    Help Me Draw A Dome [TUTORIAL]
    322 Posts 10 Posters 48.8k Views 10 Watching
      @d0me said:
      ...I will start by first creating the cylindrical 2" pole in the center of my first circle and then start drawing the domes around it. Will that be the correct way to start or should I first do the domes and then fit the pole in and then intersect?
      You can do it either way - start with a shape that would lathe around with the hole in it or intersect later. Doesn't really matter actually.
      With regards to the entrance, I will play around with putting it into a single segment and see how far I get. I will update my progress here and if its OK, request assistance when need be.
      Sure - just coma back with any questions any time. šŸ‘
      A quick question. Since this dome will now be divided into 4 pieces, what should the segment count be. I know that we originally made it 24.
      We changed the 24 segment circle to 48 and indeed the 12 segment arc to 24 (i.e. doubled both). This can still be the practice as both are divisible with 4, too (and that is the main point)
        D0me
        Hi Gaieus
        I've started redoing this exercise but didn't get too far.
        I came up to this point and then couldn't get further.
        I noticed in the link mentioned above, you said that the ideal solution was somewhere between yours and mine. I downloaded the version you uploaded there and tried looking at it to see if I can find my way around. I noticed that both arcs in your version were made into individual groups using the same circle. My guess is that 2 circles were created with the same radius.
        I also noticed that the ARC's in my sketch (attached)are not as smooth as the ones you created found in the link above (Edit: After posting, I rechecked my sketch and realized that i forgot to set my segments for the arcs to 24. After doing so, it looks much more smoother and rounder. I have attached the sketch with the new line segments on the arc. You will also notice that I have added additional arcs on this new sketch. My sketch will have a total of 5 domes piled onto each other as can be seen in the sketch.)
        Regards
        D0me
        Dome X 3.skp
        Dome X 3 - Additional Arcs.skp
          You need to select a face and a path (two half circles) and group them. See image. Do this with every, individual face + half circles (there are a whole bunch of them - you can include a pair in each group - see my attached file where this is already done).
            D0me
            Hi Gaieus
            I've been trying to do that since yesterday but instead of clicking once on the semi-circle, I ended up double clicking, which is probably the reason I was unable to group it.
            I have managed to group the arcs with the 2 semi-circles but I did notice a slight difference between your model and mine.
            I have attached images explaining the difference.
            The first image is my model and the 2nd image is yours.
            Should I be concerned about what I noticed.
            Regards
            D0me
              It's because the original circles are still there and for some reason, SU prefers those to be displayed (greyed out) instead of the ones in the group. Hide all the groups, select all the remaining, loose geometry and delete. You won't need it anyway and it will only litter the model and confuse you later.
                D0me
                Hi Gaieus
                Thanks, didn't even realize that there was some left over circles on the model.
                Now I can proceed.
                Will keep you updated on my progress and surely drop by with any issue I experience.
                Take Care
                Regards
                D0me
                  Alright!
                  Looking forward to your advance with the model!
                  šŸ˜‰
                    D0me
                    Hi Gaieus
                    Once again, I am at a jam. Well not really a jam as I managed to find a tedious solution but Im curious to know why this happened.
                    When I double click on a group and try selecting my 2 semi circles so I can set my path for the follow me tool to follow and create the dome, I find that small bits and pieces of the semi circle are selected rather than how I am able to select the entire semi-circle on your model with one click.
                    Any idea why it would do that?
                    Regards
                    D0me
                      D0me
                      Hi Gai
                      I’ve gone quite far but a few questions and minor problems arose and are discussed below.
                      While following the tutorial, I came across a post where you said my dome is upside down. How do I check if I’ve made this mistake again or not?
                      After continuing further, I came across this image where you mentioned some extra line segments and to delete them but I can’t seem to find them on my current model. Are the segments there somewhere and I am just missing it?
                      After creating my slicing plane, I positioned my rotate tool on the slicing plane till I got the inference (Intersection in Group (Rotate Tool Is Green)) and then I dragged the tool up until I got an inference saying ā€œOn Blueā€. I then grabbed the corner of my slicing plane and moved it to the nearest midpoint. It did snap to the Midpoint but the inference I got was End Point though I could physically see my slicing plane on the midpoint. Is this anything to worry about?
                      You mentioned here that you temporarily Grouped Everything, do I did the same by selecting everything and right click > make group.
                      Now I am at this image . This is what I’ve done so far. I double click my dome which still has everything grouped except the newly created arch entrance (At this stage, I’d like to ask whether all the pieces of my dome should still be grouped as you mentioned here that it is a temp grouping). Once I enter the editing context of the group, I triple clicked the left dome piece to get inside of the geometry. I then right clicked and selected intersect with model. After doing this, I used Ctrl+H to hide the rest of my model but now my dome doesn’t look like yours found in this image .
                      I have a backup before intersecting the model and I may have a backup before the temporary grouping if we need to go back a few steps.
                      Regards
                      D0me
                      Dome X 5 - Opening Arch Intersected.skp
                        Well, I also noticed that for some weird reason (and no, I do not know or understand the reason) when I group those circles, they get exploded. Not a big deal because the follow me tool would explode them anyway. There is that inconvenient issue only that in order to establish the path for the follow me tool, you need to select the segments individually - unless you think a little bit. šŸ˜‰
                        After thinking, select everything by triple clicking then deselect the arch face and its bounding edges by holding the Shift key and double clicking on it. Now you have the circle selected only - pick the follow me tool and apply it on the arch face.
                        I cannot really remember where those segments came from - but if they are not there now, no problem at all.
                        I don't know why it says endpoint but if you are sure it is not an endpoint, it's okay then. Maybe there is a broken line somewhere but it won't cause any serious problem I believe.
                        I only grouped those things because it is easier to handle the pieces together when rotating. In fact, that grouping is not necessary at all - I only did it because as a lesser experienced user, you may not be able to do the rotation at once perfectly and this way we could avoid re-selecting the pieces all the time. If you now feel comfortable with the tools already, no need to group at all - and you can explode this container group when you are done.
                        At the first sight, your dome looks just fine except for one thing; all faces are inside out. Select the faces (inside the components), right click and "reverse faces" so that the white faces are outside. It is not extremely important for you but you will need to get used to model everything consistently as who knows when you decide to render your models or export to 3rd party software where this may be important.
                        Since those are two, identical instances of the same component definition, the "Hide rest of model" command will not hide the other instance. There is another command; "Hide similar" and if I remember correctly, we have also set up a shortcut for you - Shift+Ctrl+H but if not, you can still do it (or don't care about the other instance if it is not too much in your way).
                          D0me
                          Hi Gai
                          Thanks for the clarifying for me the points in my previous post.
                          I exploded the group of Dome Pieces and now I am able to access each piece individually without entering a group. I indirectly learned about the Explode Function.
                          I don't really care about the other instance as it doesn't come in the way though I will start making use of that function of hiding similar.
                          Now comes a small problem
                          I've managed to intersect the entrance and clean whatever is not required.
                          Now I am at a stage where I need to close of the face of the entrance but every time I draw a line from 1 end point to the other, it doesn't close the face. Please assist me.
                          Regards
                          D0me
                          Dome X 5 - Opening-Cleaned.skp
                            Hi D0me,
                            Whatever you attached does not seem to be the model you put the image if in. In your model, tha entrance piece is one group while in the picture, it is something of two, different groups/components.
                            So I cannot advise on the model but tried to comment on the image. Of course, you cannot close a face with any entity that is outside of the editing context you are in (i.e. you are working with half of the entrance- how do you expect to close a face with the other half???)
                            So just draw the half - with two edges (like I depict below). Then you can hide the connecting seam with the Shift+Eraser tool if you want...
                              D0me
                              Hi Gai
                              I don’t know how I went about uploading the wrong model. Apologies for that, I have so many backups, that I may have incorrectly sent the wrong one.
                              I didn’t realize I was outside the editing context of the entity I wish to close the face of. Did I go wrong along the way that has caused this?
                              I tried to follow your instructions from the image whereby you advised to close the face using lines and then use the eraser tool to delete the seams. I failed to succeed.
                              So I decided to take a few steps back. I have a backup of my model where the individual dome pieces were still grouped. I left it that way as and didn’t explode the group like how I have done previously.
                              I then created the first part of my arch entrance.
                              After that, I used the offset tool to create the second part (3") of my arch entrance. I then interestected my entrance and then cleaned up what was required. Now I am again at the stage where I cannot close the face. I’ve attached the model and this time I made sure to double check it is the same one as the images I have uploaded. Can you guide me using the model I uploaded?
                              Thanks for being patient with me. Much appreciated
                              Regards
                              D0me
                              Dome X 5 - Entrance Just Started.skp
                                Well, the intersect command will not generate those faces of course. There are two ways to get them there;
                                1 - you can "hand-stitch" the edges but that's tiresome and not very elegant.
                                2 - follow the tricky steps below:
                                First we need to get those pieces from somewhere - and obviously the entrance group is the most convenient to "borrow" some faces from. Enter the group, select that top surface and intersect it with the model.
                                Now copy that bit (Ctrl+C) onto the clipboard. If you wish, at this moment you can even undo the intersect operation (we won't need those ugly lines on that entrance) as the undo will not undo whatever is on the clipboard.
                                Finally enter the dome component (inside your group so do the double click twice) and go to Edit > Paste in place. The just copied face will be there for you. Reverse its face so the white is out and done.
                                  D0me
                                  Hi Gaieus
                                  Neat trick. Worked like a charm.
                                  Now I am at the 4th dome and this new trick you taught me doesn’t seem to be working as it did for the previous domes.
                                  I hid the previous three domes and the last dome found below the 4th dome. I then intersected the 4th dome and something just didn’t look right but anyways I still proceeded with the cleanup. After the cleanup, I intersected my tunnel so I could create the face and then copy it to close the face of the 4th dome.
                                  In the picture attached, you can see that this dome face didn’t close of as neatly as the others and left some portion of the face open as pointed out using the red arrows. Also, will I use the same solution to this problem on the last and final Dome which is labeled Sand Dome?
                                  Lastly, with the previous dome, I had to draw in small lines to complete broken lines that were left after intersecting the tunnel to create the face. Just wanted to check if that’s ok as everything seems to look OK.
                                  I’ve attached a model just after completing the 3rd dome / before starting the 4th dome. I have also attached my current model.
                                  Regards
                                  D0me
                                  Dome X 5 - 3rd Dome Entrance Cleaned & Face Closed.skp
                                    Well, your entrance does not fully intersects the fourth dome. You will need to enter the entrance group and PushPull it until it fully intersects that dome, too.
                                    From this view, it is also apparent that you cannot use this entrance group to intersect the very middle dome (sand dome?) with. There has to be another solution.
                                      D0me
                                      Hi Gai
                                      I've pulled back the tunnel and then intersected. After that I cleaned up the opening but still something didn't seem right. I continued cleaning and drew back any broken lines. I then entered the tunnel and intersected to get the face for the 4th dome piece. I copied the face, undid the intersection. I entered the fourth dome and pasted the face in place.
                                      Attached is what I ended up with. Definitely not looking right. I had to have gone wrong somewhere?
                                      With regards to the last dome (Sand Dome), what solution can you propose for me?
                                      Regards
                                      D0me
                                      Dome X 5 - 4th Dome Problem.skp
                                        Hi D0me,
                                        Working on it... I see the problem and found the reason just need time to put everything together.
                                          Okay, here is what I found. One little line segment was not created at the very edge of the intersection. The reason (probably) if that the intersect with model command does not intersect coplanar geometry (the intersect selected command does that) and there, as the width of the entrance and the innermost dome are exactly the same, that edge would have been coplanar. Here is a screenshot in X-ray mode (well I can imagine how confusing it is with all the lines everywhere).
                                          Also, to be able to work easier in this line jungle, I placed the different layers/shells of domes on different SU Layers. Open your layer dialog from te Window menu and turn them on/off to see the logic.
                                            D0me
                                            Hi Gaieus
                                            Thanks for investigating and assisting in resolving my problem.
                                            After my previous post and just before reading your reply with the solution, I decided to take one more look at the model to try and see if I can figure out whats causing these problems with the last 2 domes.
                                            I also picked this up when looking over the model. It then struck me that this could be the major cause in my last two dome, not intersecting properly. So I decided to take a few steps back. I had a backup of my model just after all my dome pieces were created and before creating the Arch Lines for the entrance. Instead of a 3" wall thickness for my tunnel, I chose a 1" thickness. I then went about following your tutorial and steps to make the tunnel. After creating the tunnel and intersecting all the Dome pieces, everything worked out perfectly. The problem was definitely my tunnel dimensions and specifically my wall thickness which made my tunnel exactly the same width as my second last dome.
                                            All your teaching and the hard work and effort you put into tutoring me helped me diagnose the fault myself and I cant begin to explain how good it feels. Thanks Gaieus for bringing me so far along.
                                            I've attached my model. Please can you have a look and see if everything is OK.
                                            Now I am going to start the cylinder in the middle of my dome to create the bevel at the top.
                                            Kind Regards
                                            D0me
                                            Dome X 5 - Arch Lines Done + Groups Created.skp
                                            With your input, this post could be even better šŸ’—
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
