    [Plugin] Extrude Edges by Face
    38 Posts 10 Posters 55.9k Views 10 Watching
    • charly2008C Offline
      charly2008
      A promising tool, thanks TIG
      Face.skp
      Face.skp
        charly2008
        Another Profile. Maybe interesting for Woodworkers.
        Face.skp
          charly2008
          The first experiments reminded me of the plug-ins "Convert arcs, circles ..... to cylinders" and "tube along path". But the fact that you can use different profiles I see it as a powerful extension of the possibilities which the above mentioned plugins have.
          Face.skp
            charly2008
            Here are a few experiments with different geometric bodies.
            Face1.skp
              DIEGO-RODRIGUEZ
              TIG excellent update. thank you very much for the speed at which fixes plugins
              can you add, optional, the orientation of the face?
              similar to the file attachment, or other options for rotation of the face
              maybe
              align with curved or aligned with the axis, or random alignment
              http://img46.imageshack.us/img46/5838/sinttulo1czn.jpg
              http://img716.imageshack.us/img716/613/sinttulo2u.jpg
              TIG is possible?
              05.skp
                DIEGO-RODRIGUEZ
                hi tig.
                a question.
                This plugins can work with 2 face and 1 rail?
                for example
                initial one face (circle), and a final face (square)
                or
                initial one face (rectangle), and a final face (square)
                or just the same face but with a different scale.
                for example
                face 1 rectangle of 10cm x 15cm
                face 2 rectangle 20cm x 30cm
                  Yes it can.
                  Make sure the two Profiles' edges - the circle and the square [welded] - are both Curves.
                  Make the Rail a Curve too - even if it's only one segment long !
                  Pick Rail-1 and re-pick it as Rail-2 when prompted...
                  • X Offline
                    xrok1
                    @xrok1 said:
                    here's what i get:
                    http://forums.sketchucation.com/download/file.php?id=42840&t=1
                      DIEGO-RODRIGUEZ
                      @tig said:
                      Yes it can.
                      you say use the extrude edgesbayrailes plugins?
                      my question is can you do with your extrude edges by face.
                      that automatically positions the face about the curve
                      the idea is that works like this plugins
                      http://www.drawmetal.com/tapermaker
                      is it possible?
                        It's the Extrude Edges By Rails **By Face** plugin that does this.
                        That works very similarly to EEbyRails BUT it makes the ribs from a preselected face - like the individual 'rib' made with EEbyFace..............
                          DIEGO-RODRIGUEZ
                          tig apologize. not understand well what you say.
                          My idea was that the plugins Extrude Edges by Face, work with both sides and a rail.
                          like the example attached. ( picture + file )
                          http://img96.imageshack.us/img96/9297/sinttulo1mh.jpg
                          Operating:
                          select two sides + a curved edge
                          run the plugins
                          generates geometria
                          this is possible?
                          Sin título.skp
                            this is possible?
                            2 faces + path by Kirill2008 😉
                              OK you can already do this with EEbyRails IF the edges of the two faces are Curves and you make the 'path' curve as the two Rails...
                              You want a tool Extrude Face to Face By Rails ?
                              You pick Face1 then Face2 then Rail1 and Rail2 [or Rail1 again].
                              It'd work just like EEbyRails but the Profile and the Melding-Profile are made from the edges forming the two faces' outer_loop...
                              I'll think about it but I think it's been done 💭
                                DIEGO-RODRIGUEZ
                                if Tig. It has done something similar.
                                2 faces + path but it can do, but is more complex.
                                other plugins that generates something like this is tapermaker. but is limited
                                only use preset faces in a dialog box
                                but
                                Extrude Edges by Face is fantastic plugins. is simple and fast
                                  See here http://forums.sketchucation.com/viewtopic.php?p=226249#p226249 for Extrude Edges by Faces...
                                    Tool has been updated
                                    1.4 20100220 Glitch on some text in db fixed.
                                    1.5 20100220 Glitch with number of Rail-Ribs fixed.
                                    Color coding of picked curves added.
                                    Profile=Cyan
                                    Rail1=Magenta
                                    Rail2=DarkVioletRed
                                    MeldingProfile=DarkCyan
                                    FaceEdges=Orange
                                    See here for download link http://forums.sketchucation.com/viewtopic.php?p=224218#p224218
                                      chrisjk
                                      TIG, there now seems to be a problem with your latest EEBRF:-
                                      http://woodgen.smugmug.com/Other/MIsc-Forum-posts-1/Screen-shot-2010-02-20-at/792649990_rXWyB-L.png
                                      so far so good..
                                      http://woodgen.smugmug.com/Other/MIsc-Forum-posts-1/Screen-shot-2010-02-20-at/792649988_5PBK3-L.png
                                      It just stops working here after clicking OK.
                                        Are you sure?
                                        Just wait end calculation ?
                                        Do you see something bottom screen left corner screen line help?
                                          chrisjk
                                          Frenchy,
                                          I am sure. I replaced the latest version with a version from 18 Feb and that works fine. Changing the older one out for the newer again and it still hangs at the same point.
                                          I am on a Mac - maybe there's a difference?
                                            There are two tools EEbyFace and EEbyRailsByFace - you are jumbling the threads. 😕
                                            EEbyFace - you pre-pick a Face and a path of Edges and run the tool there are no prompts to pick curves etc
                                            EEbyRailsbyFaces
                                            Pre-pick the ProfileFace
                                            • you run the tool
                                              Pick the profiles as with EEbyRails...
                                            BUT it shouldn't dump out like that.
                                            I have tried to replicate this and got it too...
                                            I have a fix - publishing it soonest... 😒
