    Frank Lloyd Wright Project [Update 2-25]
    26 Posts 11 Posters 4.5k Views 11 Watching
    • Horseman04H Offline
      Horseman04
      That link goes to the Freeman House, it looks very similar to the Storer House, but it isn't. I wish there was an Isometric Drawing for the Storer House. I have the Plans though from that page, those are the HABS documents.
        pav_3j
        Sorry, my bad, i should have specified, if you follow the link to the page, and scroll down a bit, it is two article underneath the Freeman house image, that was just the link i followed to the website where found the image.
        Pav
        Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
          Horseman04
          UPDATE
          Driveway Walls and Stairs to House
          I just Traced the Section Cut for the Terrain. At some point I have to figer I'll have to go back and fix it, but for now it works.
            Andy ICEedge
            moved
            http://www.icevisioncloud.com
              Horseman04
              Progress so Far.
                Horseman04
                Well I've Pretty Much Finished the Terraceing on the front of the House, as well as Getting the Terrain to match the photos and Documents.
                Again any Reference Photos of the Storer House Anyone has would be Greatly Appreciated.
                  bytor
                  Horseman04,
                  That is some really nice work! The concrete detail and the pool are excellent in that last image. All this difficult geometry and the challenge of obtaining good reference materials makes this a real labor of love. Great to see your progress!
                  Dean
                  Find the Cost of Freedom.....
                  • Mike LuceyM Offline
                    Mike Lucey
                    Thanks for the update. Looking forward to seeing the finished job.
                      cmoreink
                      I would like to see a close up shot on the walkway and stairs work with some detail πŸ˜„
                      my portfolio
                        Horseman04
                        Tested out some Concrete Texture as well as a Plant.
                          bytor
                          Bravo!
                          Wonderfull detail modeling and texturing there. The bush is very nice - what is the (application / library) source? Only crit would be to make a small gap between the edge of the steps and the wall as these would never butt together that tightly.
                          Again - great work!
                            cmoreink
                            Wicked!
                            my portfolio
                            • chrisglasierC Offline
                              chrisglasier
                              @bytor said:
                              :sketchstatic:
                              Bravo!
                              Again - great work!
                              Bored with coding so ...
                              I would just add that I don't think FLW would allow cutting a pattern (as shown at the edge of the steps) - more likely he would have used a plain border like the wall material.
                                Horseman04
                                @chrisglasier said:
                                @bytor said:
                                :sketchstatic:
                                Bravo!
                                Again - great work!
                                You'd think that, but according to the HABS Survey Documents It is how I modeled it. Any actual photos anyone has which could confirm or deny this would be much appreciated.
                                • artysmediaA Offline
                                  artysmedia
                                  @horseman04 said:
                                  [attachment=0:2a5fnmpj]<!-- ia0 -->Stairs.jpg<!-- ia0 -->[/attachment:2a5fnmpj]
                                  So good! πŸ‘
                                  Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                                  Blog: Artysmedia
                                    Horseman04
                                    Been a while since I updated, but I've been busy with work and other projects. So this is what Ive done since last update
                                    The majority of the First Floor Tiles have been laid. And I started to mass out the Walls for the First Floor. Until today I thought that the First Floor was all on the same height, apparently I was wrong, looking at the section the two Lower Bedrooms are about four and a half feet lower. So now I have to figure out how the stairs work to continue with the rest of the First Floor.
                                    First Floor Plan
                                    http://memory.loc.gov/pnp/habshaer/ca/ca0200/ca0268/sheet/00002a.gif
                                    Larger Image
                                    http://memory.loc.gov/pnp/habshaer/ca/ca0200/ca0268/sheet/00002a.tif
                                    Section
                                    http://memory.loc.gov/pnp/habshaer/ca/ca0200/ca0268/sheet/00006a.gif
                                    Larger Image
                                    http://memory.loc.gov/pnp/habshaer/ca/ca0200/ca0268/sheet/00006a.tif
                                    • DanielD Offline
                                      Daniel
                                      Excellent work. A careful examination of the photos and HABS drawings shows that the textile blocks were not used for the steps, but rather smaller, plain square blocks.
                                      My avatar is an anachronism.
                                        Horseman04
                                        Yes, but photos say otherwise.
