    Slow loading library
    4 Posts 3 Posters 491 Views 3 Watching
    • C
      cb2
      version 7.1.6860
      Since loading this version (I think) my materials library has been very slow loading.
      Has a file path changed?
      What should I be looking for as the culprit?
      Thank you kindly, CB
      • Chris FullmerC
        Its terribly slow for me too. Drives me nuts. I think others have mentioned it in the past, but no fix has been offered that I know of.
          Jim
          I created a "Default" folder in the Materials/Colors folder and moved all the color .skm files in there. Then I created a very minimal color set for the Colors library. Much faster. You could even organize the default colors into folders based on color value, etc.
          In general, create several sub-folders with fewer materials in each. The trade-off is more clicking to get to the material you want - but it is still faster than having the entire palette loaded at once.
          • C
            cb2
            Thanks Chris and Jim. I didn't realise that it was a bug. I will try your idea Jim, sounds like a workaround. Thanks, CB
