    How to "build" with bricks in sketchup - Newbie
    25 Posts 5 Posters 11.1k Views 5 Watching
    • GaieusG
      @jagizzi said:
      I have been going through the newbie forum. Probably should have posted this there i guess, sorry.
      If you felt it were more comfortable there, I can always move your topic there and we can continue there.
      We have the newbie forum so that anyone can feel more comfortable when asking "embarrassingly newbie" questions but we never force anyone to use it with even the most basic questions.
      @jagizzi said:
      How can I get these bricks to touch each other, and also to be on the same plane?
      What you haven't probably learnt yet is how to utilize, exploit and harness all the potentials of the inference engine in SU. It will always help you align object perfectly - in fact, some people wish they could turn it off in certain cases instead. Simply picking a component's endpoint with the move tool:
      Then move it snapping to the endpoint of the other brick:
      floor bricks.skp
      @jagizzi said:
      i need to figure out how to tilt the bricks prior to arranging them in an array but one step at a time.
      As for the alignment of the brick piece, it is the same (we need to draw the stray line below in order to break the arc entity otherwise we never get the midpoint inference on the segment. Erasing it in a later step will "heal" the arc back).
      Without talking too much, see the steps:
      As for your other file you have just posted while I was writing this, I'll have a look (one step for me at a time, too πŸ˜„ )
        jagizzi
        Gaieus,
        I can handle the number of segments as I know how to do that. What I cannot do is align anything at this point. I created a brick. It aligns to the axes, snaps to them. My arc is more than a semicircle so the brick does not line up with a segment of arc when I pull it, the arc that it.
        I am on my Mac, which is new to me, so I don't know how to capture a window to post so I will have to save the sketchup file itself. (Would take that bit of knowledge too, if you knew how). Easy on my PC buy am learning the mac as i go.
        If you can tell me how to get the brick to line up with a segment it would be most appreciated. it may also help me solve other alignment issue that I seem to have as well.
        Thanks,
        nonaligned.skp
          jagizzi
          I will digest what you have so kindly posted, no need to move to newbie forum if others don't mind.
          You are posting as I am posting and the answers magically appear, whew.
          I will practice what you have posted and get back to this tomorrow. The dog is snoring so I should probably think about it as well.
          Many thanks for your help so far. i fear there will be many more questions, but I promise not to overwhelm too much in one day :>)
          Jim
          PS. Glad to have found this forum. I am also looking forward to the newletter. I saw it referenced in your signature so will definitely be reading it. Will most likely be above my head for a while but, like Photoshop, I am sure it takes time, practice, and some patience.
          • GaieusG
            @jagizzi said:
            Gaieus,
            I don't think that my mortar joints will look as good as those that you have placed into your arch. I am a newbie at that part as well :>)
            It's a kind of "cheat" actually - I simply made an arch of the original arc (a bit offset and recessed with the PushPull tool on the front and back). See attached model - go through the "scenes"
            Arch.skp
            You can see that I struggled with the porcha s there are several solids making up what should be one surface but hey, It helped me see the structure, which was my goal.
            So I have lloked into that file, too. You could actually erase most of those edges dividing the roof of the porch.
            This should be solved exactly the way I showed in my last post. But make sure to make the brick a component first. Now, as you have built it on top of the arc, it intersects with it and if you look at it from below, it has chopped off a bit of the last segment. You will end up with errors this way.
            Yeah, I keep turning my head, too... 😲
              jagizzi
              Gaieus,
              Woo Hoo! I got the inference part, thanks loads for that! I just wasn't moving in close enough to pay that much attention to the cursor change and the endpoint color changes.
              That is nice. I can now clean up my floor bricks, much appreciated.
              Now, truly, all for tonight for me.
              Jim
              • chrisglasierC
                chrisglasier
                How about getting hold of one of DOme's segments and "cut" it up into bricks?
                • chrisglasierC
                  chrisglasier
                  If you don't want absolute precision just aspect
                  (briks will be not separate objects)
                  Call hidden Geometry
                  Select faces you want and Apply Joint Push Pull by Fredo6 πŸ˜‰
                  I think he wants accuracy. So why can't he trace appropriate hidden lines, create a brick using the geometry and then print the front + top face full size as templates for plywood templates?
                  Every home needs a DOme ...
                  PS don't forget the bunghole problem
                    jagizzi
                    I have managed to lay out the floor with your help. Thanks.
                    Now I need to trim it, and that, again, is not obvious to me. Also complicated to explain but I will try.
                    I want to take the included circle and lay it on the floor and cut away the surrounding bricks with the following exception.
                    There will be a vent floor that is 19" wide at the point that it touches the circle. Basically lopping off the section of the circle that is defined by a chord 19" long.
                    That floor will be 23" wide at the outside edge and will be 16" deep. the final form should be something like a keyhole shape. See the first photo in this thread.
                    Obviously possible but not easy to figure out. I laid the circle onto the bricks and thought that I would be able to push them away, but the only surface that is push/pullable is the full set of bricks contained by the circle. that I don;t understand at all but think it must have something to do with the fact that the bricks are components.
                    Again, looking for advice. I was thinking of making the courses of bricks on different layers. Would that be a good idea? I don't know if that will cause registration issues later.
                    Thanks,
                    Jim
                    floor bricks.skp
                    • GaieusG
                      Right, you cannot PushPull only "raw", flat, coplanar faces. So no components, groups, curved surfaces or image entities (and whatever I now forget). So in order to be able to PushPull a face in a component, you have to edit it to enter its editing context - then you can access the face inside.
                      Note however that if you edit one instance of the same component definition, all the other instances will be affected, too, so you need to make some of those bricks "unique" components (in which case the idea of being a component is somewhat redundant but we can live with that).
                      First you have to position your circle on top of the bricks, PushPull it into a cylinder (you will only need the side of the cylinder), delete a 19" part in its front, make the affected bricks (quite a lot) unique one-by-one (I painted them in the model), edit each, intersect with the model and then you will find the intersection lines appearing - along which you can PushPull and lose the parts that are outside of your cylinder.
                      If you wish, you can play around with finding symmetrically similar pieces and spare some bits of memory using parts that are cut similarly as instances of the same (but already unique) component (see two, probably similar pieces painted differently) but that would be more hassle than finishing with each one by one.
                      This is actually the same as in real life - you need to cut those pieces one by one while the whole ones inside or outside can come from the factory.
                      floor bricks.skp
                        jagizzi
                        Hi Gaieus,
                        I am able to edit the component and push the faces away as you have instructed thanks. As my goal is twofold, however, to learn as well as model, I have another question.
                        super simple as well but I have to ask it as I can't make the circle. My circle is not hollow as yours is, but is a solid circle. I then have no idea how to cut out a piece that is 19" wide.
                        As I said, these seem like simple things but I don't know how you did them.
                        Thanks for getting me this far.
                        Jim
                        • GaieusG
                          You can always select a face/surface and delete it. I pulled the circle up to be a cylinder and deleted the top.
                          As for the opening - I made a cube with 19" sides, made it a group, poked it into the cylinder, entered the cylinder group (I believe I made it a group), selected the sides and right click > Intersect with model. Then deleted the useless geometry and there is the opening.
                          In SU you keep adding/subtracting until your model is done.
                            How about getting hold of one of Dome's segments and "cut" it up into bricks?
                            (briks will be not separated objects)
                              jagizzi
                              Duhhh is the only response that seem appropriate. I should have been able to figure that out.
                              Well, thanks though. On to the next phase.
                              I am sure i won't have anymore questions as it is all super clear to me now ;>)
                              • GaieusG
                                @jagizzi said:
                                ...I am sure i won't have anymore questions as it is all super clear to me now ;>)
                                You never know... πŸ˜‰
                                • chrisglasierC
                                  chrisglasier
                                  Like what you going to do about the bunghole problem!
                                  • daleD
                                    dale
                                    @jagizzi said:
                                    Gaieus,
                                    Thanks,
                                    jagizzi to do a screen capture on your mac you can use "command/shift/3" for a full screen capture, or "command/shift/4 " will bring up a set of gun sights to capture the area you highlight.
                                    I have always wanted to build one of these ovens for bread and pizza, so I will follow this closely. πŸ‘
