    Optimization Tips
    110 Posts 22 Posters 172.5k Views 22 Watching
      @adamb said:
      OT: Any chance the forum administrator of SCF can fix the [ruby:38zsi59i]tag to not remove formatting. Formatting is a big part of understanding code, and while for regular text collapsing whitespace down to a single space might work, for code it does not.
      I think the ruby is meant for inline code. While you got the code tag for block codes. (Though I wish there was a way to expand it - I loathe internal scrollbars.)
        Interesting test Adam:
        doit 6.474 3.292 nil
        Note: I increased the number of iterations ( 10000000.times { ... })
          Didn't realise Ruby would recreate the variables for each iteration. I'd thought it'd keep them for the duration of the loop...
          • AdamBA Offline
            AdamB
            Seems an arbitrary (and wrong) assumption that inline code requires removing whitespace. Why not just leave in what the author wrote rather than trying to second guess? Whatever.
              Agree - whitespace eating of ruby has bothered me as well. Will ask if it can be changed.
              • AdamBA Offline
                AdamB
                The closure you create with curly braces is handled as a first class object and passed as an argument to the iterator. This means the scope of any variables you mention inside that block is limited to that block - it must create them each time. 😞
                  Is that why each is slow?
                    Guys, Thom asked if we can do something with these white spaces but I have to say it is most probable that we cannot. I is hard coded somewhere in the php script of the forum software and even if we could tweak that, it would be impossible to keep it through upgrades (which is very due soon anyway).
                    Is the code tag not good (apart from that scrolling annoyance)?
                      It's ok. I just hoped there was a config UI for BBCode tags on the forum. Thought it was normal. The code tag is ok, just figured if it could be changed...
                      I don't suppose there are forum plugins that can be installed? having the code block apply syntax highlighting would be a delight for us coders. Such as this:
                      Google Code Archive - Long-term storage for Google Code Project Hosting.
                      (code.google.com)
                      http://syntaxhighlighter.googlecode.com/files/Overview01.png
                      Edit: what version of phpBB does SCF run? I'm looking at this: http://www.phpbb.com/kb/article/adding-custom-bbcodes-in-phpbb3/ from this it appear to be that it'd be a matter of setting the HTML replacement for the ruby tag to not collapse white space using CSS.
                      Replacement sample something like this:
                      <span style="white-space:pre;">{TEXT}</span>
                        I can imagine you would like that syntax highlight! I use Notepad++ and know what a difference it is!
                        Coen and Tavi should be spoken to about these things.
                          @adamb said:
                          I see a lot of SU scripts using some of the more compact iterators Ruby iterators. So they might read nice, but they're often slower than just simple for-loops.
                          403 Forbidden
                          (blog.shingara.fr)
                          In regard to this should one init the variables used by for in to speed up things? or is that not needed?
                          Would this
                          ` x = 0
                          for x in collection
                          endbe faster than for x in collection
                          end`
                          • AdamBA Offline
                            AdamB
                            no
                              Jim
                              I've always thought for used each under the hood.
                              http://blog.grayproductions.net/articles/the_evils_of_the_for_loop
                              for loops do not have their own scope - the loop variable and any variables created in the loop become available (or are over-written) in the current scope.
                              With .each, variables are local to the block {..}
                                If you click the method names in the Ruby API manual you get to see the sourcecode:
                                http://ruby-doc.org/core/classes/Array.html#M002173
                                  Jim
                                  That's showing a for loop in the c language.
                                    That's what it's doing under the hood.
                                      Jim
                                      Right, so where is the definition for the for function?
                                      The answer is there isn't one because for is not a function, but is "sugar". The for loop in Ruby really uses the .each method behind the scenes.
                                      Although, I can't recall where I learned that. The link to the blog article mentions it, though.
                                      • tbdT Offline
                                        tbd
                                        speaking of each vs for :
                                        loop1 = []
                                        loop2 = []
                                        calls = ["one", "two", "three"]
                                        calls.each do |c|
                                          loop1 << Proc.new { puts c }
                                        for c in calls
                                          loop2 << Proc.new { puts c }
                                        loop1[1].call #=> "two"
                                        loop2[1].call #=> "three"
                                        http://plugins.ro
                                        • Dan RathbunD Offline
                                          Dan Rathbun
                                          @jim said:
                                          The for loop in Ruby really uses the .each method behind the scenes. ... Although, I can't recall where I learned that.
                                          'Pick-Axe' > For ... In expressions
                                          I'm not here much anymore.
                                            Jim
                                            I guess to get back on topic, for loops are not faster then .each iterators. The performance must have to do with how the for loop variables are not loop scoped, as in each.
                                            • 3 / 6
