bit bigger.
              Now I have to rush to the bank and then to the accountant (darn financial issues) and don't know when I am back but we can eventually find out something.
                chrisglasier
                  D0me
                  Hi Guys
                  Chris, thanks for the explanation using images. Understand it much better now. I’ll definitely keep those tips in mind.
                  Good luck with sorting your financial issues. They are the worst thing to resolve.
                  Whenever you can assist will be perfectly fine with me. No Rush.
                  I thought, while we are trying to resolve this situation, we can start thinking about how to get this model printed to scale and more so, how we going to draw this model in simple 2D lines so I can easily make my guides. If there is need to redo my model, this shouldn’t be an issue as I am very familiar with how to do it in a short space of time thanks to you.
                  My explanations as usual don’t seem to make much sense but hope the images do. If you need me to clarify anything, let me know.
                    chrisglasier
                    The transition from model to construction data should not be like this. I would like some time to explain. This is an important part of my work. Can you give some time - like tomorrow or the next day?
                      D0me
                      Sure Chris. I'd love to hear your advice on how the transition should be done.
                      Your advice is always welcomed and I look forward to hearing it.
                      Don't keep me in suspense for too long. I'm really anxious to compare your advice with the way I thought it should be done.
                      Take care
                      Regards
                      D0me
                        chrisglasier
                        Make the model to visualise how the real thing will work, how it will look and how it can be made. Then as far as possible use the dimensions you used to draw it in Sketchup to draw it on the plywood, bricks or whatever exists. I remember that, in your crusade to make things difficult (CMTD), that the arc of the dome is not regular, so you will have to make a template.
                        I am not against printing one. In fact I did that once for a bar canopy that was like part of an airplane wing. It took up to eight sheets of A0 paper for each truss. In those days I had all sorts of equipment including a plotter (and a joinery shop). But really I think the best thing for you is to lay a grid over a parallel projection of a standard view of the model, and then transpose the intersections onto a full scale grid on plywood to make the spinner. You won't need any other templates.
                        But you will need some 2" wire nails, twine, measuring tape, marker pen, shovel, broom, hawk and finishing trowel. You may find a wood float useful as well. Aim to make the d0me accurate to +- 10mm.
                        I have never used rapid hardening concrete but I understand it is only workable for 20 minutes or so. You really need to understand how to use the spinner and these tools before mixing the concrete. I don't understand why you want multiple d0mes (CMTD?) but I suggest 2" is a minimum thickness for any one casting. You should consider using a bonding agent.
                        If you want to wire cut the segments make a plywood collar to slip over the pole and attach straining wires at its quadrant points. Lay out your brick base square so that there is a joint at each of the base quadrant points. (Not CMTD herringbone - which will never be appreciated anyway). After cutting and scooping out the bunghole, push the collar down the pole and align the wires in the brick joints. Cut the d0me like cheese.
                        I can only give you my opinion; please remember I have only experience making an adobe d0me.
                        When's the kickoff?
                          As for printing to scale in general, the method should be this:
                          1. Make sure you are in Parallel projection mode (Camera menu).
                          2. Also make sure you are in any of the Standard views (Camera menu again).
                          3. Then set your print dialog (File menu > Print) like this below (I have set it to 1:5 now as that can still fit on an A4 page I "virtually" printed the model into a pdf file - see also attached).
                            Now I also added a section plane to the model so that you can print the section cut to scale. If you had the Pro version, you could even export this cut into a vector format to use it in some external CAD software or such. Certainly the cut looks quite ugly this way but with some plugins we can easily fix that later - the theory will be the same.
                          Dome-Print2Scale.pdf
                          Dome-Print2Scale.skp
                            chrisglasier
                            Oh and you will need to make a tunnel for the door opening and a piece of pipe for the smoke outlet. This should be close to the top of the door so that the smoke swirls.
                              D0me
                              Hi Guys
                              Thanks so much for the replies.
                              Chris, I hear what you're saying and will surely implement the given advice wherever I can. I may have access to a Plotter but if not then I will Sketch the drawing using my dimensions. Because this is a first time for me, both Sketching and Building/Masonry, I will explore different methods and use the most accurate and not necessarily the most easiest. As a comparison, I will also print the model on A4 or larger paper and see where it leads to from there.
                              "Kick Off?" My planned date is Next Weekend. I have planned other dates before but it never went according to plan but this time I am a little more confident. I am actually of to the hardware store today to try and source material I will require.
                              Gaieus: Thanks for the step by step on how to print this model to scale. Always look forward to your tutorials.
                              Regarding the plugin you mentioned to sort out the ugly cut, where can I download it in the mean time so I can start playing around?
                              Did you get a chance to figure out how we going to resolve the problem with my Dome Height after creating the bung hole/bevel?
                              Thanks again
                              Regards
                              D0me
                                Didn't you like my 'quick and dirty' solution? You know - to scale up everything by that bit. Oh well - you would have just a little bit thicker walls for your dome. 😒
                                Edit: and here is TIG's SectionCutFace plugin.
                                  chrisglasier
                                  When you have taken out the spinner pipe (it needs to be pipe not a pole in order to rotate on the spigot), fill the void with sand and dome the top. Pour the bung. Your height will be same as before.
                                    Ah good, thanks Chris. No wonder I did not suggest that - these technical details (even the whole process) is not my strength. I also thought that hole will have function later.
                                    What is this "bevel" thing with the dome BTW?
                                      chrisglasier
                                      The hole is to accommodate the spinner pipe. (It also stubs the pointy bit of the segments, which could easily break if transported.) The bung is cast at a different time so there may be a slip plane at the joint. The beveled edges stop the bung falling through. The bung is an oculus shaped keystone if you know what I mean.
                                        @chrisglasier said:
                                        ...The bung is an oculusshaped keystoneif you know what I mean.
                                        Now we are speaking! 😉
                                        Why didn't you start with this???
                                          chrisglasier
                                          @gaieus said:
                                          And take the mystery out of the topic? Notice I haven't asked why the d0me is in four segments. Another mystery yet to be revealed - eh!
                                          And what's this got to do with anything:
                                            D0me
                                            Sorry Gaieus, I must have misunderstood you. In a previous post you mentioned this solution but didn't say how to do it. You did say you were rushing over to the bank and we'll figure something out when you get back.
                                            Thicker walls should be fine but the important thing for me is to learn more about the power of SU.
                                            After my Sand Dome, I will add to it the Refractory Dome with the pipe still in place. The Refractory dome will be made in 4 Pieces. Because Refractory material is a quick hardening material, and this is a first time for me, I will cast 1 piece at a time. After all 4 pieces are casted, I will join them together. Because each piece will be casted with the pipe in place, this will automatically create the bunghole in the centre. I will just fill the centre with refractory cement to close it of thus creating the "Keystone".
                                            I may be wrong but with the way I plan on doing things, the height of my inner refractory dome will decrease a little.
                                            Really don't know why I'd didn't as I should have started with this first. Its not too late to do so. Any advice to make sure I do it right especially the height.
                                            Chris, I guess the picture attached is what should be used as my spinner. I went to my Hardware store today and explained to the salesman what I require and how I will use it. Unfortunately he couldn't think of anything to supply me with that could help me create a spinner.
                                            Also regarding the pipe, any pipe you recommend?
                                            Lastly, how large of a diameter should my bunghole be and this will be the same diameter of my pipe.
                                            Regards
                                            D0me
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
