    [plugin] Ruby Code Editor - UPDATED to v3.0 3/4/2013
    56 Posts 11 Posters 44.3k Views 11 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @driven said:
      I'll globalise it, and do you have any objections to me posting this ruby for others, less interested in doing it themselves... I think really handy.
      Well handy yes, but not all that 'special'. There are numerous plugins around that put help links on the menus. (One by Didier and TBD that will search all folders under Plugins and create links to any help file type, like .pdf, .txt, .chm, .hlp, .htm, etc... automatically.)
      There is a problem with your version. You have the new constructor inside the command block without a conditional check to only create a new instance if it has not yet been done. Repeated clicking on the menu would create extra WebDialog objects, wasting space on the stack.
      Either move the constructor statement before the 'helpmenu.add_item' line, or add
      ' get_dialog=false' before it and change the constructor inside the {} block to:
      ' get_dialog = UI::WebDialog.new if not get_dialog'
      Probably the 2nd is best, so the WebDialog object doesn't get created unless the menuitem is actually clicked.
      I'm not here much anymore.
        Dan Rathbun
        @thomthom said:
        Except that you can't create modal webdialogs on Mac. A modal form on the Mac only makes it stay on top of SU's window - but not modal.
        He knows, we know. That's really what he wants... it to stay on top.
          Dan Rathbun
          @dan rathbun said:
          Apparently the UI.openURL argument requires (on the Mac,) the protocol 'file://localhost' before the HOME variable. For a trully generic loadstring (if you were to change your username,) this should work as well (all one line):
          UI.openURL("file://localhost#{ENV['HOME']}/Documents/Learning_rubies/TextBook.pdf")
          URLs work slightly different on PC and Mac.
          FYI: On the PC, Windows ignores 'file://localhost/' and strips it off when it passes the path to whatever application is registered to open the filetype. If it's a .txt it will likely open in Notepad, if a .pdf it will open in Adobe Acrobat Reader, etc.
            driven
            Exactly, the Mac 'flaw' is the best feature
            Dan, I got this far last night and I'll have another look, with your new input in mind, but what do think??
            > #  _PDF_Viewer.rb
            > #  seems to only work with adobe pdf format, but that's what safari saves pdfs to, so if it won't open, re-save from safari
            > #  seems to open most image files at full size so you may want smaller copies, export to mail and post to self is cheap and easy,
            > #  batch conversion, or graphics convertor.
            > #  helpmenue.rb Created by Dan Rathbun on 14/02/2010.
            > #  2010 @SCF. No? rights reserved.
            > #  modified for modal Mac usage by john@drivenupthewall.co.uk
            > #  show_modal works differently on PC's
            > #  user selected pdf + image veiwer
            > #  for PLAT=Mac & OS=OSX
            > module SU_User
            >    module Menus
            > require "sketchup.rb"
            > # Check to see if the plugin is already loaded
            > if not file_loaded? "_PDF_Viewer.rb"
            > # where to look for it
            >    helpmenu=UI.menu('Help')
            >    helpmenu.add_separator
            > # it's name in the Help menu
            >    helpmenu.add_item('PDF_Viewer') {
            >       file = UI.openpanel;
            >       get_dialog = UI;;WebDialog.new;
            >       get_dialog.show_modal;
            >       get_dialog.set_url(file)
            >   end
            >     end
            >  file_loaded "_PDF_Viewer"
            > end
            If I move get_dialog.set_url(file) to the top will that allow multi-windows? I do get new file, iff I shut the first window
            chee
            #  _PDF_Viewer.rb
            module SU_User
               module Menus
            cheers
              ? It's terrible. Makes it impossible to make replacements for UI.inputbox.
                driven
                I'll more than likely agree if/when I get to that stage in coding, but being able to simply float the 'TextBook' over SU has already increased my workflow, so for now I see it as a blessing which I may curse later on...
                BTW: I found the your 'missing manual' page helpful, but only found it through google after I almost last-night.
                  Yea - it'd odd that show on PC keeps the window ontop of SU, while on OSX it doesn't. So much for consistency. πŸ˜’
                  ??? == osx.show() pc.show() == osx.show_modal() pc.show_modal() == ???
                  Oh the sanity of being a SketchUp scripter!
                    driven
                    on the PC, if you are watching a tutorial in a wd viewer, can you pause to draw and still see the video, or does it jump to the back,under SU, where you have to go find it to carry on?
                      Webdialogs on PC created using .show() is always parent to the SU window and will stay on top. Like SU's toolwindows.
                        Dan Rathbun
                        Check out these links (bookmark them!):
                        Sketchup Ruby resources
                        http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
                        Developer's Forum Sticky Links
                        http://forums.sketchucation.com/viewtopic.php?f=180&t=20427
                        State of Observers
                        http://forums.sketchucation.com/viewtopic.php?f=180&t=20676
                          driven
                          cheers for those Dan, it is a bit hard to navigate this forum, when your not quite sure what your looking for...
                          don't suppose you know a way of turning off
                          UI.play_sound(Sketchup.get_resource_path("video/fera.mp3"))
                          #in sync with
                          when "stop"
                          		UI.stop_timer @timer1;"video/fera.mp3"
                          I know this dosen't work but I can't find any method of having the sound pause or stop when I turn off the video texture, which I can turn on and of at will.
                          I could change a new page and switch to another .mp3 (blank), but as an exercise I'm trying to avoid that as instead off pause, continue, need to start over to keep in sync...
                            chyn2000
                            I wanted to say that this is an AWESOME plugin!
                            Some functionality suggestions that (IMHO) would make your interface even more invaluable:
                            Add break point capability:
                            At break points, the pluging could add a popup before execution (behind the scenes, not in the viewable text field). The user would just press 'OK' to continue on.
                            Add Escape or Kill button:
                            The Escape would be an emergency breakout to stop execution if the user created an inf loop. Maybe force inserted into any loop conditions (again, behind the sceens).
                            Add Variable Watcher window:
                            This might be pretty hard, but then maybe not, but also a variable watcher window sharing the space with the results/error window. I could see this working by having pairs of fields. Type the variable name in one field and the program updates that fields pair with the in scope value.
                            Reduce Web Console's realestate during execution:
                            Have the option to hide, minimize or make the Web Console transparent during code execution.
                            Just some suggestions, though I'm sure you are busy doing things that actually make you money so you can pay for internet access (oh, and I guess eat and have a place to sleep too... πŸ˜‰ )
                            Cheers!
                            Reg
                              Dan Rathbun
                              @driven said:
                              don't suppose you know a way of turning off ...
                              This needs to be broken off into a new thread. It's far removed from the WebConsole/RubyEditor discussion.
                              (and sorry.. John, I don't mess with sound in Sketchup or WebDialogs. My only suggestion would be to embed a media player of some kind in the webpage. Check up on the html OBJECT tag. [EMBED and APPLET are deprecated.])
                              http://msdn.microsoft.com/en-us/library/ms535859(VS.85).aspx
                              • chrisglasierC Offline
                                chrisglasier
                                Here's yet another plugin related to this from 2006.
                                The introspection aspect is interesting but it seems to have some problems with XP.
                                suapi.rb
                                  Dan Rathbun
                                  @driven said:
                                  Is it possible, or could I put it on my website and read it from there (less preferable as the books not published yet)?
                                  I think it would be better to open the PDF file using the Adobe Reader browser plugin running in a normal instance of Safari (in your case.)
                                  How to Access a PDF in your default Browser
                                  Safari on Mac | MS Internet Explorer on PC
                                  Copy the code below save it to a file name 'helpmenu.rb' and put it in your plugins directory.
                                  # helpmenu.rb for PLAT=Mac & OS=OSX
                                  # Public Domain
                                  module SU_User
                                    module Menus
                                      # Edit the 'Your TextBook Title' Menu Item Title below
                                      # Edit the pathname to your textbook pdf file below
                                      helpmenu.add_item('Your TextBook Title') {
                                        UI.openURL("file;//localhost#{ENV['HOME']}/ruby/help/textbook.pdf")
                                      #   #{ENV['HOME']} inside a double-quoted string
                                      #   should return something like; '/Users/John' on the Mac
                                      #   For PC, the HOME variable must be changed to USERPROFILE
                                    end # module Menus
                                  end # module SU_User
                                  Revised: Added 'file://localhost' to openURL argument.(see posts below.)
                                    rvs1977
                                    looks great!
                                    I discovered a strange behavior with my (danish)keyboard. When I want to
                                    make brackets [ ], it opens a small textarea inside the console.
                                    The textareabox appears when I push the AltGr key. When I enter numbers
                                    and press Enter, it submits it at the top op the console???
                                    anyone seen that too?
                                    Get a Ruby
                                    • alexschreyerA Offline
                                      alexschreyer Extension Creator
                                      Just updated to version 2.0.
                                      Cheers,
                                      Alex
                                      Author of "Architectural Design with SketchUp":
                                      http://sketchupfordesign.com/
                                        Alex (or anyone as a matter of fact): excuse my utter ignorance but how do I launch this plugin at all? 😳
                                          driven
                                          it's under Window >> Ruby Code Editor, not Plugins
                                          make sure it's 'checked' as an extension in prefs if not showing up
                                            Holy crap! I did not even think of that location. Thanks a bunch! πŸ‘
                                            (And of course, to Alex for the plugin) πŸ‘
                                            • 3 / 3
